Ender Hypersonic May 5, 2022 Share May 5, 2022 New battery for my son's retired Oppo R15 Pro.. Last checked with Accubattery, the old battery estimation was less than 2500 MAH (rated at 3430MAH) This time bought from Shoppe, Malaysian seller, coz cheapest at $18.50. Looks like original. year of manufactured was 2021 (left battery in the picture), old battery was manufactured in 2018. Screenshot of first estimation of the new battery base on first charge is 3461 MAH. ↡ Advertisement 4 Link to post Share on other sites More sharing options...
Hamburger Hypersonic May 5, 2022 Share May 5, 2022 My HW P20 battery health is failing and discharging real fast. Maybe should buy a new batt on line and DIY a change. 1 Link to post Share on other sites More sharing options...
t0y0ta Supercharged May 6, 2022 Share May 6, 2022 On 4/29/2022 at 10:46 PM, Ct3833 said: The switch on my outdoor socket went bad because the plastic and spring in the switch gear has deteriorated, i bought a schneider socket but the switch does not come with this connector below, this is a connector/sleeve to be attached to the pvc pipe to prevent water from going into the pipe, where could i buy this ? I ran to a few HDB HW shops but none of them has the exeact fit. Bring this old socket to Choo Chiang, they are the mega stall of electrical components. Many branches all over the island. 4 Link to post Share on other sites More sharing options...
Ct3833 Supersonic May 6, 2022 Share May 6, 2022 1 hour ago, Hamburger said: My HW P20 battery health is failing and discharging real fast. Maybe should buy a new batt on line and DIY a change. Change phone. 3 Link to post Share on other sites More sharing options...
Ender Hypersonic May 6, 2022 Share May 6, 2022 2 hours ago, Hamburger said: My HW P20 battery health is failing and discharging real fast. Maybe should buy a new batt on line and DIY a change. Better check the youtube if you want to go thru the hassle of opening up the phone. Coz nowadays most phone use glue instead of clipped plastic back cover. Need to have the right tools, like heat gun/hair dryer, thin piece of metal or plastic to do the initial slipped into small gaps. The oppo and Redmi are accessed thru the back cover which is slightly easier. I just tried to open the Google Pixel, which is a pain coz have to access thru the front screen, and I have cracked the edge of the sceen, coz the tool I have is too thick. Now I am waiting for the arrival of a thinner stainless steel sheet before trying again.. 4 2 Link to post Share on other sites More sharing options...
TangoCharlie Supersonic May 6, 2022 Share May 6, 2022 3 hours ago, Ender said: Better check the youtube if you want to go thru the hassle of opening up the phone. Coz nowadays most phone use glue instead of clipped plastic back cover. Need to have the right tools, like heat gun/hair dryer, thin piece of metal or plastic to do the initial slipped into small gaps. The oppo and Redmi are accessed thru the back cover which is slightly easier. I just tried to open the Google Pixel, which is a pain coz have to access thru the front screen, and I have cracked the edge of the sceen, coz the tool I have is too thick. Now I am waiting for the arrival of a thinner stainless steel sheet before trying again.. You change pixel battery or screen? Just changed my oow pixel screen at $140+ . Ouch. Link to post Share on other sites More sharing options...
Lala81 Hypersonic May 6, 2022 Author Share May 6, 2022 8 minutes ago, TangoCharlie said: You change pixel battery or screen? Just changed my oow pixel screen at $140+ . Ouch. oh its just the screen from the sweat/water? not the phone died. Link to post Share on other sites More sharing options...
TangoCharlie Supersonic May 6, 2022 Share May 6, 2022 Just now, Lala81 said: oh its just the screen from the sweat/water? not the phone died. Yup. Only 1 year plus so send in as doubtful some drops of sweat can totally kill the phone. 1 Link to post Share on other sites More sharing options...
Ender Hypersonic May 6, 2022 Share May 6, 2022 6 minutes ago, TangoCharlie said: You change pixel battery or screen? Just changed my oow pixel screen at $140+ . Ouch. Want to change battery, but to access to it, need to pry off the screen. Delicate process, need the right tools. Aliexpress has the screen for around $40.. Maybe if I cracked the screen too much, I may just change the screen as well. 2 Link to post Share on other sites More sharing options...
Lala81 Hypersonic May 6, 2022 Author Share May 6, 2022 1 minute ago, TangoCharlie said: Yup. Only 1 year plus so send in as doubtful some drops of sweat can totally kill the phone. haha google pixels arent particularly known for being reliable. Link to post Share on other sites More sharing options...
TangoCharlie Supersonic May 6, 2022 Share May 6, 2022 (edited) 2 minutes ago, Lala81 said: haha google pixels arent particularly known for being reliable. Also learned from service centre pixel 4A is not rated for water resistance, unlike the higher end ones. Edited May 6, 2022 by TangoCharlie Link to post Share on other sites More sharing options...
Evo5sg 2nd Gear May 8, 2022 Share May 8, 2022 Any reason why my instant water heater switch can become like that ? Link to post Share on other sites More sharing options...
Kb27 Supersonic May 8, 2022 Share May 8, 2022 5 minutes ago, Evo5sg said: Any reason why my instant water heater switch can become like that ? Looks like overloading. Too much current passed through, the wire cannot handle the heat and insulation burned. 2 Link to post Share on other sites More sharing options...
Ender Hypersonic May 8, 2022 Share May 8, 2022 15 minutes ago, Evo5sg said: Any reason why my instant water heater switch can become like that ? Reminder if this allows to continued uncheck. Wire fused occurs and danger. Quote When the plug to the water heater was opened after the incident, the cables inside were “badly burnt” and the earth cable and neutral cable had fused together. 1 Link to post Share on other sites More sharing options...
Dafansu Turbocharged May 8, 2022 Share May 8, 2022 (edited) On 5/6/2022 at 2:07 AM, Ender said: New battery for my son's retired Oppo R15 Pro.. Last checked with Accubattery, the old battery estimation was less than 2500 MAH (rated at 3430MAH) This time bought from Shoppe, Malaysian seller, coz cheapest at $18.50. Looks like original. year of manufactured was 2021 (left battery in the picture), old battery was manufactured in 2018. Screenshot of first estimation of the new battery base on first charge is 3461 MAH. I replaced two batteries, ordered from shopee, one for my Samsung tablet and one for my Samsung old note 8. The tablet seems ok, but the phone battery doesn't last long, capacity can reduce to 20-30% in a day even without using. Not sure if phone issue or they pass me lousy QC battery or recon type. Edited May 8, 2022 by Dafansu Link to post Share on other sites More sharing options...
Dafansu Turbocharged May 8, 2022 Share May 8, 2022 (edited) On 5/6/2022 at 10:47 AM, Ender said: Better check the youtube if you want to go thru the hassle of opening up the phone. Coz nowadays most phone use glue instead of clipped plastic back cover. Need to have the right tools, like heat gun/hair dryer, thin piece of metal or plastic to do the initial slipped into small gaps. The oppo and Redmi are accessed thru the back cover which is slightly easier. I just tried to open the Google Pixel, which is a pain coz have to access thru the front screen, and I have cracked the edge of the sceen, coz the tool I have is too thick. Now I am waiting for the arrival of a thinner stainless steel sheet before trying again.. good to try, next time will know how to replace, not that difficult, a lot of youtube videos online for reference like what you had mentioned, even from those selling the same battery. The tools for replacement purposes are cheap $2-4 can get whole set in shopee. I didn't break anything during replacement, just that I tried to dig the battery out from the centre of my phone not knowing the screen panel is directly behind resulting in a dot that slowly grow bigger on the LCD screen. ok with it since it's my spare phone, just trying out for the fun of it and learning purposes. Tablet will be easier since usually no IP68 ratings which means no glue at the side and usually clip on. Hair dryer/Heat Gun is a must to loosen the glue before trying to take out. Edited May 8, 2022 by Dafansu 7 Link to post Share on other sites More sharing options...
Ender Hypersonic May 8, 2022 Share May 8, 2022 5 hours ago, Dafansu said: I replaced two batteries, ordered from shopee, one for my Samsung tablet and one for my Samsung old note 8. The tablet seems ok, but the phone battery doesn't last long, capacity can reduce to 20-30% in a day even without using. Not sure if phone issue or they pass me lousy QC battery or recon type. Ya, buy battery from online also there's a risk these are old stock, or worst when seller sells used battery as new. Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged May 9, 2022 Share May 9, 2022 borrow this thread.. Anyone know where to get shower screen seal? those installed at the edge/bottom of the glass to prevent water splashing out.. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
Home renovation tips
Wheel Spacer Installation DIY
