Bluepica 4th Gear April 8, 2021 Share April 8, 2021 Hi, My car boot trunk suddenly unable to open with the manual lever, I have to use the remote control to open it. Even so, sometimes the trunk light lights up , sometime it doesn't. I have missed 2 service in C&C for more than a year, if I send my car for them to fix this only item, will they entertain me? or if not, which workshop should I go to? Thanks. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic April 8, 2021 Share April 8, 2021 On 4/8/2021 at 1:51 AM, Bluepica said: Hi, My car boot trunk suddenly unable to open with the manual lever, I have to use the remote control to open it. Even so, sometimes the trunk light lights up , sometime it doesn't. I have missed 2 service in C&C for more than a year, if I send my car for them to fix this only item, will they entertain me? or if not, which workshop should I go to? Thanks. Expand Your rear seat can fold or not? Fold it down, climb into the boot, press remote and then kick/push upwards. Did you reverse and bang the wall is it? How can it suddenly unable to open? 2 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator April 8, 2021 Share April 8, 2021 On 4/8/2021 at 1:51 AM, Bluepica said: Hi, My car boot trunk suddenly unable to open with the manual lever, I have to use the remote control to open it. Even so, sometimes the trunk light lights up , sometime it doesn't. I have missed 2 service in C&C for more than a year, if I send my car for them to fix this only item, will they entertain me? or if not, which workshop should I go to? Thanks. Expand C&C will sure entertain you lah. 🙂 After all you are still a customer. For boot wise, you can just go to any workshop for a check. If you manual lever is mechanic one, it will be easier to spot the repair, if is electronic one, then I think will trial and error a bit. Or maybe the OBD scanner can detect what is the fault code. Link to post Share on other sites More sharing options...
Watwheels Supersonic April 8, 2021 Share April 8, 2021 On 4/8/2021 at 2:21 AM, kobayashiGT said: C&C will sure entertain you lah. 🙂 After all you are still a customer. For boot wise, you can just go to any workshop for a check. If you manual lever is mechanic one, it will be easier to spot the repair, if is electronic one, then I think will trial and error a bit. Or maybe the OBD scanner can detect what is the fault code. Expand Most probably something is caught in the catch mechanism. OBD cannot pick up unless you put a sensor there. LoL... 2 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator April 8, 2021 Share April 8, 2021 On 4/8/2021 at 2:29 AM, Watwheels said: Most probably something is caught in the catch mechanism. OBD cannot pick up unless you put a sensor there. LoL... Expand I dunno what car TS is driving, my lau pok chia is mechanic one. hahha. Link to post Share on other sites More sharing options...
Beregond Supersonic April 8, 2021 Share April 8, 2021 On 4/8/2021 at 1:51 AM, Bluepica said: an a year, if I send my car for them to fix this only item, will they entertain me? or if not, which workshop should I go to? Expand why not if u are a paying customer?? u talking about claiming warrently for free repair??? if your car is new and within warrently. even if u miss servicing, what does engine oil got to do with the boot not opening??? no reason cannot also 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic April 8, 2021 Share April 8, 2021 On 4/8/2021 at 2:45 AM, Beregond said: why not if u are a paying customer?? u talking about claiming warrently for free repair??? if your car is new and within warrently. even if u miss servicing, what does engine oil got to do with the boot not opening??? no reason cannot also Expand He scared ppl boh hue him becos he did not go back to them for servicing. 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic April 8, 2021 Share April 8, 2021 That's exactly the reason I go back to AD till my warranty expire. While I pay more for servicing, there is also the element of insurance that it covers all the nitty gritty or expensive non wear and tear stuffs on the car. Eg . Air con system. 3 Link to post Share on other sites More sharing options...
Kopites Supersonic April 8, 2021 Share April 8, 2021 On 4/8/2021 at 2:59 AM, Hamburger said: That's exactly the reason I go back to AD till my warranty expire. While I pay more for servicing, there is also the element of insurance that it covers all the nitty gritty or expensive non wear and tear stuffs on the car. Eg . Air con system. Expand Generally speaking things only start to break down after the expire of warranty.😟 Link to post Share on other sites More sharing options...
Hamburger Hypersonic April 8, 2021 Share April 8, 2021 On 4/8/2021 at 4:38 AM, Kopites said: Generally speaking things only start to break down after the expire of warranty.😟 Expand If unlucky might kana. Me car 1st owner told me the air con compressor was changed on the 2nd year. Foc of course. So all depends on luck I guess. Link to post Share on other sites More sharing options...
Bluepica 4th Gear April 8, 2021 Author Share April 8, 2021 @Watwheels can fold but release knob is inside boot... boot still can open with key remote control lo... just that the mechanic lever can pull but the boot not release... suspect something wrong along the mechanic cable. Link to post Share on other sites More sharing options...
Volvobrick Supersonic April 8, 2021 Share April 8, 2021 On 4/8/2021 at 3:38 PM, Bluepica said: @Watwheels can fold but release knob is inside boot... boot still can open with key remote control lo... just that the mechanic lever can pull but the boot not release... suspect something wrong along the mechanic cable. Expand Just strip out the trim in the trunk to check if the end of the cable moves. Could be like bicycle brakes/gear cables, need adjustments after some time. 1 Link to post Share on other sites More sharing options...
Fitvip Supersonic April 9, 2021 Share April 9, 2021 I think it could be due to the cable connecting to the hook comes loose. So, when you pull the lever, the hook is not released! Link to post Share on other sites More sharing options...
Bluepica 4th Gear May 6, 2021 Author Share May 6, 2021 @Fitvip the trunk light also not turn on... not the bulb blown because occasionally it will turn on... i can't find the trunk light activator switch... btw I'm driving a kia cerato K3 Link to post Share on other sites More sharing options...
Jamesc Hypersonic May 6, 2021 Share May 6, 2021 Wah loyal Kia customer. From Picanto to Cerato and next time Stinger. 2 Link to post Share on other sites More sharing options...
Bluepica 4th Gear May 6, 2021 Author Share May 6, 2021 @Jamesc no lei, in between got Hyundai Avante.... ok la, maybe Korean fan 🤣 1 Link to post Share on other sites More sharing options...
Fitvip Supersonic May 6, 2021 Share May 6, 2021 On 5/6/2021 at 5:17 AM, Bluepica said: @Fitvip the trunk light also not turn on... not the bulb blown because occasionally it will turn on... i can't find the trunk light activator switch... btw I'm driving a kia cerato K3 Expand Your truck cable release problem is still not solved? I am not familiar with Cerato's cable set up. Can't figure out how the trunk light is activated. ↡ Advertisement Link to post Share on other sites More sharing options...
What car will you buy with a budget price of $130000
Hyundai Elantra or Kia Cerato
Hi brothers, anyone has comments on KIA Cerato
MOD:why so many K3 topics? combine into 1?
Kia Cerato 2013
Kia Cerato 2013
