Gnahp Turbocharged September 19, 2020 Share September 19, 2020 I like to use original spark plug too last year I replaced mine, both are original spark plugs, left is new, right has 95,000km on it. First set lasted 130,000km from new I measured the gap, only open up by 0.1mm should adjust the gap, put them back and continue to use 😁 ↡ Advertisement 5 Link to post Share on other sites More sharing options...
Jamesc Hypersonic September 19, 2020 Share September 19, 2020 25 minutes ago, Apple-Tree said: Car STOCK Coolant from Factory BEST. My car 3 years already, still green green. Why change if it isn't broken .......heeee Absolutely right Toyota super long life coolant is meant to last up to ten years. 1 Link to post Share on other sites More sharing options...
Wt_know Supersonic September 19, 2020 Share September 19, 2020 (edited) all these snake until no snake la i am a big snake eater ... i eat until laosai liao simi sai spark plug simi sai ignition coil simi sai coolant simi sai air filter simi sai tok kong engine oil simi sai grounding cable simi sai voltage stabilizer simi sai snaking oil if you want to eat snake ... err ... eat sai ... no harm ... it's part of life experience zheng'ing car ... lol Edited September 19, 2020 by Wt_know 1 2 Link to post Share on other sites More sharing options...
inlinesix Hypersonic September 19, 2020 Share September 19, 2020 The best performance enhancer is ROM100 1 Link to post Share on other sites More sharing options...
Kangadrool Supersonic September 19, 2020 Share September 19, 2020 I prefer $4.50 per piece spark plug. 1 Link to post Share on other sites More sharing options...
Wt_know Supersonic September 19, 2020 Share September 19, 2020 (edited) 9 minutes ago, inlinesix said: The best performance enhancer is ROM100 you feed that into City or Vios ... no effect la ... not even butt feel ... but feel shiok can “afford” RON100 in msia ... priceless ... Edited September 19, 2020 by Wt_know 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic September 20, 2020 Share September 20, 2020 9 hours ago, Wt_know said: you feed that into City or Vios ... no effect la ... not even butt feel ... but feel shiok can “afford” RON100 in msia ... priceless ... I feed it into MYVI. It feels like i just drank RedBull. Every gear upshift at 4k RPM. Link to post Share on other sites More sharing options...
StrikeX 1st Gear September 21, 2020 Author Share September 21, 2020 On 9/19/2020 at 5:12 PM, Apple-Tree said: Cu BEST sia ...... NGK, Denso ......4 for $16. 40kkm hor. 110 -16 = A Few Roast Duck sia !! Better fuel saving. Is it true? Link to post Share on other sites More sharing options...
Hachi 3rd Gear September 21, 2020 Share September 21, 2020 On 9/19/2020 at 11:17 PM, Wt_know said: you feed that into City or Vios ... no effect la ... not even butt feel ... but feel shiok can “afford” RON100 in msia ... priceless ... I feed my swift sport, is the best, redline and engine wont pings.... Keep whacking.... 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic September 21, 2020 Share September 21, 2020 18 minutes ago, Hachi said: I feed my swift sport, is the best, redline and engine wont pings.... Keep whacking.... With RON100, dual VVT-I can operate at its maximum angle. Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear September 21, 2020 Share September 21, 2020 7 hours ago, StrikeX said: Better fuel saving. Is it true? OK. I did not say that. BUT hor, it is YOUR LUCKY DAY indeed. I happened to dig the mountain of INTERNET. Very Very intense research on this matter lor. It is a hyped that YOUR CAR will fly after installing iridium or whatever dium sia..... Here is the ARTICLE from Denso on their Iridium produck hor !!! Your JAW will drop hor, like Iridium can help to INCREASE 6metres for EVERY 799 metres....... Wah, 6 Metres like Machap solid solid lor OR 0.75% improvement ONLY. Then, YES, INCREASE in Horse power wor !!! ..... so, what is the different between.....31.50ps and 31.06ps ah ?? Then hor, many are tested with a 2 Cyc. 50cc Engine leh ....... what kind of Engine is that lor ...... Denso is AT LEAST HONEST lor. Take a look bro .... your whatever dium ...... never heard before lor. https://www.denso.com/global/en/products-and-services/automotive-service-parts-and-accessories/plug/iridiumpower/ Link to post Share on other sites More sharing options...
Mkl22 Twincharged September 21, 2020 Share September 21, 2020 On 9/19/2020 at 11:03 PM, Wt_know said: all these snake until no snake la i am a big snake eater ... i eat until laosai liao simi sai spark plug simi sai ignition coil simi sai coolant simi sai air filter simi sai tok kong engine oil simi sai grounding cable simi sai voltage stabilizer simi sai snaking oil if you want to eat snake ... err ... eat sai ... no harm ... it's part of life experience zheng'ing car ... lol Thank you for your contribution to society. 😅 Link to post Share on other sites More sharing options...
Mkl22 Twincharged September 21, 2020 Share September 21, 2020 On 9/19/2020 at 10:21 PM, Phang said: I like to use original spark plug too last year I replaced mine, both are original spark plugs, left is new, right has 95,000km on it. First set lasted 130,000km from new I measured the gap, only open up by 0.1mm should adjust the gap, put them back and continue to use 😁 Yup. A spark is a spark. Last time also got conned by sales talk. Now just stock best and just use. Unless some misfiring else no need to change one. Link to post Share on other sites More sharing options...
Gnahp Turbocharged September 21, 2020 Share September 21, 2020 2 hours ago, Mkl22 said: Yup. A spark is a spark. Last time also got conned by sales talk. Now just stock best and just use. Unless some misfiring else no need to change one. my late sifu once told me.. the power stroke get its bang from the air fuel mixture, like a dynamite does it make a difference in the bang if we light up the dynamite fuse with a lighter or a flame thrower? - Paul Lee 2 Link to post Share on other sites More sharing options...
Volvobrick Supersonic September 21, 2020 Share September 21, 2020 1 hour ago, awhtc said: More on saving of labour cost due to higher resistance to wear and tear. If the iridium spark plugs have 3x the lifespan, it will save $20 x 3 = $60 of labour cost. Unless it's a Latio, plugs is a DIY 10 min job. Unless you have a V12 then it's 30 min. 1 Link to post Share on other sites More sharing options...
Mkl22 Twincharged September 21, 2020 Share September 21, 2020 8 hours ago, Phang said: my late sifu once told me.. the power stroke get its bang from the air fuel mixture, like a dynamite does it make a difference in the bang if we light up the dynamite fuse with a lighter or a flame thrower? - Paul Lee Same thing with those who get conned by fancy Japanese coils. Okuda something. I think there is a YouTube video on this. Link to post Share on other sites More sharing options...
Watwheels Supersonic September 22, 2020 Share September 22, 2020 If it really claims to be longer lasting than Iridium spark plugs they will be good for cars with boxer engines. LoL...cos their spark plugs are hard to reach. Dont have to change so regularly. But price wise surely it will cost more than Iridium SP? Link to post Share on other sites More sharing options...
Shando 1st Gear October 7, 2020 Share October 7, 2020 On 9/21/2020 at 9:38 PM, Apple-Tree said: OK. I did not say that. BUT hor, it is YOUR LUCKY DAY indeed. I happened to dig the mountain of INTERNET. Very Very intense research on this matter lor. It is a hyped that YOUR CAR will fly after installing iridium or whatever dium sia..... Here is the ARTICLE from Denso on their Iridium produck hor !!! Your JAW will drop hor, like Iridium can help to INCREASE 6metres for EVERY 799 metres....... Wah, 6 Metres like Machap solid solid lor OR 0.75% improvement ONLY. Then, YES, INCREASE in Horse power wor !!! ..... so, what is the different between.....31.50ps and 31.06ps ah ?? Then hor, many are tested with a 2 Cyc. 50cc Engine leh ....... what kind of Engine is that lor ...... Denso is AT LEAST HONEST lor. Take a look bro .... your whatever dium ...... never heard before lor. https://www.denso.com/global/en/products-and-services/automotive-service-parts-and-accessories/plug/iridiumpower/ I think the main bonus are the lower spark voltage required to jump the gap, putting less stress on the ignition coil and thus less misfire. Probably would not matter if your driving style doesn't rev above 2000rpm most of the time but for ppl who like to rev 4-5000rpm occasionally then it might be helpful, smoother engine. Quote: "IRIDIUM POWER has a 0.4 mm diameter iridium center electrode and a specially shaped ground electrode. These features combine to achieve higher ignitability and require lower spark voltage than ever before. This enables high-response driving with fewer misfies than under higher required voltage spark conditions, and fewer misfires when ignitability is difficult." ↡ Advertisement Link to post Share on other sites More sharing options...
The end of human race.
Lobang to change toilet sink faucet
What do you call the cloth covers used for SAF ID tags?
Selling one year old Piano
Testing of tags
Testing of tags
Devon conger eel close to record
Would you buy a Tag Grand Carrera when you already have 2 other Tags?
