mersaylee Hypersonic October 11, 2024 Share October 11, 2024 On 10/11/2024 at 9:09 AM, Lala81 said: Probably in early morning, don't want to disturb the ones sleeping. Unless it's as loud as a door bell switch...😁 ↡ Advertisement Link to post Share on other sites More sharing options...
Ysc3 Twincharged October 11, 2024 Share October 11, 2024 @Lala81 just got this but not what was expecting ... Link to post Share on other sites More sharing options...
13177 Hypersonic October 11, 2024 Share October 11, 2024 On 10/11/2024 at 10:24 PM, Ysc3 said: @Lala81 just got this but not what was expecting ... You did not expect it is made in china or expect the switch is quiet and yet switch still noisy? Link to post Share on other sites More sharing options...
Lala81 Hypersonic October 12, 2024 Author Share October 12, 2024 (edited) On 10/11/2024 at 10:24 PM, Ysc3 said: @Lala81 just got this but not what was expecting ... Yup it's for those with recessed switches tunneled into the wall so some of the older hdb can't use. Edited October 12, 2024 by Lala81 Link to post Share on other sites More sharing options...
13177 Hypersonic October 12, 2024 Share October 12, 2024 (edited) On 10/12/2024 at 9:19 AM, Lala81 said: Yup it's for those with recessed switches tunneled into the wall so some of the older hdb can't use. Didn’t know switch also got suitable for new or old hdb? Lol. Edited October 12, 2024 by 13177 Link to post Share on other sites More sharing options...
Volvobrick Supersonic October 12, 2024 Share October 12, 2024 On 10/11/2024 at 11:18 AM, Ysc3 said: anyone using any quiet or soft-click switches for your water heater switch ? mine is the standard HDB switch which clicks quite loudly whenever its being switched on and off. "quiet" as in mechanical switches and not those wifi (powered) switches. How loud can a switch be?? Afraid to wake up the house mouse? 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic October 12, 2024 Share October 12, 2024 put some oil on the contacts. 😁 basically the switch connects and disconnect via 2 metal strips. I'd be more concern with the sparking than the noise it makes. 😀 2 Link to post Share on other sites More sharing options...
13177 Hypersonic October 12, 2024 Share October 12, 2024 On 10/12/2024 at 12:07 PM, Kb27 said: put some oil on the contacts. 😁 basically the switch connects and disconnect via 2 metal strips. I'd be more concern with the sparking than the noise it makes. 😀 Isn’t seeing some spark when you switch on socket is quite common? But seeing spark when switch on lightning switch is uncommon. Link to post Share on other sites More sharing options...
Ct3833 Supersonic October 14, 2024 Share October 14, 2024 On 10/11/2024 at 8:35 AM, Mkl22 said: Eh? Does it matter. Not as if it’s a light switch where you switch on and off many times. Water heat just off and on for that period of use. More importantly to get a decent approved one. come back home at 2 am after spending good time with girlfriend , scare to wake up wife mah. 4 Link to post Share on other sites More sharing options...
Mkl22 Supersonic October 14, 2024 Share October 14, 2024 On 10/14/2024 at 9:06 PM, Ct3833 said: come back home at 2 am after spending good time with girlfriend , scare to wake up wife mah. Must bath in cold water to repent then…. 😂 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic October 14, 2024 Share October 14, 2024 I thought bath at GF. Otherwise bring good smells home 2 Link to post Share on other sites More sharing options...
mersaylee Hypersonic October 20, 2024 Share October 20, 2024 On 10/14/2024 at 9:16 PM, inlinesix said: I thought bath at GF. Otherwise bring good smells home Better not use gf soap...climb stairs until smelly...the home affair minister sure kpkb ask the one having an affair quickly go bathe...✌️😁 2 Link to post Share on other sites More sharing options...
Lala81 Hypersonic November 12, 2024 Author Share November 12, 2024 Lower Back sore now. Been procrastinating. The black cambray cloth underneath the sofa been peeling off into fragments and papery black dust. Bought the stapler gun and cloth some months back. Finally did it today. Family affair. Cant unscrew off my stools legs. So just trimmed off the cloth with penknife. My wife pointed out same problem will recur. But that's what I have for now. Maybe getting a black thin vinyl will be better. But that's a problem for another day. 6 Link to post Share on other sites More sharing options...
Atonchia Supersonic November 12, 2024 Share November 12, 2024 I need to get new bedroom door handle/lockset..... Broken only after almost 5yrs of usage....🤦 Checked with the brand office, no longer carry this model... It's tubular type.... Not sure if other brand has similar dimension. 1 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic November 12, 2024 Share November 12, 2024 On 11/12/2024 at 6:58 PM, Atonchia said: I need to get new bedroom door handle/lockset..... Broken only after almost 5yrs of usage....🤦 Checked with the brand office, no longer carry this model... It's tubular type.... Not sure if other brand has similar dimension. I install this on my bedroom door. Only thing to watch out for is the backset dimension. This one can do 60mm or 70mm. I can't remember how to measure it. 😁 https://shopee.sg/NELON-Room-Door-LEVER-LOCKSET-16411-SERIES-(Stainless-Steel)-i.277102416.7257120901 3 Link to post Share on other sites More sharing options...
Atonchia Supersonic November 12, 2024 Share November 12, 2024 On 11/12/2024 at 8:56 PM, Kb27 said: I install this on my bedroom door. Only thing to watch out for is the backset dimension. This one can do 60mm or 70mm. I can't remember how to measure it. 😁 https://shopee.sg/NELON-Room-Door-LEVER-LOCKSET-16411-SERIES-(Stainless-Steel)-i.277102416.7257120901 Yah...I saw this pop up when I search for tubular type of door handles. Initially wanted to get the same brand, because all other internal doors all same handle.... Link to post Share on other sites More sharing options...
Ct3833 Supersonic November 12, 2024 Share November 12, 2024 On 11/12/2024 at 6:58 PM, Atonchia said: I need to get new bedroom door handle/lockset..... Broken only after almost 5yrs of usage....🤦 Checked with the brand office, no longer carry this model... It's tubular type.... Not sure if other brand has similar dimension. This is a common lock, usually get this distance right will do, either 50mm, 60mm or 70mm. You can dismantle the whole lock and bring it to a door lock hardware shop and compare it yourself. It wont take .ore than 2 or 3 screws to remove the whole lock. 4 1 Link to post Share on other sites More sharing options...
13177 Hypersonic November 12, 2024 Share November 12, 2024 One question, how can I fix scratches on metal window frames ar? ↡ Advertisement Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
Even after $60k in vet bills and going into debt, S’pore couple couldn’t save their dog
Dream home
Dream home
Home renovation tips
