Kb27 Supersonic September 10, 2020 Share September 10, 2020 I had a small accident with this cheapo aluminum ladder. When I first step on it, the step broke off, 6 aluminum rivets are sheared off at the same time. Hurt my feet a little bit and marble floor suffered some chips. Luckily I am not at the top of the steps when it decide to break. I had earlier replaced the top step rivets with bolts and nuts, but the bottom step caught me off-guard. So if you have this kind of ladder, better have a second look, or maybe throw it away for own safety. Granted the ladder was quite old, I didn't use it much, the rivets may have corroded away. But I'd rather have a step ladder that doesn't do this. ↡ Advertisement 3 8 1 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic September 10, 2020 Share September 10, 2020 Where did you buy it? I thinking of getting one for my MIL. 12 Link to post Share on other sites More sharing options...
Volvobrick Supersonic September 10, 2020 Share September 10, 2020 12 minutes ago, Jamesc said: Where did you buy it? I thinking of getting one for my MIL. I think Kb27 will be very willing to sell you his. For a good price. That's what friends are for! 4 Link to post Share on other sites More sharing options...
Tkseah Turbocharged September 10, 2020 Share September 10, 2020 Maybe u exceeded the maximum load? 😛 4 Link to post Share on other sites More sharing options...
1fast1 Supersonic September 10, 2020 Share September 10, 2020 35 minutes ago, Jamesc said: Where did you buy it? I thinking of getting one for my MIL. And she's buying a stairway to heaven. 😁 5 Link to post Share on other sites More sharing options...
13177 Hypersonic September 10, 2020 Share September 10, 2020 (edited) This type of ladder quite common, many people should have one at home. Lucky you dont have major injury. Have to check our ladder from time to time. Edited September 10, 2020 by 13177 Link to post Share on other sites More sharing options...
Lala81 Hypersonic September 10, 2020 Share September 10, 2020 1 hour ago, Kb27 said: I had a small accident with this cheapo aluminum ladder. When I first step on it, the step broke off, 6 aluminum rivets are sheared off at the same time. Hurt my feet a little bit and marble floor suffered some chips. Luckily I am not at the top of the steps when it decide to break. I had earlier replaced the top step rivets with bolts and nuts, but the bottom step caught me off-guard. So if you have this kind of ladder, better have a second look, or maybe throw it away for own safety. Granted the ladder was quite old, I didn't use it much, the rivets may have corroded away. But I'd rather have a step ladder that doesn't do this. On a side note. I thought u aren't supposed to step on the top step for this ladder? 1 Link to post Share on other sites More sharing options...
Fitvip Supersonic September 10, 2020 Share September 10, 2020 (edited) 14 minutes ago, Lala81 said: On a side note. I thought u aren't supposed to step on the top step for this ladder? Strictly speaking No. But I had done it before. Should have bought this type. Edited September 10, 2020 by Fitvip Link to post Share on other sites More sharing options...
Volvobrick Supersonic September 10, 2020 Share September 10, 2020 18 minutes ago, Lala81 said: On a side note. I thought u aren't supposed to step on the top step for this ladder? Absolutely cannot! That's asking for trouble. 2 Link to post Share on other sites More sharing options...
Kklim Supercharged September 10, 2020 Share September 10, 2020 Glad the injuries were slight Link to post Share on other sites More sharing options...
Jusnel 6th Gear September 10, 2020 Share September 10, 2020 2 hours ago, Kb27 said: I had a small accident with this cheapo aluminum ladder. When I first step on it, the step broke off, 6 aluminum rivets are sheared off at the same time. Hurt my feet a little bit and marble floor suffered some chips. Luckily I am not at the top of the steps when it decide to break. I had earlier replaced the top step rivets with bolts and nuts, but the bottom step caught me off-guard. So if you have this kind of ladder, better have a second look, or maybe throw it away for own safety. Granted the ladder was quite old, I didn't use it much, the rivets may have corroded away. But I'd rather have a step ladder that doesn't do this. Buy the more modern type of step ladders. V heavy but v stable. Link to post Share on other sites More sharing options...
Kb27 Supersonic September 10, 2020 Author Share September 10, 2020 I think the problem is the rivets. Rivets should not be used in a load bearing application. 2 Link to post Share on other sites More sharing options...
Carbon82 Moderator September 10, 2020 Share September 10, 2020 3 hours ago, Kb27 said: I had a small accident with this cheapo aluminum ladder. When I first step on it, the step broke off, 6 aluminum rivets are sheared off at the same time. Hurt my feet a little bit and marble floor suffered some chips. Luckily I am not at the top of the steps when it decide to break. I had earlier replaced the top step rivets with bolts and nuts, but the bottom step caught me off-guard. So if you have this kind of ladder, better have a second look, or maybe throw it away for own safety. Granted the ladder was quite old, I didn't use it much, the rivets may have corroded away. But I'd rather have a step ladder that doesn't do this. Thanks for sharing. Lucky you are fine. Actually there is a lot more to the safe use of ladder. The following are some do's and dont's for all users to take note. 16 Link to post Share on other sites More sharing options...
Kopites Supersonic September 10, 2020 Share September 10, 2020 Can still surf mean he is still ok. Count your blessings did not use it near window to hang curtain. Must be positive. By the way what is your BMI?😄 1 1 Link to post Share on other sites More sharing options...
Kopites Supersonic September 10, 2020 Share September 10, 2020 https://www.google.com/amp/s/eezee.sg/blog/ladder-safety-working-at-height-safely/ Spend a minutes or so to read through. 1 Link to post Share on other sites More sharing options...
Kopites Supersonic September 10, 2020 Share September 10, 2020 Can't resist to link this video...hahaha Ladder? Haha Link to post Share on other sites More sharing options...
Ct3833 Supersonic September 10, 2020 Share September 10, 2020 3 hours ago, Kb27 said: I had a small accident with this cheapo aluminum ladder. When I first step on it, the step broke off, 6 aluminum rivets are sheared off at the same time. Hurt my feet a little bit and marble floor suffered some chips. Luckily I am not at the top of the steps when it decide to break. I had earlier replaced the top step rivets with bolts and nuts, but the bottom step caught me off-guard. So if you have this kind of ladder, better have a second look, or maybe throw it away for own safety. Granted the ladder was quite old, I didn't use it much, the rivets may have corroded away. But I'd rather have a step ladder that doesn't do this. Thanks for sharing. Hope you are OK now. I better check mine. But I notice the steps on your ladder are deformed, did any heavy weight step on it before? Or has it been used very frequently? Especially with safety shoes on it? 1 Link to post Share on other sites More sharing options...
therock Supersonic September 10, 2020 Share September 10, 2020 Take care and glad there was no serious injury. Hailo makes good ones. I use this one, and there's a sale now on Lazada: https://www.lazada.sg/products/queen-household-ladder-9-step-i100382531-s100390241.html?spm=a2o42.searchlist.list.1.3ba94d346FugPo&search=1 ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Would You Buy a Nissan...
Car accident advice
Car accident advice
Fire safety manager (FSM)
Sideswipe Accident Insurance Claim
TP speeding cause accident
