Kb27 Supersonic March 11, 2022 Share March 11, 2022 8 hours ago, Lala81 said: To me as a layman. Kb27's video is clearer to understand. More theory based. I'm also a layman, although I've a bit more electrical knowledge. It's not really that hard to learn. The video seems to suggest in UK, they like to split the load into 2 RCCB, it's probably a better technique. In hdb flat, it's only 1 RCCB which handles all the load. One thing the video didn't mention is the wire size. Obviously, if you connecting a MCB with 25/30A, you need a bigger wire. Those lightings that connect to a 6A MCB only needs a thinner wire, but thicker is ok, if laying the same wires is more convenient. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
JanM 2nd Gear March 11, 2022 Share March 11, 2022 33 minutes ago, Kb27 said: I'm also a layman, although I've a bit more electrical knowledge. It's not really that hard to learn. The video seems to suggest in UK, they like to split the load into 2 RCCB, it's probably a better technique. In hdb flat, it's only 1 RCCB which handles all the load. One thing the video didn't mention is the wire size. Obviously, if you connecting a MCB with 25/30A, you need a bigger wire. Those lightings that connect to a 6A MCB only needs a thinner wire, but thicker is ok, if laying the same wires is more convenient. Their houses are larger. I saw another Youtube video somewhere where they say one is for downstairs and the other for upstairs. 2 Link to post Share on other sites More sharing options...
Ahwhye 6th Gear March 12, 2022 Share March 12, 2022 On 3/10/2022 at 10:58 AM, Mrmilktooth said: In old Chinese movies, when electrified there is a blue coloured lightning current passing through the person. irl no such thing. It’s just very very unfortunate that the family gone like that… 😵😭 Sigh… better wear shoes in showering from now on. wet shoes offer no protection, can still conduct electricity somewhat.. Link to post Share on other sites More sharing options...
Mrmilktooth Supercharged March 12, 2022 Share March 12, 2022 1 hour ago, Ahwhye said: wet shoes offer no protection, can still conduct electricity somewhat.. Rubber should be ok. Won’t conduct electrocity Link to post Share on other sites More sharing options...
Ahwhye 6th Gear March 12, 2022 Share March 12, 2022 32 minutes ago, Mrmilktooth said: Rubber should be ok. Won’t conduct electrocity don't give yourself the false sense of safety leh..... dry one may be not, but wet rubber shoes still conduct.... there are even certain types of rubber that can conduct electricity hor..... 2 Link to post Share on other sites More sharing options...
Ender Hypersonic March 12, 2022 Share March 12, 2022 (edited) https://www.channelnewsasia.com/singapore/water-heater-safety-electrocution-deaths-lakeside-experts-2558816 Electrocution deaths: Experts urge people to check their water heaters regularly SINGAPORE: People should check their water heaters regularly and make sure it is not using a three-pin plug, experts said. This comes after an elderly couple and their son died in a flat in Jurong Lakeside in December 2020 after being electrocuted because the cables in the plug supplying power to their instant water heater fused together. The flat’s heater was powered by a three-pin plug connected to an extension outlet, which was in turn connected to a power outlet in the kitchen, said an Energy Market Authority engineer who testified during a coroner's inquiry. When the plug to the water heater was opened after the incident, the cables inside were “badly burnt” and the earth cable and neutral cable had fused together. The engineer said that the cables fused because they were overloaded. The plug had a 13-amp fuse but the maximum current when the water heater was operating was more than 14 amps. CNA spoke to experts about how you can ensure your water heater is safe. Water heaters should be connected to a switch for water heaters, not a three-pin plug Electricians and engineers CNA spoke to said a three-pin plug cannot support loads higher than 13 amps, and currents for water heaters are larger than that. Instead, water heaters should be connected with a switch meant for water heaters. These are usually ones with indicator lights when they are turned on. Mr Benetton Chan, director of electrical and plumbing services company Sparkflow, said it is still common to see three-pin plugs used for water heaters in some homes. Many homeowners have been using water heaters with this setup for more than 10 years with no incidents, he added. “The plug itself supports up to 13 amps. The heater uses, let’s say 14 amps. That means the plug itself will have to work even harder to fulfil that 14 amps, but the limit for that plug is only 13 amps. It gets hot because it works even harder, and that’s why the wire burns,” he explained. "The regulation has always been to use a heater switch." If the water heater has already been installed wrongly, homeowners should call an electrician to change the wiring, he stressed. “We will have to run a new set of wires from the main circuit breaker, all the way to the toilet,” said Mr Chan. His team usually charges about S$100 to S$200 for this, depending on the distance, he added. Look out for other changes to the water heater that might indicate electrical damage Connection points are the “most common places” that start to heat up when water heaters run into issues, said Mr Wang Gucheng, senior manager of the clean energy research centre at Temasek Polytechnic’s School of Engineering. People who notice a burnt smell should call a professional electrician, experts said. If the switches start to turn black, this could be a “telltale sign” that the wires are burnt or about to start burning, said Mr Chan. They should also contact an electrician if any part of the water heater or switch feels unexpectedly hot, said Mr Wang. Buy water heaters with the Safety Mark and a leakage detection protection function Experts stressed that people should make sure that the water heater they buy should have the SG Safety Mark. “Some water heaters have a leakage detection protection function. If you purchase that one, there is a test button that allows you to test that function. Test the protection function regularly,” said Mr Wang. A normal water heater may last between eight and 12 years, he added. If the water heater becomes old, homeowners should get professional electricians to check on the condition of their appliances. A typical water heater has a warranty of up to five years, said Mr Chan. “As long as it crosses the warranty period, it’s better to check already. I think that’s the safest way,” he added. Installation of a water heater should be carried out by a licensed electrician Mr Chan and his team have also encountered people who have tried to install their own water heaters, even though they do not have the appropriate electrical work licences. “They think it’s not working, then they call us. They complain that it is the heater’s problem. In fact, it is their installation that is incorrect,” he said. When hiring an electrician to install a water heater, homeowners can ask the worker to show them their licence card. The card should have their photograph, their name, identity card number and licence number, said Mr Wang. These electricians have been trained to ensure that the wiring is done correctly and safely. They also have professional equipment that can detect any potential risks in the current wiring or connection, he added. Mr Chan also advised homeowners to have a professional electrician check their water heaters “every once in a while”. “There are a few things you have to check. First is if the wires are still intact or not, if there’s any sign of burnt wires. Also the switches – switches could burn as well, depending on how the previous installer tied the wires, or ... the quality of the wires,” he said. “All these things will not happen suddenly. It will slowly build up, so (it's) better to get an engineer to check for you.” It can be difficult for people without a proper electrician licence to check on the status of the water heater and the wiring, he noted. “You don’t know what’s inside ... unless you open up everything,” said Mr Chan, adding that he has seen instances of correct wires being used in the visible parts near the switches, but the wrong wires used in the parts that are not exposed. “There will be instances like that, so first thing ... is to get a proper electrician to do all the wiring.” Check your earth leakage circuit breaker or residual current circuit breaker in your distribution board box Homeowners should also check regularly that their earth leakage circuit breakers or residual current circuit breakers are working properly, experts said. In the Jurong Lakeside flat incident, the engineer who testified in court said that the household’s electrical circuit comprised two wiring systems: An older system installed in 1971, and a newer system installed when the flat underwent the Housing and Development Board’s (HDB) Main Upgrading Programme completed in 2003. As part of the HDB upgrading, a residual current circuit breaker (RCCB) was installed for the newer wiring system. The RCCB would trip the system and cut off the current when an earth leakage was detected. The water heater drew electricity from the older wiring system, which was not protected by the RCCB as there was no such requirement at the time the system was installed, he told the inquiry. He said that if the RCCB had been installed in such a way that it protected the household’s entire circuitry, it would have detected the earth leakage during the incident, tripped and cut off the current. Homeowners should ensure that there is an RCCB in their house’s distribution box. They can ask a licensed electrician to teach them how to test it regularly to make sure that it is working, said Mr Wang. If the earth leakage circuit breaker or RCCB is working correctly, it will trip during the test, and all the electricity in the house will immediately shut off, said Mr Chan. If the electricity does not shut off, something is wrong, and homeowners should call a professional electrician for help, he added. What to do if electrocution occurs at home Beyond checking the water heater and its components, homeowners can wear slippers when they are showering to reduce the risk of getting electrocuted, said Mr Wang. They should also stop using the water heater if they feel any tingling sensation when using it, he added. “When you’re electrocuted, you don’t have the time to react,” stressed Mr Chan. In the Jurong Lakeside case, one of the deceased was holding onto a metallic water hose and not wearing any shoes as he was taking a shower. This caused the man to be electrocuted, said the engineer at the coroner's inquiry. His wife died after she went into the bathroom to help her husband. Water was still flowing from the shower head when their son arrived to check on them. Upon seeing his parents on the floor, he ran to them, and then collapsed and fell on his mother’s body. If someone at home gets electrocuted, family members should immediately cut off the main power supply using the distribution box, said Mr Chan. “Do not try to touch the person if he or she has been electrocuted,” said Mr Wang. Source: CNA/hw(mi) Edited March 12, 2022 by Ender 5 Link to post Share on other sites More sharing options...
Kb27 Supersonic March 12, 2022 Share March 12, 2022 Sad case of electrocution via water heater, but it should jolt us to have a closer look at what we have. My storage heater use a "water heater" switch, 20A. Theoretically, it can handle a 4kW heater. Maybe you shouldn't be using such a high powered heater, just bcuz it can heat up the water faster. Plugging in an instant water heater to a 13A socket seems like a "normal" practice no one thinks much about, It's cheaper this way of cuz, without running a separate set of wires from the breaker, and who don't want cheap ? (until tragedy struck) But anything in-between the breaker to the water heater (switches, connection points), also must be able to handle that large current. Again, not many thinks much about it. Fixing an isolator would be a better idea, I think. 5 Link to post Share on other sites More sharing options...
Windwaver Turbocharged March 12, 2022 Share March 12, 2022 I use gas water heater (close to 20 years), cheaper and safer. 2 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic March 13, 2022 Share March 13, 2022 18 hours ago, Ender said: https://www.channelnewsasia.com/singapore/water-heater-safety-electrocution-deaths-lakeside-experts-2558816 Electrocution deaths: Experts urge people to check their water heaters regularly SINGAPORE: People should check their water heaters regularly and make sure it is not using a three-pin plug, experts said. This comes after an elderly couple and their son died in a flat in Jurong Lakeside in December 2020 after being electrocuted because the cables in the plug supplying power to their instant water heater fused together. The flat’s heater was powered by a three-pin plug connected to an extension outlet, which was in turn connected to a power outlet in the kitchen, said an Energy Market Authority engineer who testified during a coroner's inquiry. When the plug to the water heater was opened after the incident, the cables inside were “badly burnt” and the earth cable and neutral cable had fused together. The engineer said that the cables fused because they were overloaded. The plug had a 13-amp fuse but the maximum current when the water heater was operating was more than 14 amps. CNA spoke to experts about how you can ensure your water heater is safe. Water heaters should be connected to a switch for water heaters, not a three-pin plug Electricians and engineers CNA spoke to said a three-pin plug cannot support loads higher than 13 amps, and currents for water heaters are larger than that. Instead, water heaters should be connected with a switch meant for water heaters. These are usually ones with indicator lights when they are turned on. Mr Benetton Chan, director of electrical and plumbing services company Sparkflow, said it is still common to see three-pin plugs used for water heaters in some homes. Many homeowners have been using water heaters with this setup for more than 10 years with no incidents, he added. “The plug itself supports up to 13 amps. The heater uses, let’s say 14 amps. That means the plug itself will have to work even harder to fulfil that 14 amps, but the limit for that plug is only 13 amps. It gets hot because it works even harder, and that’s why the wire burns,” he explained. "The regulation has always been to use a heater switch." If the water heater has already been installed wrongly, homeowners should call an electrician to change the wiring, he stressed. “We will have to run a new set of wires from the main circuit breaker, all the way to the toilet,” said Mr Chan. His team usually charges about S$100 to S$200 for this, depending on the distance, he added. Look out for other changes to the water heater that might indicate electrical damage Connection points are the “most common places” that start to heat up when water heaters run into issues, said Mr Wang Gucheng, senior manager of the clean energy research centre at Temasek Polytechnic’s School of Engineering. People who notice a burnt smell should call a professional electrician, experts said. If the switches start to turn black, this could be a “telltale sign” that the wires are burnt or about to start burning, said Mr Chan. They should also contact an electrician if any part of the water heater or switch feels unexpectedly hot, said Mr Wang. Buy water heaters with the Safety Mark and a leakage detection protection function Experts stressed that people should make sure that the water heater they buy should have the SG Safety Mark. “Some water heaters have a leakage detection protection function. If you purchase that one, there is a test button that allows you to test that function. Test the protection function regularly,” said Mr Wang. A normal water heater may last between eight and 12 years, he added. If the water heater becomes old, homeowners should get professional electricians to check on the condition of their appliances. A typical water heater has a warranty of up to five years, said Mr Chan. “As long as it crosses the warranty period, it’s better to check already. I think that’s the safest way,” he added. Installation of a water heater should be carried out by a licensed electrician Mr Chan and his team have also encountered people who have tried to install their own water heaters, even though they do not have the appropriate electrical work licences. “They think it’s not working, then they call us. They complain that it is the heater’s problem. In fact, it is their installation that is incorrect,” he said. When hiring an electrician to install a water heater, homeowners can ask the worker to show them their licence card. The card should have their photograph, their name, identity card number and licence number, said Mr Wang. These electricians have been trained to ensure that the wiring is done correctly and safely. They also have professional equipment that can detect any potential risks in the current wiring or connection, he added. Mr Chan also advised homeowners to have a professional electrician check their water heaters “every once in a while”. “There are a few things you have to check. First is if the wires are still intact or not, if there’s any sign of burnt wires. Also the switches – switches could burn as well, depending on how the previous installer tied the wires, or ... the quality of the wires,” he said. “All these things will not happen suddenly. It will slowly build up, so (it's) better to get an engineer to check for you.” It can be difficult for people without a proper electrician licence to check on the status of the water heater and the wiring, he noted. “You don’t know what’s inside ... unless you open up everything,” said Mr Chan, adding that he has seen instances of correct wires being used in the visible parts near the switches, but the wrong wires used in the parts that are not exposed. “There will be instances like that, so first thing ... is to get a proper electrician to do all the wiring.” Check your earth leakage circuit breaker or residual current circuit breaker in your distribution board box Homeowners should also check regularly that their earth leakage circuit breakers or residual current circuit breakers are working properly, experts said. In the Jurong Lakeside flat incident, the engineer who testified in court said that the household’s electrical circuit comprised two wiring systems: An older system installed in 1971, and a newer system installed when the flat underwent the Housing and Development Board’s (HDB) Main Upgrading Programme completed in 2003. As part of the HDB upgrading, a residual current circuit breaker (RCCB) was installed for the newer wiring system. The RCCB would trip the system and cut off the current when an earth leakage was detected. The water heater drew electricity from the older wiring system, which was not protected by the RCCB as there was no such requirement at the time the system was installed, he told the inquiry. He said that if the RCCB had been installed in such a way that it protected the household’s entire circuitry, it would have detected the earth leakage during the incident, tripped and cut off the current. Homeowners should ensure that there is an RCCB in their house’s distribution box. They can ask a licensed electrician to teach them how to test it regularly to make sure that it is working, said Mr Wang. If the earth leakage circuit breaker or RCCB is working correctly, it will trip during the test, and all the electricity in the house will immediately shut off, said Mr Chan. If the electricity does not shut off, something is wrong, and homeowners should call a professional electrician for help, he added. What to do if electrocution occurs at home Beyond checking the water heater and its components, homeowners can wear slippers when they are showering to reduce the risk of getting electrocuted, said Mr Wang. They should also stop using the water heater if they feel any tingling sensation when using it, he added. “When you’re electrocuted, you don’t have the time to react,” stressed Mr Chan. In the Jurong Lakeside case, one of the deceased was holding onto a metallic water hose and not wearing any shoes as he was taking a shower. This caused the man to be electrocuted, said the engineer at the coroner's inquiry. His wife died after she went into the bathroom to help her husband. Water was still flowing from the shower head when their son arrived to check on them. Upon seeing his parents on the floor, he ran to them, and then collapsed and fell on his mother’s body. If someone at home gets electrocuted, family members should immediately cut off the main power supply using the distribution box, said Mr Chan. “Do not try to touch the person if he or she has been electrocuted,” said Mr Wang. Source: CNA/hw(mi) Anyone engaged this company Sparkflow before? Link to post Share on other sites More sharing options...
Jellandross Supersonic March 17, 2022 Share March 17, 2022 2 Link to post Share on other sites More sharing options...
Ender Hypersonic January 16, 2023 Share January 16, 2023 How safe is your water heater? 7 1 Link to post Share on other sites More sharing options...
13177 Hypersonic January 17, 2023 Share January 17, 2023 5 hours ago, Ender said: How safe is your water heater? Best is to go back to the good old days using water directly from the tap. And if want hot water, just boil using kettle and then pour into the bucket and shower. 😂 3 Link to post Share on other sites More sharing options...
Kb27 Supersonic January 17, 2023 Share January 17, 2023 Recently my RCCB tripped in the middle of the night at 4am. Damn..I had to wake up, half groggy and find out where is the culprit. It's a good thing it worked, but I had the awful job of isolating which circuit is causing the problem. Internal to the house is one RCCB. External is another RCCB, which belongs to the authorities. Sometimes the external RCCB also tripped. You have to check both. So I started troubleshooting by shutting down all the MCBs (individual miniature circuit breakers), then turn each one on, one at a time, until I find the MCB that is causing the problem, and tripped the RCCB. RCCB is like the master and the MCBs are the slaves. Only the RCCB detects leakage current, the MCB does not. Leakage current is caused by a live or neutral wire with compromised insulation, leaking a very small amount of current to the earth. RCCB detects this, and tripped. So I determined MCB no. 4 is causing the problem, I went around to find out which power sockets run off MCB 4. I had earlier labelled every power outlet with a number that correspond to the MCB. So it was easy to find the power sockets causing the problem was in the kitchen. Without the labelling, I would have to hunt around the whole house, bedrooms, living rooms, etc. So the kitchen was it, I then further isolate the appliance which happens to be a rice cooker. After removing it, I can turn back the RCCB and go back to sleep. My point is, when the circuits are in normal condition, use the MCB and find out which power sockets belong to which MCB. Then label on the socket and the corresponding MCB with a number or identifier. So when the ELCB or RCCB decides to trip, esp. in the middle of night (for no reason), it will make your loss of electricity much less harrowing. 😀 If the culprit was the water heater, at least you can shut it down, until you get it fixed, but still be able to use electricity in the meantime. 14 Link to post Share on other sites More sharing options...
Victor68 Turbocharged January 17, 2023 Share January 17, 2023 13 minutes ago, Kb27 said: Recently my RCCB tripped in the middle of the night at 4am. Damn..I had to wake up, half groggy and find out where is the culprit. It's a good thing it worked, but I had the awful job of isolating which circuit is causing the problem. Internal to the house is one RCCB. External is another RCCB, which belongs to the authorities. Sometimes the external RCCB also tripped. You have to check both. So I started troubleshooting by shutting down all the MCBs (individual miniature circuit breakers), then turn each one on, one at a time, until I find the MCB that is causing the problem, and tripped the RCCB. RCCB is like the master and the MCBs are the slaves. Only the RCCB detects leakage current, the MCB does not. Leakage current is caused by a live or neutral wire with compromised insulation, leaking a very small amount of current to the earth. RCCB detects this, and tripped. So I determined MCB no. 4 is causing the problem, I went around to find out which power sockets run off MCB 4. I had earlier labelled every power outlet with a number that correspond to the MCB. So it was easy to find the power sockets causing the problem was in the kitchen. Without the labelling, I would have to hunt around the whole house, bedrooms, living rooms, etc. So the kitchen was it, I then further isolate the appliance which happens to be a rice cooker. After removing it, I can turn back the RCCB and go back to sleep. My point is, when the circuits are in normal condition, use the MCB and find out which power sockets belong to which MCB. Then label on the socket and the corresponding MCB with a number or identifier. So when the ELCB or RCCB decides to trip, esp. in the middle of night (for no reason), it will make your loss of electricity much less harrowing. 😀 If the culprit was the water heater, at least you can shut it down, until you get it fixed, but still be able to use electricity in the meantime. You did the right thing but there are times you need to unplug all your appliances from the switch socket outlets first before you can reset the RCCB. The worse case is neutral short, then you better get an electrician to isolate the neutral wire. 4 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic January 17, 2023 Share January 17, 2023 5 hours ago, Ender said: How safe is your water heater? Licensed electrician cost 100% more than an unlicensed electrician. But the one doing the work is also not the one with the licence. It’s the ah nehs. 5 Link to post Share on other sites More sharing options...
Watwheels Supersonic January 17, 2023 Share January 17, 2023 5 hours ago, Ender said: How safe is your water heater? I think the flat's wiring and electrical system are also questionable. They could be very old. It could be the reason why the circuit breaker did not shut off when smth isnt right. Then there is also the water heater built-in safety feature. I think all of these factors have to come together for tragedy to happen. Any type of system be it electrical or gas can have leaks. Though gas is unlikely to have electrocution. Pros and cons to every type of system. It is sad that a family of 3 died in such circumstances. 1 Link to post Share on other sites More sharing options...
Victor68 Turbocharged January 17, 2023 Share January 17, 2023 10 minutes ago, Fcw75 said: Licensed electrician cost 100% more than an unlicensed electrician. But the one doing the work is also not the one with the licence. It’s the ah nehs. This is the big problem here. Although electrician is responsible, the cost of the work is being 'pushed down' by cheap labour by competitors. Most times, it is just a worker carrying on behalf of the electrician. 2 Link to post Share on other sites More sharing options...
Playtime Twincharged January 17, 2023 Share January 17, 2023 1 hour ago, 13177 said: Best is to go back to the good old days using water directly from the tap. And if want hot water, just boil using kettle and then pour into the bucket and shower. 😂 POUR into the bucket? In the old days... you dont pour... you put the kettle or pot into the bucket of cold water, the water is heated up, the boiled water can still use for drink, make tea or whatever. ↡ Advertisement 1 5 Link to post Share on other sites More sharing options...
