Lala81 Hypersonic March 9, 2022 Author Share March 9, 2022 8 hours ago, Se3h3ng said: Anyone can guide on how to repair the screw hole cause by hinge? (Cupboard). Previously i try to tighten the screw, but seems like the hole gone liao… cannot be tighten anymore… I believe I've read what local contractors do in Sg renovation is they put in some epoxy. Let it dry then drive the screw in again. I can't remember the number of the epoxy they use. Yes can put in strips of plywood if u have some. There are tutorials on YouTube. ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Rayleigh 6th Gear March 10, 2022 Share March 10, 2022 9 hours ago, Se3h3ng said: Anyone can guide on how to repair the screw hole cause by hinge? (Cupboard). Previously i try to tighten the screw, but seems like the hole gone liao… cannot be tighten anymore… You can use a wood filler and it takes a couple of hours to dry or harden. Or if you can find wooden cloth peg, cut into stripe and insert into the screw hole. Trim off the excess that are protruding out. 3 Link to post Share on other sites More sharing options...
Mustank Hypersonic March 10, 2022 Share March 10, 2022 Water heater better don’t anyhow diy 1 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic March 10, 2022 Share March 10, 2022 4 minutes ago, Mustank said: Water heater better don’t anyhow diy I replaced mine tank type myself. But with exact same model.... 2 Link to post Share on other sites More sharing options...
Stratovarius Turbocharged March 10, 2022 Share March 10, 2022 10 hours ago, Se3h3ng said: Anyone can guide on how to repair the screw hole cause by hinge? (Cupboard). Previously i try to tighten the screw, but seems like the hole gone liao… cannot be tighten anymore… my method is 1 -find a suitable wall plug. cut a wall plug to length as wall plugs are much longer than the thickness of the door. 2 -apply white glue to the wall plug 3 - press fit into the hole and wait awhile for the glue to dry. 4 - screw back on. 6 Link to post Share on other sites More sharing options...
mersaylee Hypersonic March 10, 2022 Share March 10, 2022 4 minutes ago, Stratovarius said: my method is 1 -find a suitable wall plug. cut a wall plug to length as wall plugs are much longer than the thickness of the door. 2 -apply white glue to the wall plug 3 - press fit into the hole and wait awhile for the glue to dry. 4 - screw back on. Simi white glue huh? 😁 Oh oh...wood glue 😅 3 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic March 10, 2022 Share March 10, 2022 1 minute ago, mersaylee said: Simi white glue huh? 😁 Oh oh...wood glue 😅 Not the natural one la. 5 Link to post Share on other sites More sharing options...
mersaylee Hypersonic March 10, 2022 Share March 10, 2022 16 minutes ago, Mustank said: Water heater better don’t anyhow diy I've replaced at least 5 from old to new for self and family members...just need to ensure all CBs and switches are off (yes, ALL including the one for the Fridge becos I kiasi 😁) and that the new set has safety certificate label plus different colours for the 3 wires. 4 Link to post Share on other sites More sharing options...
Stratovarius Turbocharged March 10, 2022 Share March 10, 2022 8 minutes ago, mersaylee said: Simi white glue huh? 😁 Oh oh...wood glue 😅 PVA. the non organic kind. 🤣 2 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic March 14, 2022 Share March 14, 2022 Replaced the bloated batteries for my old Think pad laptop and an Acer tablet. Quite simple thanks to YouTube. 3 Link to post Share on other sites More sharing options...
Kklim Supercharged March 14, 2022 Share March 14, 2022 On 3/9/2022 at 11:04 PM, Ender said: I am wondering if plastic wall plugs can be usev for the damage hole? Stick a small cable between screw and plug and then tighten. Trim off excess and you're good to go. Link to post Share on other sites More sharing options...
Mkl22 Supersonic March 16, 2022 Share March 16, 2022 Anyone knows where I can get butyl sealant for the car door waterproof sheet locally? In a roll or tape form it is readily available but I’m having trouble looking for those that dispense like a silicone sealant. Link to post Share on other sites More sharing options...
Ender Hypersonic April 15, 2022 Share April 15, 2022 Replaced the battery of my Redmi Note 8 pro since it was bloated. Followed on of the youtube.. Battery arrived in 12 days from China. Vost about $19.30. Considered fast despite the lock down there. 5 Link to post Share on other sites More sharing options...
Kb27 Supersonic April 15, 2022 Share April 15, 2022 On 3/10/2022 at 7:45 AM, Lala81 said: I know. Thanks for the link. I didn't know what they were called. I just use what I had available. I bought fischer duopower wall plug. It's kind of expensive compared to the 1 cent plug from Horme. But it is very good for all kinds of walls, including drywall. https://shopee.sg/fischer-DUOPOWER-6-x-30-S-(nylon-plug-screw)-i.240539452.9411960182?sp_atk=a88a3cfe-45c0-46c5-8634-e03fe20026cd The 1 cent plug is quite limited. You need to drill more or less exact hole depth. Sometimes I hit a hollow brick, the plug would just dropped into the void and bcum useless. The duopower with a flange/lip at the top will not sink into the hole. Its 2 parts will spread securely holding onto the wall. 2 Link to post Share on other sites More sharing options...
Ender Hypersonic April 24, 2022 Share April 24, 2022 On 4/16/2022 at 1:01 AM, Ender said: Replaced the battery of my Redmi Note 8 pro since it was bloated. Followed on of the youtube.. Battery arrived in 12 days from China. Vost about $19.30. Considered fast despite the lock down there. Advertised mah is 5400mah. Must learn not to trust all these above stock value from 3rd party vendors. But still within 5% from the official Xiaomi spec is good enough especially for the price paid. 4 Link to post Share on other sites More sharing options...
Ct3833 Supersonic April 29, 2022 Share April 29, 2022 (edited) The switch on my outdoor socket went bad because the plastic and spring in the switch gear has deteriorated, i bought a schneider socket but the switch does not come with this connector below, this is a connector/sleeve to be attached to the pvc pipe to prevent water from going into the pipe, where could i buy this ? I ran to a few HDB HW shops but none of them has the exeact fit. Edited April 29, 2022 by Ct3833 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic April 29, 2022 Share April 29, 2022 18 minutes ago, Ct3833 said: The switch on my outdoor socket went bad because the plastic and spring in the switch gear has deteriorated, i bought a schneider socket but the switch does not come with this connector below, this is a connector/sleeve to be attached to the pvc pipe to prevent water from going into the pipe, where could i buy this ? I ran to a few HDB HW shops but none of them has the exeact fit. Got to go specialist electrical supply shop I guess. There are a couple at Enterprise Building Toh Guan Road. 1 Link to post Share on other sites More sharing options...
Twister 5th Gear April 30, 2022 Share April 30, 2022 9 hours ago, Volvobrick said: Got to go specialist electrical supply shop I guess. There are a couple at Enterprise Building Toh Guan Road. @Ct3833, I think you go Sim Lim Tower is nearer.. 🤔 ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
Home renovation tips
Wheel Spacer Installation DIY
