SGMCF328 Turbocharged September 3, 2021 Share September 3, 2021 Car and Coffee, I love the concept! 😍😍 MCF should consider getting one to facilitate joint event with ADs. And when situation is back to normal, this Jimny Beans can be deployed for members' MU too. 😎 Source: https://www.piston.my/2021/09/01/fresh-coffee-wherever-you-want-it-with-suzuki-jimny-beans/ In this age of increasing food trucks and mobile food services, here’s an idea from Suzuki’s British subsidiary which turns the Suzuki Jimny into a mobile coffee bar. The conversion of the compact SUV was carried out by Coffee Latino, which specializes in such projects. The vehicle has a Chiffon Ivory Pearl metallic finish with Bluish Black roof and is nicknamed ‘Jimny Beans’. It will be used by the company for promotional activities in the UK, offering complimentary coffee at the venues. The conversion makes maximum use of space within the compact dimensions of the vehicle. The front passenger’s seat was removed to accommodate all the services required which include a 57-litre water tank with 3M filtration system to ensure the water is clean. A compact 12V drawer fridge manufactured by Waeco is also fitted which cools milk to -2 degrees Centigrade. At events, the vehicle can run on either gas or mains electricity with power inverter and has two additional large capacity 125A/H 12V batteries to assist with power if required. For gas, a LPG tank was installed in the limited space under the rear floor section which required a specially designed exhaust system with side exit pipe. And with its 4×4 drivetrain, the little Suzuki can also be taken off-road to camp sites or the beach for fresh coffee. The high specification coffee machine, manufactured by Fracino, is fully integrated into the rear section of the vehicle with an aluminium-topped work area and milled aluminium effect panel surround. It has the facility to serve two speciality coffees at the same time via its twin milk frothing units as well as central hot water dispenser for tea. ↡ Advertisement 12 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator September 3, 2021 Share September 3, 2021 43 minutes ago, SGMCF328 said: Car and Coffee, I love the concept! 😍😍 MCF should consider getting one to facilitate joint event with ADs. And when situation is back to normal, this Jimny Beans can be deployed for members' MU too. 😎 Source: https://www.piston.my/2021/09/01/fresh-coffee-wherever-you-want-it-with-suzuki-jimny-beans/ In this age of increasing food trucks and mobile food services, here’s an idea from Suzuki’s British subsidiary which turns the Suzuki Jimny into a mobile coffee bar. The conversion of the compact SUV was carried out by Coffee Latino, which specializes in such projects. The vehicle has a Chiffon Ivory Pearl metallic finish with Bluish Black roof and is nicknamed ‘Jimny Beans’. It will be used by the company for promotional activities in the UK, offering complimentary coffee at the venues. The conversion makes maximum use of space within the compact dimensions of the vehicle. The front passenger’s seat was removed to accommodate all the services required which include a 57-litre water tank with 3M filtration system to ensure the water is clean. A compact 12V drawer fridge manufactured by Waeco is also fitted which cools milk to -2 degrees Centigrade. At events, the vehicle can run on either gas or mains electricity with power inverter and has two additional large capacity 125A/H 12V batteries to assist with power if required. For gas, a LPG tank was installed in the limited space under the rear floor section which required a specially designed exhaust system with side exit pipe. And with its 4×4 drivetrain, the little Suzuki can also be taken off-road to camp sites or the beach for fresh coffee. The high specification coffee machine, manufactured by Fracino, is fully integrated into the rear section of the vehicle with an aluminium-topped work area and milled aluminium effect panel surround. It has the facility to serve two speciality coffees at the same time via its twin milk frothing units as well as central hot water dispenser for tea. I always find Jimny can be anything. haha. 3 Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged September 3, 2021 Share September 3, 2021 3 hours ago, SGMCF328 said: Car and Coffee, I love the concept! 😍😍 MCF should consider getting one to facilitate joint event with ADs. And when situation is back to normal, this Jimny Beans can be deployed for members' MU too. 😎 Source: https://www.piston.my/2021/09/01/fresh-coffee-wherever-you-want-it-with-suzuki-jimny-beans/ In this age of increasing food trucks and mobile food services, here’s an idea from Suzuki’s British subsidiary which turns the Suzuki Jimny into a mobile coffee bar. The conversion of the compact SUV was carried out by Coffee Latino, which specializes in such projects. The vehicle has a Chiffon Ivory Pearl metallic finish with Bluish Black roof and is nicknamed ‘Jimny Beans’. It will be used by the company for promotional activities in the UK, offering complimentary coffee at the venues. The conversion makes maximum use of space within the compact dimensions of the vehicle. The front passenger’s seat was removed to accommodate all the services required which include a 57-litre water tank with 3M filtration system to ensure the water is clean. A compact 12V drawer fridge manufactured by Waeco is also fitted which cools milk to -2 degrees Centigrade. At events, the vehicle can run on either gas or mains electricity with power inverter and has two additional large capacity 125A/H 12V batteries to assist with power if required. For gas, a LPG tank was installed in the limited space under the rear floor section which required a specially designed exhaust system with side exit pipe. And with its 4×4 drivetrain, the little Suzuki can also be taken off-road to camp sites or the beach for fresh coffee. The high specification coffee machine, manufactured by Fracino, is fully integrated into the rear section of the vehicle with an aluminium-topped work area and milled aluminium effect panel surround. It has the facility to serve two speciality coffees at the same time via its twin milk frothing units as well as central hot water dispenser for tea. Are those wheels on that car steel rims or alloy rims? Link to post Share on other sites More sharing options...
Jamesc Hypersonic September 3, 2021 Share September 3, 2021 This car got stock? I thot its such a hot seller worldwide always no stock one. Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator September 3, 2021 Share September 3, 2021 1 hour ago, Jamesc said: This car got stock? I thot its such a hot seller worldwide always no stock one. My office downstairs have ppl displaying leh. you want me to ask them reserve for you? 😂 $110K for this small little cube. I a bit cannot swallow. hahahaha. But indeed, I also fall in love with this car. so cute. 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic September 3, 2021 Share September 3, 2021 10 minutes ago, kobayashiGT said: My office downstairs have ppl displaying leh. you want me to ask them reserve for you? 😂 $110K for this small little cube. I a bit cannot swallow. hahahaha. But indeed, I also fall in love with this car. so cute. This car can drive for the next 30 years. Too bad we have COE here. 2 1 Link to post Share on other sites More sharing options...
Brass 6th Gear September 4, 2021 Share September 4, 2021 16 hours ago, kobayashiGT said: My office downstairs have ppl displaying leh. you want me to ask them reserve for you? 😂 $110K for this small little cube. I a bit cannot swallow. hahahaha. But indeed, I also fall in love with this car. so cute. I think there's the new commercial version now in the UK since the 1.5L doesn't help with emission standards in the UK. If you slap a G plate on that and get the 10k rebate, I think you can get it for 70 to 80k instead of 110k. Link to post Share on other sites More sharing options...
Scion Turbocharged September 4, 2021 Share September 4, 2021 i always come across those Taiwanese and Japanese youtube videos where Jimny owners drive around the country sightseeing and camping quite a cool and popular car there Link to post Share on other sites More sharing options...
Carbon82 Moderator September 4, 2021 Share September 4, 2021 2 hours ago, Brass said: I think there's the new commercial version now in the UK since the 1.5L doesn't help with emission standards in the UK. If you slap a G plate on that and get the 10k rebate, I think you can get it for 70 to 80k instead of 110k. For commercial vehicle, the only saving would be the 100% - 140% ARF, and the marginal differences in COE premium (between cat A & C), and basing on that, it would be $25K max, which put the commercial Jimny close to $90K based on current COE climate. But have to say the commercial version look equally cool and functionable. 2 hours ago, Scion said: i always come across those Taiwanese and Japanese youtube videos where Jimny owners drive around the country sightseeing and camping quite a cool and popular car there 2 keywords: Cheap (as compared to proper SUV) Functionality (full off road capability) Sadly these don't applies here. 7 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator September 4, 2021 Share September 4, 2021 5 hours ago, Carbon82 said: For commercial vehicle, the only saving would be the 100% - 140% ARF, and the marginal differences in COE premium (between cat A & C), and basing on that, it would be $25K max, which put the commercial Jimny close to $90K based on current COE climate. But have to say the commercial version look equally cool and functionable. 2 keywords: Cheap (as compared to proper SUV) Functionality (full off road capability) Sadly these don't applies here. Woah! The commercial one looks good! can ferry my dog go gai gai! 🙂 1 Link to post Share on other sites More sharing options...
Discoburg Supersonic September 4, 2021 Share September 4, 2021 On 9/3/2021 at 12:09 PM, kobayashiGT said: I always find Jimny can be anything. haha. Wanted to buy that over my Mz 3 but too expensive. Link to post Share on other sites More sharing options...
Vidz 6th Gear September 9, 2021 Share September 9, 2021 too small to hankie-pankie tho... wasted 😀 Link to post Share on other sites More sharing options...
Brass 6th Gear September 13, 2021 Share September 13, 2021 On 9/4/2021 at 12:29 PM, Carbon82 said: For commercial vehicle, the only saving would be the 100% - 140% ARF, and the marginal differences in COE premium (between cat A & C), and basing on that, it would be $25K max, which put the commercial Jimny close to $90K based on current COE climate. But have to say the commercial version look equally cool and functionable. 2 keywords: Cheap (as compared to proper SUV) Functionality (full off road capability) Sadly these don't applies here. Don't forget that there is most likely a 10k rebate as it's petrol. Even the hiace 2.0 could get the 10k rebate, so this should get it too. Link to post Share on other sites More sharing options...
SGMCF328 Turbocharged September 14, 2021 Author Share September 14, 2021 On 9/3/2021 at 12:09 PM, kobayashiGT said: I always find Jimny can be anything. haha. Jimny is one rare car which can be seen as a serious off-roader, cute SUV, commercial vehicle or a daily runabout, and would not look out of place in different occasions. On 9/3/2021 at 2:48 PM, DOBIEMKZ said: Are those wheels on that car steel rims or alloy rims? Should be steel rim. Design or steel rim look very different from the one on this Jimny Bean. On 9/3/2021 at 3:56 PM, Jamesc said: This car got stock? I thot its such a hot seller worldwide always no stock one. Got $$$ got stock, as with any other commodity. 😎 On 9/3/2021 at 5:29 PM, Jamesc said: This car can drive for the next 30 years. Too bad we have COE here. I still see many old Jimny running around, confirm can last 30 years. On 9/4/2021 at 9:51 AM, Brass said: I think there's the new commercial version now in the UK since the 1.5L doesn't help with emission standards in the UK. If you slap a G plate on that and get the 10k rebate, I think you can get it for 70 to 80k instead of 110k. I thought Vehicular Emission Schemes (VES) is only applicable for passenger car and taxi? And if I my memory do not fail me, G plate do not need to pay ARF, so where will the VES rebate come from? https://onemotoring.lta.gov.sg/content/onemotoring/home/buying/upfront-vehicle-costs/emissions-charges.html 5 Link to post Share on other sites More sharing options...
Brass 6th Gear September 14, 2021 Share September 14, 2021 13 hours ago, SGMCF328 said: Jimny is one rare car which can be seen as a serious off-roader, cute SUV, commercial vehicle or a daily runabout, and would not look out of place in different occasions. Should be steel rim. Design or steel rim look very different from the one on this Jimny Bean. Got $$$ got stock, as with any other commodity. 😎 I still see many old Jimny running around, confirm can last 30 years. I thought Vehicular Emission Schemes (VES) is only applicable for passenger car and taxi? And if I my memory do not fail me, G plate do not need to pay ARF, so where will the VES rebate come from? https://onemotoring.lta.gov.sg/content/onemotoring/home/buying/upfront-vehicle-costs/emissions-charges.html https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.channelnewsasia.com/singapore/new-emissions-scheme-april-2021-incentivise-use-cleaner-commercial-vehicles-769281&ved=2ahUKEwiEsoKF1P7yAhWO8HMBHQ1wDlMQFnoECAkQAQ&usg=AOvVaw3bVKWDzi5wDe1S2oTRNgDl I meant this rebate. I think it's lump sum for the 10k and it does not come from the arf as that would only be 1k or so. 2 Link to post Share on other sites More sharing options...
Tohto Hypersonic September 14, 2021 Share September 14, 2021 Recently saw quite a number of Jimny on the road. Very cute and nice little car. But when I check on the car spec, I was like ... what thr F... an old 1.4L with an even older 4 speed auto. 2 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator September 15, 2021 Share September 15, 2021 9 hours ago, Tohto said: Recently saw quite a number of Jimny on the road. Very cute and nice little car. But when I check on the car spec, I was like ... what thr F... an old 1.4L with an even older 4 speed auto. more than enough to power this cute car le. I think in japan, the jimny pass as a kei car, so there is a 660cc version in japan. https://jalopnik.com/the-660cc-2019-suzuki-jimny-isn-t-perfect-but-its-full-1819392546 They should just bring this in, with manual option. Sweet. hahaha. 2 Link to post Share on other sites More sharing options...
Tohto Hypersonic September 15, 2021 Share September 15, 2021 14 minutes ago, kobayashiGT said: more than enough to power this cute car le. I think in japan, the jimny pass as a kei car, so there is a 660cc version in japan. https://jalopnik.com/the-660cc-2019-suzuki-jimny-isn-t-perfect-but-its-full-1819392546 They should just bring this in, with manual option. Sweet. hahaha. Manual will be a better option. Too bad no spare cash for extra car. ↡ Advertisement 1 1 Link to post Share on other sites More sharing options...
This is the redesigned new-for-2015 KIA Sorento.
2026 Volvo EX60 7 Seater BEV
[Concept] Honda 0 Series EVs
Toyota Corolla Cross
Aion Y Plus
Aion Y Plus
2022 Toyota bZ4X
2022 Toyota bZ4X
