Stalker79 Neutral Newbie June 5, 2020 Share June 5, 2020 engine still running even though ignition key turn to off when I was in the Carpark. Drove to the end of the Carpark and off again and managed to shutdown My battery is 1yr 10months could it be due to battery? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Leo72 6th Gear June 5, 2020 Share June 5, 2020 20 minutes ago, Stalker79 said: engine still running even though ignition key turn to off when I was in the Carpark. Drove to the end of the Carpark and off again and managed to shutdown My battery is 1yr 10months could it be due to battery? Most likely is the ignition key lock problem or relay problem. 1 Link to post Share on other sites More sharing options...
iamahbee 5th Gear June 5, 2020 Share June 5, 2020 (edited) 32 minutes ago, Stalker79 said: engine still running even though ignition key turn to off when I was in the Carpark. Drove to the end of the Carpark and off again and managed to shutdown My battery is 1yr 10months could it be due to battery? What are you driving? I had this problem in my Golf 7 previously. The engine won't cut out when I turn the ignition off, but only when I pull out the key. Fault was attributed to the comfort control module. Edited June 5, 2020 by iamahbee 2 Link to post Share on other sites More sharing options...
Kangadrool Supersonic June 5, 2020 Share June 5, 2020 Manual still the best! If cannot shut off, use clutch to stall. 3 1 Link to post Share on other sites More sharing options...
Albeniz Turbocharged June 5, 2020 Share June 5, 2020 This sounds exactly like my wife! She just won't stop nagging even when I have already gone into switch off mode. 1 1 14 Link to post Share on other sites More sharing options...
Fitvip Supersonic June 5, 2020 Share June 5, 2020 9 minutes ago, Albeniz said: This sounds exactly like my wife! She just won't stop nagging even when I have already gone into switch off mode. Diesel engine some more!🤣🤣🤣 3 Link to post Share on other sites More sharing options...
RadX Moderator June 5, 2020 Share June 5, 2020 Just now, Fitvip said: Diesel engine some more!🤣🤣🤣 and black soot cum out summore...ewwwwwww 6 Link to post Share on other sites More sharing options...
Kb27 Supersonic June 5, 2020 Share June 5, 2020 1 hour ago, Stalker79 said: engine still running even though ignition key turn to off when I was in the Carpark. Drove to the end of the Carpark and off again and managed to shutdown My battery is 1yr 10months could it be due to battery? nothing to do with battery. in my old vw van, there's a big ole relay, that's supposed to energise when you crank or connect the circuit. then it's supposed to cut off when you turn the key off. sometimes the relay get stuck and don't cut off the engine or don't allow you to start the engine. Link to post Share on other sites More sharing options...
Bicolor 5th Gear June 5, 2020 Share June 5, 2020 In my case it was the ignition lock cylinder. Couldn't turn off car at all even after turning to off and pulling key out. Was really troublesome because all I could do was to put car into gear, release clutch and stall it, but all the dashboard lights wouldn't go off so I had to disconnect battery. Bear in mind that mine was a very old car, so problem might be different. Best to let workshop check as soon as possible while you still can turn it off after a few attempts. Will be really troublesome once you can't shut car off at all. 3 Link to post Share on other sites More sharing options...
Jamesc Hypersonic June 5, 2020 Share June 5, 2020 (edited) And if the brakes don't work also and you want to sell I am looking for a last car for my MIL. I don't mind paying above market price. Edited June 5, 2020 by Jamesc 5 Link to post Share on other sites More sharing options...
Stalker79 Neutral Newbie June 5, 2020 Author Share June 5, 2020 13 minutes ago, Bicolor said: In my case it was the ignition lock cylinder. Couldn't turn off car at all even after turning to off and pulling key out. Was really troublesome because all I could do was to put car into gear, release clutch and stall it, but all the dashboard lights wouldn't go off so I had to disconnect battery. Bear in mind that mine was a very old car, so problem might be different. Best to let workshop check as soon as possible while you still can turn it off after a few attempts. Will be really troublesome once you can't shut car off at all. Going down to workshop to check tomorrow... 2 Link to post Share on other sites More sharing options...
Stalker79 Neutral Newbie June 5, 2020 Author Share June 5, 2020 2 hours ago, Leo72 said: Most likely is the ignition key lock problem or relay problem. Thanks for the info 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator June 5, 2020 Share June 5, 2020 23 minutes ago, Jamesc said: And if the brake don't work also and you want to sell I am looking for a last car for my MIL. I don't mind paying above market price. When smth happens to your MIL, you let me know! I help you mask away all the post here! 3 Link to post Share on other sites More sharing options...
Kendra Clutched June 5, 2020 Share June 5, 2020 2 hours ago, Kangadrool said: Manual still the best! If cannot shut off, use clutch to stall. 3 pedals are better than 2 2 Link to post Share on other sites More sharing options...
Discoburg Supersonic June 5, 2020 Share June 5, 2020 3 hours ago, Stalker79 said: engine still running even though ignition key turn to off when I was in the Carpark. Drove to the end of the Carpark and off again and managed to shutdown My battery is 1yr 10months could it be due to battery? Phuacb??? Link to post Share on other sites More sharing options...
badlammy 6th Gear June 5, 2020 Share June 5, 2020 I thought the thread means this... Link to post Share on other sites More sharing options...
Windwaver Turbocharged June 5, 2020 Share June 5, 2020 3 hours ago, Albeniz said: This sounds exactly like my wife! She just won't stop nagging even when I have already gone into switch off mode. A tip bro. She'll nag more if she know you already switched off You should instead turn on turbo mode and listen to her carefully. 1 Link to post Share on other sites More sharing options...
Windwaver Turbocharged June 5, 2020 Share June 5, 2020 34 minutes ago, badlammy said: I thought the thread means this... Spoiler I also thought so initially. ↡ Advertisement Link to post Share on other sites More sharing options...
Simple home DIY repairs
Getting your car refreshed for CNY: paint / polish / ceramic
Temporary Tire Repairs
Where do you do your servicing/repair/tyre change?
3 party repairs ?
3 party repairs ?
Quotation for repairs
