Carbon82 Moderator May 18, 2020 Share May 18, 2020 Coupé or Cabriolet? Targa: The Best of Both Worlds Porsche completes its sports car trio in time for summer: following on from the Coupé and Cabriolet, the third body variant of the new 911 generation now makes its debut with the all-wheel drive Porsche 911 Targa 4 and 911 Targa 4S models. The distinguishing feature of the Targa remains its innovative, fully automatic roof system and, just like the legendary original Targa model from 1965, it features a characteristic wide roll hoop, a movable roof section above the front seats and a wraparound rear window. The roof can be comfortably opened and closed in just 19 seconds. It is powered by a six-cylinder, three-litre boxer engine with twin turbochargers: the Porsche 911 Targa 4 now delivers 283 kW (385 PS) and, in combination with the optional Sport Chrono package, accelerates from zero to 100 km/h in just 4.2 seconds - one tenth faster than before. The engine in the 911 Targa 4S boasts 331 kW (450 PS) and reaches the 100 km/h mark in just 3.6 seconds under the same conditions - four tenths faster than its predecessor. Top speed of the 911 Targa 4 is 289 km/h (up two km/h), while the 4S peaks at 304 km/h (up three km/h). Both sports cars are fitted with eight-speed dual-clutch transmission (PDK) and intelligent all-wheel drive Porsche Traction Management (PTM) as standard to deliver maximum driving pleasure. Alternatively, the 911 Targa 4S can be ordered with the newly developed seven-speed manual gearbox, with which the Sport Chrono package is included. New technology has also been integrated to extend the range of features for both 911 models and, for the first time, Porsche InnoDrive, which includes adaptive cruise control, is available. Thanks to the enhanced Smartlift function, ground clearance can be programmed so that it is raised for everyday use. The list of options is supplemented by an extensive range from Porsche Tequipment and new personalisation options from Porsche Exclusive Manufaktur. Porsche will further extend the combination of traditional style elements, timeless design and cutting-edge technology in a special edition of the 911 Targa, which will make its debut in June. Efficient biturbo boxer engine Like the 911 Carrera models, both Porsche 911 Targa variants profit from the increase in power provided by the turbocharged three-litre six-cylinder boxer engines. Both performance and everyday usability benefit as a result. The engine in the 911 Targa 4 produces 283 kW (385 PS) at 6,500 rpm, which is 11 kW (15 PS) more than its predecessor. Maximum torque of 450 newton metres is delivered across a wide engine speed range of between 1,950 and 5,000 rpm. With 331 kW (450 PS), the 911 Targa 4S delivers 22 kW (30 PS) more output than its predecessor and generates maximum torque of 530 Nm (up 30 Nm) between 2,300 and 5,000 rpm. Optimised all-wheel drive for better traction The enhanced performance of the new all-wheel drive models goes hand-in-hand with further development of the front-axle drive. The clutch and differential unit is water-cooled and has reinforced clutch discs for greater robustness and a higher load capacity. The increased actuating torque at the clutch improves its adjustment accuracy and the function of the additional front-axle drive. Overall, the enhanced front-axle drive with PTM (Porsche Traction Management) contributes to even better traction in all road conditions. Further developed chassis for more comfort and safety The electronically controlled variable damping system PASM (Porsche Active Suspension Management) is part of the standard equipment on the new 911 Targa models. This system automatically adjusts the damping characteristics in terms of driving comfort and handling to each driving situation and has two manually adjustable maps, Normal and Sport. Porsche Torque Vectoring Plus (PTV Plus), which includes an electronic rear differential lock with fully variable torque distribution, is added as standard equipment for the Targa 4S and is available as an option on the Targa 4. Like the other eighth generation Porsche 911 variants, the Targa models are also equipped with Porsche Wet mode as standard. Sensors fitted in the front wheel housings are capable of detecting water on the road surface and, if significant volumes of water are picked up, a signal in the cockpit provides a recommendation for the driver to manually switch to Wet mode. The drive responsiveness is then adapted to the conditions to guarantee maximum driving stability. The driving dynamics setup for the 911 Targa 4 includes 235/40 ZR tyres on 19-inch alloy wheels on the front axle and 295/35 ZR tyres on 20-inch wheels on the rear axle. As standard, the 4S model is fitted with 245/35 ZR tyres on its 20-inch front wheels and 305/30 ZR tyres on its 21-inch rears. On the Targa 4, deceleration is taken care of on both axles by 330-millimetre brake discs with black four-piston monobloc fixed callipers. The red-painted brake callipers on the Targa 4S have six pistons at the front axle, four at the rear while its discs measure 350 mm front and rear. The Porsche Ceramic Composite Brake (PCCB) can be ordered as an option. Extravagant Targa design with a modern interpretation The exterior of the Porsche 911 Targa is characterised by the design elements of its 992 model generation. Compared to its predecessors, its body features significantly more pronounced wheel housings at the front and, between its LED headlights, its bonnet has a distinctive recess evoking the design of the first 911 generations. Its rear is dominated by its wider, variably extending rear spoiler and seamlessly integrated, elegant light bar. With the exception of the front and rear sections, the entire outer skin is made from aluminium. The interior echoes the 911 Carrera models and is characterised by the clear and straight lines of its dashboard and its recessed instruments. The 911 models from the 1970s provided the inspiration here. Alongside the central rev counter - very much a defining feature for Porsche - two thin, frameless freeform displays extend the information provided to the driver. A compact switch unit with five buttons for direct access to important vehicle functions is located below the 10.9-inch centre screen of the Porsche Communication Management (PCM). The standard PCM features include online navigation based on swarm data as well as Connect Plus with Apple Car Play. The model for a new class of sports cars since 1965 The 1965 911 Targa 2.0 was a trailblazer for a whole new type of car. Originally marketed as a "safety cabriolet with anti-roll bar", the Targa, with its detachable roof, soon established itself as an independent concept and indeed became a style icon. Right through to the present day, Porsche has continued to combine two worlds in the 911 Targa: the advantages of open-top driving in a cabriolet combined with the everyday comfort and safety of a coupé. Prices The new Porsche 911 Targa models will be launched on the market from August 2020. Prices (including 19 percent VAT and country-specific equipment) start from 128,486 euros for the 911 Targa 4 and from 143,956 euros for the 911 Targa 4S. ↡ Advertisement 11 Link to post Share on other sites More sharing options...
Carbon82 Moderator May 18, 2020 Author Share May 18, 2020 Porsche 911 Targa 4 Porsche 911 Targa 4S 10 Link to post Share on other sites More sharing options...
inlinesix Hypersonic May 18, 2020 Share May 18, 2020 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic May 18, 2020 Share May 18, 2020 Must be expensive to make that thin piece of rear windscreen bend in such a shape w/o breaking. Link to post Share on other sites More sharing options...
1fast1 Supersonic May 18, 2020 Share May 18, 2020 I don't think I like the Targa look much. Coupes are best but proper cabriolets are OK with the top down. But Targas just look 'off' to me. Link to post Share on other sites More sharing options...
chelsiachel Clutched May 18, 2020 Share May 18, 2020 super cool 😍 Link to post Share on other sites More sharing options...
Carbon82 Moderator May 21, 2020 Author Share May 21, 2020 Personally, I prefer the Targa over Coupe for it better visibility (thanks to the relatively large curved rear windscreen), and the less common look. Anyway even the entry variant 911 is beyond my reach, so just empty talk only... 9 Link to post Share on other sites More sharing options...
SZ_ford 5th Gear May 22, 2020 Share May 22, 2020 im very curious, whats the purpose of targa? doesn't a cabriolet serve the same purpose? maybe someone can enlighten me. Never really a fan of the looks Link to post Share on other sites More sharing options...
inlinesix Hypersonic May 22, 2020 Share May 22, 2020 52 minutes ago, SZ_ford said: im very curious, whats the purpose of targa? doesn't a cabriolet serve the same purpose? maybe someone can enlighten me. Never really a fan of the looks Targa only removes the top only. It removes the need to install wind deflector for high speed driving. When roof is shut, Targa has less wind noise. 1 Link to post Share on other sites More sharing options...
SZ_ford 5th Gear May 22, 2020 Share May 22, 2020 6 hours ago, inlinesix said: Targa only removes the top only. It removes the need to install wind deflector for high speed driving. When roof is shut, Targa has less wind noise. then i have another question, where to put the cover? and when it rains? Link to post Share on other sites More sharing options...
inlinesix Hypersonic May 22, 2020 Share May 22, 2020 1 minute ago, SZ_ford said: then i have another question, where to put the cover? and when it rains? Go through the video. You get your answer Link to post Share on other sites More sharing options...
Throttle2 Supersonic May 23, 2020 Share May 23, 2020 On 5/18/2020 at 11:58 PM, Turboflat4 said: I don't think I like the Targa look much. Coupes are best but proper cabriolets are OK with the top down. But Targas just look 'off' to me. I would agree with that Link to post Share on other sites More sharing options...
Weez911 Supersonic May 23, 2020 Share May 23, 2020 My favourite Posche. Been in love since a ride in the 991 Targa S in autumn Munich a few years back. Awesome. This new Targa looks even cooler. 2 Link to post Share on other sites More sharing options...
Steptronic Supercharged May 23, 2020 Share May 23, 2020 Another issue with Targa is that it accumulates heat in that trapped area. Porsche's AC is not that powderful. Not so comfy (first hand experience) 2 Link to post Share on other sites More sharing options...
inlinesix Hypersonic June 3, 2020 Share June 3, 2020 Heritage Design Edition 1 Link to post Share on other sites More sharing options...
RadX Moderator June 3, 2020 Share June 3, 2020 On 5/23/2020 at 4:20 PM, Steptronic said: Another issue with Targa is that it accumulates heat in that trapped area. Porsche's AC is not that powderful. Not so comfy (first hand experience) chey noob open window la....🤣 2 Link to post Share on other sites More sharing options...
Steptronic Supercharged June 4, 2020 Share June 4, 2020 On 6/3/2020 at 6:06 PM, RadX said: chey noob open window la....🤣 lol. Will tell its new owner 😀 2 Link to post Share on other sites More sharing options...
inlinesix Hypersonic June 5, 2020 Share June 5, 2020 12 hours ago, Steptronic said: lol. Will tell its new owner 😀 Interesting to know whether accumulation of heat is due to long hour outdoor parking or long hour driving ↡ Advertisement Link to post Share on other sites More sharing options...
Porsche
Porsche
2019 2nd Generation Audi Q3
Porsche Says EVs Would Be Worse With Fake Gear Changes
