Auto gate problem
Cysnotts
  On 6/26/2020 at 2:44 AM, Kangadrool said:
I will try to sun it this weekend to see how first.
Expand
doesn't help... So, got it done by windows surgeon today. Performed a bypass to rectify the broken wire loom connector.
Hi guys need your guidance here. My swing type auto gate moves super slow and now refuses to open or close fully. I’ve changed the transformer and adjusted the micro switches to change speed and motor delay without success. The motor and mechanical parts underneath seem ok.
question is what could be the root cause and should I look to change the circuit board or others? Circuit Board is Ranger SWG800R
many thanks in advance.
Expand
Any loose wires to the actuators? Try turning yo full speed and slowest to see if there is any difference. If no diff maybe really toasted liao!
Thanks for the guidance. Checked all the wires and connections. Also turned the micro switchs to max…circuit board fried ?
Expand
Check the hinges and alignment. Make sure the hinges are lub, the hinge bolts arent lose, if some have came lose the alignment will be out and the gate cannot close properly.
Thanks mate for the advice. All hinges arms and bolts are secure.
Been advised by the agent in Malaysia that the IC board might be fried
