Lala81 Hypersonic September 18, 2022 Author Share September 18, 2022 (edited) @Kb27 and other screw expert. Some screw is missing from my kids tennis ball trolley. I measured the diameter of the thread to be 3mm against a ruler (I don't have vernier calipers). Visually it looks about right for a M4 screw. Am i correct? Somehow this thread diameter thing is not very easily google-able. https://en.wikipedia.org/wiki/ISO_metric_screw_thread Edited September 18, 2022 by Lala81 ↡ Advertisement Link to post Share on other sites More sharing options...
Lala81 Hypersonic September 18, 2022 Author Share September 18, 2022 (edited) Maybe i switch to a nylock nut to reduce the chance of loosening. Cos the wheel is held by 10mm screw with a hex nut behind. I'm missing 1 hex nut anyway, need to replace it. Edited September 18, 2022 by Lala81 Link to post Share on other sites More sharing options...
Kb27 Supersonic September 18, 2022 Share September 18, 2022 27 minutes ago, Lala81 said: @Kb27 and other screw expert. Some screw is missing from my kids tennis ball trolley. I measured the diameter of the thread to be 3mm against a ruler (I don't have vernier calipers). Visually it looks about right for a M4 screw. Am i correct? Somehow this thread diameter thing is not very easily google-able. https://en.wikipedia.org/wiki/ISO_metric_screw_thread It's hard to tell, without a vernier. Maybe just find some M3 or M4 screws and try out. Nyloc is useful to prevent nut from coming loose due to vibration. 2 Link to post Share on other sites More sharing options...
Lala81 Hypersonic September 18, 2022 Author Share September 18, 2022 3 minutes ago, Kb27 said: It's hard to tell, without a vernier. Maybe just find some M3 or M4 screws and try out. Nyloc is useful to prevent nut from coming loose due to vibration. haha ok. Nvm just buy first and see how. What is the worst can happen, just end up with more screws lol. Link to post Share on other sites More sharing options...
Volvobrick Hypersonic September 18, 2022 Share September 18, 2022 1 hour ago, Lala81 said: haha ok. Nvm just buy first and see how. What is the worst can happen, just end up with more screws lol. Bicycle bottle cage screws are M5. Can try to ensure it is not M5 or bigger. Link to post Share on other sites More sharing options...
Lala81 Hypersonic September 23, 2022 Author Share September 23, 2022 Update. Screws and nylock nut arrived. However with the washer and only a 1cm screw, the nylock nut is not fully utilised (end of screw just reaches the end of the nut). But OK lah. Good enough. Was originally considering just change all 7 other nuts to nylock nuts but since the length of the screws are all 10mm. Hold off first. Just change as needed. 2 Link to post Share on other sites More sharing options...
Kb27 Supersonic September 23, 2022 Share September 23, 2022 28 minutes ago, Lala81 said: Update. Screws and nylock nut arrived. However with the washer and only a 1cm screw, the nylock nut is not fully utilised (end of screw just reaches the end of the nut). But OK lah. Good enough. Was originally considering just change all 7 other nuts to nylock nuts but since the length of the screws are all 10mm. Hold off first. Just change as needed. There's enough space, could've gotten longer screws like 14mm. 😁 1 Link to post Share on other sites More sharing options...
Ender Hypersonic September 26, 2022 Share September 26, 2022 (edited) DIY water heater, with water pressure pump. No need for license eletrical work... 😂😂 Edited September 26, 2022 by Ender 3 Link to post Share on other sites More sharing options...
Stratovarius Turbocharged September 26, 2022 Share September 26, 2022 12 minutes ago, Ender said: DIY water heater, with water pressure pump. No need for license eletrical work... 😂😂 PVC pipe? Link to post Share on other sites More sharing options...
Ender Hypersonic September 26, 2022 Share September 26, 2022 1 hour ago, Stratovarius said: PVC pipe? Maybe a spoof... Link to post Share on other sites More sharing options...
Victor68 Turbocharged September 27, 2022 Share September 27, 2022 15 hours ago, Ender said: DIY water heater, with water pressure pump. No need for license eletrical work... 😂😂 This one looks like no earthing hor. Water is the best electricity conductor hor. Never try it 😆 Link to post Share on other sites More sharing options...
t0y0ta Supercharged September 27, 2022 Share September 27, 2022 14 hours ago, Ender said: Maybe a spoof... should be... try to seal a round curved surface hole to a pipe I think is near impossible without wielding or soldering. Link to post Share on other sites More sharing options...
Kklim Supercharged September 27, 2022 Share September 27, 2022 Fan drive belt in Ariston washer frayed and came off. Found exact replacement on eBay (seller fr Romania). Back to normal 🙂 4 Link to post Share on other sites More sharing options...
Tianmo Hypersonic October 31, 2022 Share October 31, 2022 Guys, anyone got any idea what is the problem if the aircon blower wheel delay in spinning, like delayed 3-5min? But once it starts spinning is normal again. Link to post Share on other sites More sharing options...
Vratenza Supersonic November 10, 2022 Share November 10, 2022 Hi all! Need some advice here. My place the kitchen faucet base is loose and wobbly. Went down on my back to see what is happening. I see a horseshoe shaped metal plate that seem to be doing the job of securing the faucet to the kitchen top. It seem to be tighten down by the main water hose. There are no other screws or bolts that i can see. I assume i just need to tighten down the hex shaped pipe connector. Question is, what is the best tool to use for this? Saw online sink wrenches but the space is really tight... Link to post Share on other sites More sharing options...
Victor68 Turbocharged November 10, 2022 Share November 10, 2022 3 hours ago, Vratenza said: Hi all! Need some advice here. My place the kitchen faucet base is loose and wobbly. Went down on my back to see what is happening. I see a horseshoe shaped metal plate that seem to be doing the job of securing the faucet to the kitchen top. It seem to be tighten down by the main water hose. There are no other screws or bolts that i can see. I assume i just need to tighten down the hex shaped pipe connector. Question is, what is the best tool to use for this? Saw online sink wrenches but the space is really tight... Picture not very clear but most kitchen and basin faucet works the same way. You do need a special tool to tighten it from below. Something like those use for car sparkplugs but bigger diameter. Go to a hardware shop and they will show you. 1 Link to post Share on other sites More sharing options...
Arogab Turbocharged November 10, 2022 Share November 10, 2022 3 hours ago, Vratenza said: Hi all! Need some advice here. My place the kitchen faucet base is loose and wobbly. Went down on my back to see what is happening. I see a horseshoe shaped metal plate that seem to be doing the job of securing the faucet to the kitchen top. It seem to be tighten down by the main water hose. There are no other screws or bolts that i can see. I assume i just need to tighten down the hex shaped pipe connector. Question is, what is the best tool to use for this? Saw online sink wrenches but the space is really tight... You design is so tight. Good luck to struggle on how to get it done, you need to find the right tool to get it done. Maybe even bring a better picture to the hardware shop to buy the right wrench. Another way I used to do is to turn both top and bottom to an offset angle just before it is tight and them twist from the top to desired position to tighten while holding the bottom Link to post Share on other sites More sharing options...
t0y0ta Supercharged November 10, 2022 Share November 10, 2022 (edited) 29 minutes ago, Victor68 said: Picture not very clear but most kitchen and basin faucet works the same way. You do need a special tool to tighten it from below. Something like those use for car sparkplugs but bigger diameter. Go to a hardware shop and they will show you. That special tool you talked about will need to dismantle the flex water line 3 hours ago, Vratenza said: Hi all! Need some advice here. My place the kitchen faucet base is loose and wobbly. Went down on my back to see what is happening. I see a horseshoe shaped metal plate that seem to be doing the job of securing the faucet to the kitchen top. It seem to be tighten down by the main water hose. There are no other screws or bolts that i can see. I assume i just need to tighten down the hex shaped pipe connector. Question is, what is the best tool to use for this? Saw online sink wrenches but the space is really tight... Why do you have 3 water lines? Usually it is just 2 (hot + cold) or 2 inlets and a long flexi outlet line that will route back via a big hole back to the top of the tap for those with pull-out. Edited November 10, 2022 by t0y0ta ↡ Advertisement Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
Home renovation tips
Wheel Spacer Installation DIY
