inlinesix Hypersonic January 29, 2022 Share January 29, 2022 12 hours ago, Bluepica said: The battery now is already 2.5yrs old, flattened 2 twice for past 6 months… I just found the fault.. it’s my Thinkware F750… I checked the recording, it’s been recording every min every movement in the MSCP … the last recording shows the battery level only 5.2V !! I checked the cam settings , it’s in recording mode and the cut off recording battery level is 12.2V … but it’s still recording when battery falls below this threshold value. But I think it’s intermittent fault .. I think when the batt flattened 6 months ago, the same trait happened, n I set the cam to lower sensitivity n try to park the car whereby not much movement detected… now I dunno to change the battery or not . Rather than voltage regulator, install a cellink neo. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
alphapunk2 1st Gear January 30, 2022 Share January 30, 2022 Does anyone know if there are any special considerations when installing a dashcam to a hybrid vehicle? I'm talking battery wise. Link to post Share on other sites More sharing options...
inlinesix Hypersonic January 30, 2022 Share January 30, 2022 45 minutes ago, alphapunk2 said: Does anyone know if there are any special considerations when installing a dashcam to a hybrid vehicle? I'm talking battery wise. It still run from 12v battery. Not from Hybrid system Link to post Share on other sites More sharing options...
alphapunk2 1st Gear January 30, 2022 Share January 30, 2022 @inlinesix ok thanks bro Link to post Share on other sites More sharing options...
Kb27 Supersonic January 30, 2022 Share January 30, 2022 49 minutes ago, alphapunk2 said: Does anyone know if there are any special considerations when installing a dashcam to a hybrid vehicle? I'm talking battery wise. Most Japanese hybrid cars have a small 35AH battery for starting. Dashcam would be connected to this battery. So you have the same limitation as a normal car with 35AH battery. Your dashcam can drain that battery flat, if it doesn't behave well. Hybrid batteries is separate from this starting battery. Link to post Share on other sites More sharing options...
alphapunk2 1st Gear January 30, 2022 Share January 30, 2022 @Kb27 got it! thanks for the info Link to post Share on other sites More sharing options...
Yeobh 4th Gear February 1, 2022 Share February 1, 2022 (edited) Parasite DC current can best detect by checking amp draw at each suspected fuse via a amp tester Edited February 1, 2022 by Yeobh ↡ Advertisement Link to post Share on other sites More sharing options...
