ismailmiller 1st Gear April 8, 2020 Share April 8, 2020 Hi, Anyone knows the rough price of a Toyota Altis 2008 Model Radiator Assembly? My Engine Coolant plastic connector broke due to corrosion. I will rather buy it myself to save some costs anyways. ↡ Advertisement Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator April 9, 2020 Share April 9, 2020 I don't think you can change the plastic connector like this for the radiator, It is tight-sealed to the aluminium part. if you dismantle it, it will be hard to be 100% sealed. I think another solution to it is to get a thinner copper pipe to connect back to the rubber pipe. With the help of silicone, I think it should work just fine. or smth like this. I am not a mechanic so don't just take my words. FInd out more from yourself too! Come back and share your repair! 1 Link to post Share on other sites More sharing options...
Beregond Supersonic April 9, 2020 Share April 9, 2020 (edited) 10 hours ago, ismailmiller said: Hi, Anyone knows the rough price of a Toyota Altis 2008 Model Radiator Assembly? My Engine Coolant plastic connector broke due to corrosion. I will rather buy it myself to save some costs anyways. orginal parts i not sure. oem parts with labour and coolant roughly 300-400. this is a very common fault for toyota. Edited April 9, 2020 by Beregond 1 Link to post Share on other sites More sharing options...
Kklim Supercharged April 9, 2020 Share April 9, 2020 You may be able to just replace the top part of the radiator. Did that for my Sylphy. 1 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic April 9, 2020 Share April 9, 2020 30 minutes ago, kobayashiGT said: I don't think you can change the plastic connector like this for the radiator, It is tight-sealed to the aluminium part. if you dismantle it, it will be hard to be 100% sealed. I think another solution to it is to get a thinner copper pipe to connect back to the rubber pipe. With the help of silicone, I think it should work just fine. or smth like this. I am not a mechanic so don't just take my words. FInd out more from yourself too! Come back and share your repair! The coolant is hot and under pressure, will need to find a suitable strong adhesive that can tahan heat, otherwise the connector might just pop out. 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic April 9, 2020 Share April 9, 2020 You will need to use a threading tool called a tap to thread the assembly before inserting this hose connector. Need to know what size is the rubber hose and how big the assembly (broken connection hole) can accommodate. You cant do it w/o the right knowledge and tools. 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic April 9, 2020 Share April 9, 2020 In the end, just get the part from stockist. Straight forward. 2 Link to post Share on other sites More sharing options...
ismailmiller 1st Gear April 9, 2020 Author Share April 9, 2020 Thanks guys, this cb period you can't buy parts from stockists.. So in the end I went to my regular workshop to get it fixed. Replaced new Radiator Assembly total damage about 400 bucks. 2 Link to post Share on other sites More sharing options...
Beregond Supersonic April 9, 2020 Share April 9, 2020 14 minutes ago, ismailmiller said: Thanks guys, this cb period you can't buy parts from stockists.. So in the end I went to my regular workshop to get it fixed. Replaced new Radiator Assembly total damage about 400 bucks. 👍ok la, most important is fix properly, car can move 1 Link to post Share on other sites More sharing options...
Gnahp Turbocharged April 9, 2020 Share April 9, 2020 don't bother to repair a leaky radiator as it won't last last time I replaced a Hyundai Getz radiator at home, the cost of the entire radiator assembly was $180 ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Toyota Corolla Cross
2022 Toyota bZ4X
2022 Toyota bZ4X
