Saj 1st Gear December 16, 2020 Share December 16, 2020 My Avante 1.6 (2008 model) has been great and no major issues so far. However, it gives me headache when each time I go to petrol station. As shown in the pic, the white color plastic sleeve inside the fuel pump is sunken (moved inside) over the years. Therefore, need to pump petrol manually. Meaning we cannot lock the nozzle and let the tank fill automatically. Instead have to manually half-press the fuel nozzle handle and hold it to slowly fill the tank. It takes almost 12-15min to fill the tank fully. This is very troublesome. The technician in the workshop pulled the plastic sleeve up a bit, but next day it went back again. Anyone has seen similar issue before and managed to fix? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
1fast1 Supersonic December 16, 2020 Share December 16, 2020 (edited) This is the first time I've seen Koro on a car. 😂😂😂 Kor-ean car some more. 🤣🤣🤣 Edited December 16, 2020 by Turboflat4 Link to post Share on other sites More sharing options...
Watwheels Supersonic December 16, 2020 Share December 16, 2020 Where is the seat suppose to be? At the entry? Something must have gave way and went in there. Just hold the refueling nozzle lo. What to do? Link to post Share on other sites More sharing options...
Count-Bracula Twincharged December 16, 2020 Share December 16, 2020 Buy a funnel. 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic December 16, 2020 Share December 16, 2020 You poke too hard lah. Must be more steady when pumping. 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic December 16, 2020 Share December 16, 2020 Korean famous for plastic. Must be more gentle when poke poke. Link to post Share on other sites More sharing options...
Mooose 6th Gear December 16, 2020 Share December 16, 2020 1 hour ago, Saj said: My Avante 1.6 (2008 model) has been great and no major issues so far. However, it gives me headache when each time I go to petrol station. As shown in the pic, the white color plastic sleeve inside the fuel pump is sunken (moved inside) over the years. Therefore, need to pump petrol manually. Meaning we cannot lock the nozzle and let the tank fill automatically. Instead have to manually half-press the fuel nozzle handle and hold it to slowly fill the tank. It takes almost 12-15min to fill the tank fully. This is very troublesome. The technician in the workshop pulled the plastic sleeve up a bit, but next day it went back again. Anyone has seen similar issue before and managed to fix? sorry, i am trying to understand the issue .. because of the movement of the piece you say that you cannot lock the nozzle and let the tank fill automatically, but you can manually half press the nozzle handle and fill .. are they not separate? lock the nozzle need not be full - can lock half way too if i remember correctly - why not press half and lock and let the tank fill automatically? or still cannot? if cannot then how do you manually press half and fill? locking mechanism is on the filler nozzle and not your fuel tank .. anyway doesnt seem like a big problem - car is 12 years old, if you intend to keep it till 20 and it irritates you i am sure there is a way to fix it - just a question of how much it costs otherwise if too expensive, then just live with it, Link to post Share on other sites More sharing options...
Kb27 Supersonic December 16, 2020 Share December 16, 2020 replace the plastic sleeve, simple. 1 Link to post Share on other sites More sharing options...
Kklee 6th Gear December 16, 2020 Share December 16, 2020 3 hours ago, Saj said: My Avante 1.6 (2008 model) has been great and no major issues so far. However, it gives me headache when each time I go to petrol station. As shown in the pic, the white color plastic sleeve inside the fuel pump is sunken (moved inside) over the years. Therefore, need to pump petrol manually. Meaning we cannot lock the nozzle and let the tank fill automatically. Instead have to manually half-press the fuel nozzle handle and hold it to slowly fill the tank. It takes almost 12-15min to fill the tank fully. This is very troublesome. The technician in the workshop pulled the plastic sleeve up a bit, but next day it went back again. Anyone has seen similar issue before and managed to fix? IMHO. IIRC, the amount of petrol can be preset. If you pump 3/4 tank base on the fuel gauge marking, it should not be an issue. E.g. when the fuel gauge reach 1/4 mark, you pump $x of petrol. While auto-stop works most of the time for me, there are instances it will fail. Link to post Share on other sites More sharing options...
Mkl22 Supersonic December 16, 2020 Share December 16, 2020 Move the plastic sleeve and cut it off then. It’s probably there to prevent pumping diesel as diesel nozzles are bigger. Link to post Share on other sites More sharing options...
Watwheels Supersonic December 16, 2020 Share December 16, 2020 (edited) What TS wants is to go hands-free. Like this. But because the plastic nozzle seat had sunken in hence he has to hold the nozzle when refueling. Whoa piangz. Is that really so difficult to understand? Forgive these ppl, perhaps some have never in their driving life touch the refueling nozzle before. Anyway I thought pump attendant does it for you. Why worry? Edited December 16, 2020 by Watwheels 2 2 Link to post Share on other sites More sharing options...
Contipro 5th Gear December 16, 2020 Share December 16, 2020 5 hours ago, Saj said: My Avante 1.6 (2008 model) has been great and no major issues so far. However, it gives me headache when each time I go to petrol station. As shown in the pic, the white color plastic sleeve inside the fuel pump is sunken (moved inside) over the years. Therefore, need to pump petrol manually. Meaning we cannot lock the nozzle and let the tank fill automatically. Instead have to manually half-press the fuel nozzle handle and hold it to slowly fill the tank. It takes almost 12-15min to fill the tank fully. This is very troublesome. The technician in the workshop pulled the plastic sleeve up a bit, but next day it went back again. Anyone has seen similar issue before and managed to fix? need to find some photo of original condition, then I think only the bro can understand and help. Link to post Share on other sites More sharing options...
Alg 5th Gear December 16, 2020 Share December 16, 2020 12-15mins means really really low flowrate leh, i think even a S300 max need only 5mins. Link to post Share on other sites More sharing options...
Saj 1st Gear December 17, 2020 Author Share December 17, 2020 19 hours ago, Mooose said: sorry, i am trying to understand the issue .. because of the movement of the piece you say that you cannot lock the nozzle and let the tank fill automatically, but you can manually half press the nozzle handle and fill .. are they not separate? lock the nozzle need not be full - can lock half way too if i remember correctly - why not press half and lock and let the tank fill automatically? or still cannot? if cannot then how do you manually press half and fill? locking mechanism is on the filler nozzle and not your fuel tank .. anyway doesnt seem like a big problem - car is 12 years old, if you intend to keep it till 20 and it irritates you i am sure there is a way to fix it - just a question of how much it costs otherwise if too expensive, then just live with it, Even the lowest notch of the refilling nozzle does not work as the refilling stops in a second. That's the reason I have to manually press slightly and keep holding it for 12-15min. That's painful. It's hard to find the 'sweet spot' as the refilling keep stopping and you have to adjust the nozzle is different angles and adjust the manual pressure trial and error because each nozzle behaves differently. You need to try this to understand how trouble this is. I pump 3 full tanks per week (stared Private Hire recently). That means spending nearly 45min at the pump holding the nozzle! Yes, the cars is 12 years old, but it looks and works like a 5 year old car without any fuss and just 65K millage 🙂 and intend to use it for many more years. My current work shop has never experienced this type of issue before. Komoco is asking $75 for just to check (not sure how much for fixing). Pump attendants say this is a common issue. I was hoping someone in this forum may have experienced this before. Link to post Share on other sites More sharing options...
Saj 1st Gear December 17, 2020 Author Share December 17, 2020 17 hours ago, Watwheels said: What TS wants is to go hands-free. Like this. But because the plastic nozzle seat had sunken in hence he has to hold the nozzle when refueling. Whoa piangz. Is that really so difficult to understand? Forgive these ppl, perhaps some have never in their driving life touch the refueling nozzle before. Anyway I thought pump attendant does it for you. Why worry? Most pump attendants hate this as the refilling stops several times automatically during the process and they have to re-adjust and keep pressing half-way. When they are too frustrated, I would volunteer to take over. So far I have seen only 2 attendants who have the patience to pump without complaining 🙂 Link to post Share on other sites More sharing options...
Jamesc Hypersonic December 17, 2020 Share December 17, 2020 18 hours ago, Kb27 said: replace the plastic sleeve, simple. So simple hor poke too hard plastic break put new one lah. 1 Link to post Share on other sites More sharing options...
Saj 1st Gear December 17, 2020 Author Share December 17, 2020 18 hours ago, Kklee said: IMHO. IIRC, the amount of petrol can be preset. If you pump 3/4 tank base on the fuel gauge marking, it should not be an issue. E.g. when the fuel gauge reach 1/4 mark, you pump $x of petrol. While auto-stop works most of the time for me, there are instances it will fail. I think you didn't quite get the issue here. Even with an empty tank, the issue starts the moment you enter the nozzle. Press the lever - pumping stops in 2 seconds or sometimes petrol throws out. Link to post Share on other sites More sharing options...
Saj 1st Gear December 17, 2020 Author Share December 17, 2020 21 hours ago, Watwheels said: Where is the seat suppose to be? At the entry? Something must have gave way and went in there. Just hold the refueling nozzle lo. What to do? The sleeve supposed to be at the entry, I guess. Probably the screw that holds it in the position has given away or something. It is not just holding the nozzle. But also pressing the leaver at the right 'sweet spot', exerting right pressure and each time the pumping stops, re-adjusting and keep trying 😞 ↡ Advertisement Link to post Share on other sites More sharing options...
Where to mod fuel needle?
Coolant level going down
2016 Hyundai Elantra / Avante
