Biglittlebean 3rd Gear June 17, 2021 Share June 17, 2021 Have just installed a 4-channel active sound system with DSP. Noticed that whenever I play Spotify music via bluetooth connection to the DSP, there is a hissing/static noise in the background, especially when at the points where there's silence or start of the music piece. However, when I plug my phone directly to the head unit, the hissing/static noise disappears. Using Android phone currently, but have the same results when trying out using my wife's iPhone. Have gone back to the audio shop a couple of times and they have adjusted the DSP gains down, but still can hear the hissing/static sound. They don't seem to be able to resolve the issue so far. One of their staff said that it could be due to the DSP being an entry level one, which I'm not convinced. Does anyone know how to resolve, or any recommendations of an experience ICE workshop that can solve this issue? ↡ Advertisement Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator June 17, 2021 Share June 17, 2021 On 6/17/2021 at 2:57 PM, Biglittlebean said: Have just installed a 4-channel active sound system with DSP. Noticed that whenever I play Spotify music via bluetooth connection to the DSP, there is a hissing/static noise in the background, especially when at the points where there's silence or start of the music piece. However, when I plug my phone directly to the head unit, the hissing/static noise disappears. Using Android phone currently, but have the same results when trying out using my wife's iPhone. Have gone back to the audio shop a couple of times and they have adjusted the DSP gains down, but still can hear the hissing/static sound. They don't seem to be able to resolve the issue so far. One of their staff said that it could be due to the DSP being an entry level one, which I'm not convinced. Does anyone know how to resolve, or any recommendations of an experience ICE workshop that can solve this issue? Expand I suspect is the cable grounding issue. You can try and buy smth like this to tackle it. https://shopee.sg/Mpow-BH392-Ground-Loop-Noise-isolator-1m-3.3ft-3.5mm-Audio-Cable-For-MP3-MP4-Car-Home-Audio-System-Portable-Noise-isolator-i.98700393.6931327912 2 Link to post Share on other sites More sharing options...
Biglittlebean 3rd Gear June 17, 2021 Author Share June 17, 2021 On 6/17/2021 at 3:24 PM, kobayashiGT said: I suspect is the cable grounding issue. You can try and buy smth like this to tackle it. https://shopee.sg/Mpow-BH392-Ground-Loop-Noise-isolator-1m-3.3ft-3.5mm-Audio-Cable-For-MP3-MP4-Car-Home-Audio-System-Portable-Noise-isolator-i.98700393.6931327912 Expand Thanks! But the hissing/static sound only came out when connecting my phone through Bluetooth to the DSP. When I connect by plugging my phone into the head unit directly, the hiss/static disappeared. 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic June 18, 2021 Share June 18, 2021 On 6/17/2021 at 3:24 PM, kobayashiGT said: I suspect is the cable grounding issue. You can try and buy smth like this to tackle it. https://shopee.sg/Mpow-BH392-Ground-Loop-Noise-isolator-1m-3.3ft-3.5mm-Audio-Cable-For-MP3-MP4-Car-Home-Audio-System-Portable-Noise-isolator-i.98700393.6931327912 Expand Yeah. Should be grounding issue. 2 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator June 18, 2021 Share June 18, 2021 On 6/17/2021 at 3:30 PM, Biglittlebean said: Thanks! But the hissing/static sound only came out when connecting my phone through Bluetooth to the DSP. When I connect by plugging my phone into the head unit directly, the hiss/static disappeared. Expand I cannot give you my answer to it bro. I am not a pro to this, but that's my guess. The best is still to go to your audio shop and check it out. It also could be a faulty DSP. Link to post Share on other sites More sharing options...
Othello Supersonic June 18, 2021 Share June 18, 2021 Is your DSP new from audio shop ? Or your own ? Link to post Share on other sites More sharing options...
Biglittlebean 3rd Gear June 18, 2021 Author Share June 18, 2021 On 6/18/2021 at 1:34 AM, Othello said: Is your DSP new from audio shop ? Or your own ? Expand Mine is a new set from an audio shop... A pretty reputable one in fact. Link to post Share on other sites More sharing options...
Biglittlebean 3rd Gear June 18, 2021 Author Share June 18, 2021 @kobayashiGT yea... Will be going back in th next couple of weeks. Just thinking what to do if they still can't resolve it. 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic June 18, 2021 Share June 18, 2021 Bang table. Link to post Share on other sites More sharing options...
Jamesc Hypersonic June 18, 2021 Share June 18, 2021 If bang table don't work. Bang balls. 2 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator June 18, 2021 Share June 18, 2021 On 6/18/2021 at 3:18 AM, Biglittlebean said: @kobayashiGT yea... Will be going back in th next couple of weeks. Just thinking what to do if they still can't resolve it. Expand Change to a more high-end one Mcintosh or Mark Levinson will help you solve the problems. Then pass me the spoilt one. I help you figure out. hahaha. 1 1 Link to post Share on other sites More sharing options...
Biglittlebean 3rd Gear June 18, 2021 Author Share June 18, 2021 On 6/18/2021 at 4:17 AM, kobayashiGT said: Change to a more high-end one Mcintosh or Mark Levinson will help you solve the problems. Then pass me the spoilt one. I help you figure out. hahaha. Expand Hopefully the workshop will have more pride in their work and really resolve the issue. One of the most highly recommended retailers in sgcarmart leh. 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator June 18, 2021 Share June 18, 2021 On 6/18/2021 at 5:47 AM, Biglittlebean said: Hopefully the workshop will have more pride in their work and really resolve the issue. One of the most highly recommended retailers in sgcarmart leh. Expand Who ah who ah. Link to post Share on other sites More sharing options...
Biglittlebean 3rd Gear June 18, 2021 Author Share June 18, 2021 On 6/18/2021 at 6:15 AM, kobayashiGT said: Who ah who ah. Expand Not nice to mention la... So far they have been quite helpful the last few visits. Probably just need another visit to troubleshoot. Link to post Share on other sites More sharing options...
Chess Neutral Newbie September 5, 2021 Share September 5, 2021 (edited) I having the same issue. Install New Venom 3.6 DSP and Sony 4Ch amp running 2-way component speaker. Both place side by side under the seat. After installing hissing and static noise can be heard from the right tweeter when applying the brake. After a week to run in the DSP when back to sort out the noise, what they do adjust the gain however it came back again, this time round noise level reduces but still exist. Went back again, they connect the tweeter to DSP instead of amp noise gone... Now after driving for a distance static noise back again, this time around came from the left tweeter. I was thinking is it the DSP or Amp after the warm-up that could have caused the noise or both place side by side caused signal interference. Keep going back sianz Edited September 5, 2021 by Chess 1 Link to post Share on other sites More sharing options...
Chess Neutral Newbie September 5, 2021 Share September 5, 2021 @Biglittlebean how you sort out the issue alr? Link to post Share on other sites More sharing options...
Biglittlebean 3rd Gear September 6, 2021 Author Share September 6, 2021 On 9/5/2021 at 5:47 PM, Chess said: @Biglittlebean how you sort out the issue alr? Expand No. Was quite busy and didn't have a chance to go back. Will try to go back this week to see if it can be resolved. If can't, I'll probably go to another ICE shop to seek a second opinion. Saw your earlier post. I pm you Link to post Share on other sites More sharing options...
Biglittlebean 3rd Gear September 6, 2021 Author Share September 6, 2021 Anyway, managed to capture the hissing sounds using my wife's phone. Any gurus can advise if this is normal and what I can do to resolve it? VID-20210829-WA0007.mp4 ↡ Advertisement Link to post Share on other sites More sharing options...
Intermittent rattling noise, car in ICU
Foldable static sunshade
To Tune or Not To Tune?
Steering rack noise on 2010 Altis
Extending quiet time by 1½ hours among recommendations to tackle neighbourhood noise in Singapore
NEA to lower vehicle noise levels from 2023
