Shouyi 3rd Gear March 27, 2021 Share March 27, 2021 Hi, wonder if any bros encounter this problem before. My stock tire size is 205/45 R18. I asked some prominent shops and come to the conclusion that this size is not available in Singapore. What are the options available when the time comes for replacement. I have no intention to change the rims.Thks. ↡ Advertisement Link to post Share on other sites More sharing options...
Ct3833 Supersonic March 27, 2021 Share March 27, 2021 On 3/27/2021 at 1:51 AM, Shouyi said: Hi, wonder if any bros encounter this problem before. My stock tire size is 205/45 R18. I asked some prominent shops and come to the conclusion that this size is not available in Singapore. What are the options available when the time comes for replacement. I have no intention to change the rims.Thks. Expand Hi , your agent should have the tires for you, unless your car is PI. 215/45/R18 might be available, the size difference is only 1% 5 Link to post Share on other sites More sharing options...
Mahjong74 Supercharged March 27, 2021 Share March 27, 2021 (edited) On 3/27/2021 at 1:51 AM, Shouyi said: Hi, wonder if any bros encounter this problem before. My stock tire size is 205/45 R18. I asked some prominent shops and come to the conclusion that this size is not available in Singapore. What are the options available when the time comes for replacement. I have no intention to change the rims.Thks. Expand @Shouyi https://www.tyrepac.com/tyres/detail/48734 for 205/45 R18 https://www.lazada.sg/products/michelin-pilot-sport-4-made-in-europe-price-include-islandwide-delivery-and-installation-various-sizes-available-under-variation-click-and-select-yours-now-i889372275-s3080874887.html? for 205/40 R18 Edited March 27, 2021 by Mahjong74 5 Link to post Share on other sites More sharing options...
Beanoyip Turbocharged March 27, 2021 Share March 27, 2021 Change rim to suit the tyre.. 1 3 Link to post Share on other sites More sharing options...
inlinesix Hypersonic March 27, 2021 Share March 27, 2021 My tyre 205/45 17 rare in Singapore. Still can be found. Link to post Share on other sites More sharing options...
mersaylee Hypersonic March 27, 2021 Share March 27, 2021 Change car😁 9 Link to post Share on other sites More sharing options...
Mkl22 Supersonic March 27, 2021 Share March 27, 2021 On 3/27/2021 at 2:46 AM, inlinesix said: My tyre 205/45 17 rare in Singapore. Still can be found. Expand Yours relatively common. 205/45/18 is super rare. Never heard of it till now. 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator March 27, 2021 Share March 27, 2021 On 3/27/2021 at 1:51 AM, Shouyi said: Hi, wonder if any bros encounter this problem before. My stock tire size is 205/45 R18. I asked some prominent shops and come to the conclusion that this size is not available in Singapore. What are the options available when the time comes for replacement. I have no intention to change the rims.Thks. Expand On 3/27/2021 at 2:11 AM, Ct3833 said: Hi , your agent should have the tires for you, unless your car is PI. 215/45/R18 might be available, the size difference is only 1% Expand Yeah. can just upsize to 214/45/18. the rim still can fit one. if not yah. Change rim. You are driving the car, not the car drives you (nuts)! 2 5 Link to post Share on other sites More sharing options...
Hamburger Hypersonic March 27, 2021 Share March 27, 2021 No poison please... Behave boys. 🤭 6 Link to post Share on other sites More sharing options...
Cephas 3rd Gear March 27, 2021 Share March 27, 2021 17x8.5j 5x112pcd rim also quite hard to find... Link to post Share on other sites More sharing options...
Watwheels Supersonic March 27, 2021 Share March 27, 2021 Use an online wheel size calculator to compare size to see what is closest to the original size. http://www.wheelcalc.com/ The important dimension to note is the overall wheel diameter. The alternative would be assuming you want to stay at 18" rims. Your original wheel diameter is 620.1mm 1) 215/40 R18 -1.5%(diff between this size and original, will be slightly smaller in diameter.) Diameter 610.5mm 2) 215/45 R18 +1.9% (slightly bigger) Diameter 632.2mm FYI the differences are insignificant for you to feel any difference. Speedometer accuracy wise I also dont think there will be much of a diff. Anyway for your original after wear and tear the diameter will become smaller and smaller as you drive. Ppl will tend to take the slightly bigger diameter size. 3 Link to post Share on other sites More sharing options...
Mkl22 Supersonic March 27, 2021 Share March 27, 2021 I wonder what car. Anyone? Link to post Share on other sites More sharing options...
Roberttan 5th Gear March 27, 2021 Share March 27, 2021 On 3/27/2021 at 1:51 AM, Shouyi said: Hi, wonder if any bros encounter this problem before. My stock tire size is 205/45 R18. I asked some prominent shops and come to the conclusion that this size is not available in Singapore. What are the options available when the time comes for replacement. I have no intention to change the rims.Thks. Expand CAN SHARE what car is that using this size? Link to post Share on other sites More sharing options...
Shouyi 3rd Gear March 27, 2021 Author Share March 27, 2021 (edited) Scala Style On 3/27/2021 at 4:31 AM, Roberttan said: CAN SHARE what car is that using this size? Expand Edited March 27, 2021 by Shouyi 1 Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic March 27, 2021 Share March 27, 2021 Change rim la bro. Change to 18 looks nicer Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged March 27, 2021 Share March 27, 2021 On 3/27/2021 at 4:37 AM, Shouyi said: Scala Style Expand Skoda Scala Style? New car wor.. change tires so fast? Use first blah.. 1 Link to post Share on other sites More sharing options...
BanCoe Hypersonic March 27, 2021 Share March 27, 2021 On 3/27/2021 at 4:37 AM, Shouyi said: Scala Style Expand How old your car or rather how much mileage clocked ........ strange that the Agent brings in a car with odd tires spec Link to post Share on other sites More sharing options...
Shouyi 3rd Gear March 27, 2021 Author Share March 27, 2021 On 3/27/2021 at 5:29 AM, Ody_2004 said: Skoda Scala Style? New car wor.. change tires so fast? Use first blah.. Expand Ya. Use first. But 3 yrs down the road, need to find replacement mah. ↡ Advertisement Link to post Share on other sites More sharing options...
Portable Tyre Pump
Portable Tyre Pump
Tyre puncture
Tyre puncture
Continental CSC 7.
Continental CSC 7.
