Stary Supercharged January 17, 2023 Share January 17, 2023 Actually how many HDB household actually uses a heater switch for their instant water heater? Is it common? ↡ Advertisement Link to post Share on other sites More sharing options...
Gunzy 4th Gear January 17, 2023 Share January 17, 2023 2 hours ago, Lala81 said: My in law's place had upgrading last year. They drew another power line to bring to the toilet for the instant heater. yes, very old house usually dun have separate line for water heater i think, just wondering if the built-in elcb in the instant water heater helps? Link to post Share on other sites More sharing options...
Jamesc Hypersonic January 17, 2023 Share January 17, 2023 3 hours ago, Playtime said: In the old days... you dont pour... you put the kettle or pot into the bucket of cold water, the water is heated up, the boiled water can still use for drink, make tea or whatever. This is a good idea I will put the kettle into my MIL bathtub. I assume still plug into the wall and switched on to heat up the water? Maybe can also save electricity putting the toaster in the bathtub too? 5 Link to post Share on other sites More sharing options...
13177 Hypersonic January 17, 2023 Share January 17, 2023 4 minutes ago, Starry said: Actually how many HDB household actually uses a heater switch for their instant water heater? Is it common? After that CNA video, then i know instant heater cannot connect to a 3 pin plug socket. Now then i realised at my parents old house, the instant heater was connected to a 3 pin plug, luckily never got electrocuted when using it back then. So i guess during that time, the heater was installed by an unlicense electrician. 1 Link to post Share on other sites More sharing options...
13177 Hypersonic January 17, 2023 Share January 17, 2023 8 minutes ago, Gunzy said: yes, very old house usually dun have separate line for water heater i think, just wondering if the built-in elcb in the instant water heater helps? Unless the owner rewire the whole house electrical wire, and separate one line for the water heater. But if the owner wants to install storage heater, think it is a must to have a separate line for it, even the house does not have one. Link to post Share on other sites More sharing options...
Arogab Turbocharged January 17, 2023 Share January 17, 2023 14 minutes ago, Starry said: Actually how many HDB household actually uses a heater switch for their instant water heater? Is it common? I do, but I just forgot my knowledge if this is HBD requirement for the LEW to sign. I may need to go back and check Link to post Share on other sites More sharing options...
Strat 6th Gear January 17, 2023 Share January 17, 2023 7 minutes ago, Jamesc said: This is a good idea I will put the kettle into my MIL bathtub. I assume still plug into the wall and switched on to heat up the water? Maybe can also save electricity putting the toaster in the bathtub too? you can use this to save some electricity...tell you MIL is 100% safe .. won't get electrocuted 4 Link to post Share on other sites More sharing options...
Cheesey74 6th Gear January 17, 2023 Share January 17, 2023 14 minutes ago, Starry said: Actually how many HDB household actually uses a heater switch for their instant water heater? Is it common? I thought all hdb come default with heater switches, at least my 24 yrs old flat came with both at the mbr n kitchen, paiseh lost touch liao very long nvr move house... wahaha! Link to post Share on other sites More sharing options...
Stary Supercharged January 17, 2023 Share January 17, 2023 On 3/12/2022 at 2:59 PM, Ender said: “The plug itself supports up to 13 amps. The heater uses, let’s say 14 amps. That means the plug itself will have to work even harder to fulfil that 14 amps, but the limit for that plug is only 13 amps. It gets hot because it works even harder, and that’s why the wire burns,” he explained. "The regulation has always been to use a heater switch." On the above, the 3-pin plug has a 13A fuse inside right? If 14 amps run through it, wouldn't the fuse breaks and cut off the electricity at the plug? Just wondering....... Link to post Share on other sites More sharing options...
Ender Hypersonic January 17, 2023 Share January 17, 2023 3 minutes ago, Starry said: On the above, the 3-pin plug has a 13A fuse inside right? If 14 amps run through it, wouldn't the fuse breaks and cut off the electricity at the plug? Just wondering....... The way you quote, is like I say one...LOL 2 Link to post Share on other sites More sharing options...
Kb27 Supersonic January 17, 2023 Share January 17, 2023 3 hours ago, 13177 said: How come your rice cooker tripped at 4am? The rice cooker power is on? When I examined the rice cooker, some part of it has corroded. You know when you use water to cook rice, sometimes small amount may spill out, but this went into the rice cooker electrical parts. JHE, unknown brand cooker, better not to buy. The corrosion (with the neutral wire) could have edge towards the earth wire. Then somehow create an electrical path, and that tripped the RCCB. The rice cooker is not powered on, but a neutral wire touching an earth wire will trip the breaker. 3 Link to post Share on other sites More sharing options...
13177 Hypersonic January 17, 2023 Share January 17, 2023 31 minutes ago, Cheesey74 said: I thought all hdb come default with heater switches, at least my 24 yrs old flat came with both at the mbr n kitchen, paiseh lost touch liao very long nvr move house... wahaha! HDB with default heater switches should be those newly built HDB. Old HDB dont think have. Link to post Share on other sites More sharing options...
inlinesix Hypersonic January 17, 2023 Share January 17, 2023 1 minute ago, 13177 said: HDB with default heater switches should be those newly built HDB. Old HDB dont think have. Mine TOP 1999 got le Link to post Share on other sites More sharing options...
13177 Hypersonic January 17, 2023 Share January 17, 2023 7 minutes ago, Kb27 said: When I examined the rice cooker, some part of it has corroded. You know when you use water to cook rice, sometimes small amount may spill out, but this went into the rice cooker electrical parts. JHE, unknown brand cooker, better not to buy. The corrosion (with the neutral wire) could have edge towards the earth wire. Then somehow create an electrical path, and that tripped the RCCB. The rice cooker is not powered on, but a neutral wire touching an earth wire will trip the breaker. So it mean for electrical applicances, even it is not powered on, it might still can tripped off the RCCB? Or even have risk to electrocuted a person? 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic January 17, 2023 Share January 17, 2023 (edited) 3 hours ago, Lala81 said: My in law's place had upgrading last year. They drew another power line to bring to the toilet for the instant heater. That's the right way. Lay another set of power lines from the breaker. But that cost more, which people try to save. So they end up tapping from the nearest wire, which may overload those wires. The same thing happened in car electrical. People want to install power hungry amps and whatnot. The cheap way is to tap onto existing wires, which cause them to overload sometime in the future. And car burst into flames. Car electrical accident is more obvious, bcuz it runs on low voltage DC, so the same powered device use more current, which means more heat, unless the wires are upgraded. There were talks of moving from 12Vdc to a higher 48Vdc. but till today, nothing much has changed. Higher voltage means lower current, and the wires can be thinner. Edited January 17, 2023 by Kb27 3 Link to post Share on other sites More sharing options...
13177 Hypersonic January 17, 2023 Share January 17, 2023 Just now, inlinesix said: Mine TOP 1999 got le Like that maybe built in 90s and above got heater switch by default. 1 Link to post Share on other sites More sharing options...
Mustank Hypersonic January 17, 2023 Share January 17, 2023 Just buy from Lazada Panasonic shop lor they got arrange for installation https://s.lazada.sg/s.0COWF 明门正派 one won’t anyhow recommend installer one Link to post Share on other sites More sharing options...
Ender Hypersonic January 17, 2023 Share January 17, 2023 Just now, Mustank said: Just buy from Lazada Panasonic shop lor they got arrange for installation https://s.lazada.sg/s.0COWF 明门正派 one won’t anyhow recommend installer one Next time I get Steven Chia to install. I saw in his video, he installed the Storage heater perfectly with much approval from the license eletrician. ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Meguiar's Water Magnet MF drying towel
