Mkl22 Supersonic November 18, 2020 Share November 18, 2020 21 hours ago, shrjun said: Try explaining this to people who install 4-6 pot BBK 😂. Also we are in the cheap MIC 'I don't care for my life ' tyre thread MIC tires are not necessarily bad. you got to try to know. i have since been enlightened. ↡ Advertisement 1 1 Link to post Share on other sites More sharing options...
shrjun 5th Gear November 23, 2020 Share November 23, 2020 Here is someone who believes in cheap tyres 🤣 1 Link to post Share on other sites More sharing options...
RevStarZen 1st Gear November 23, 2020 Share November 23, 2020 2 hours ago, shrjun said: Here is someone who believes in cheap tyres 🤣 What’s wrong with cheap tyres?🤔 Cheap does not necessarily equate to lousy quality tyres as @Mkl22 had mentioned in previous post...🤣 1 4 Link to post Share on other sites More sharing options...
RevStarZen 1st Gear November 29, 2020 Share November 29, 2020 On 11/24/2020 at 7:55 AM, awhtc said: Worst Tire Brands to Avoid Purchasing in 2020 6 Worst Tire Brands to purchase Chaoyang Goodride Westlake AKS Tires Telluride Compass Tires https://mechanicbase.com/tires/tire-brands-to-avoid-purchasing/ I’m on one of the brand as mentioned and dun find it worse than a Firenza model previously which was really 🤦. 2 Link to post Share on other sites More sharing options...
Roberttan 5th Gear November 30, 2020 Share November 30, 2020 On 11/24/2020 at 7:55 AM, awhtc said: Worst Tire Brands to Avoid Purchasing in 2020 6 Worst Tire Brands to purchase Chaoyang Goodride Westlake AKS Tires Telluride Compass Tires https://mechanicbase.com/tires/tire-brands-to-avoid-purchasing/ OK SEEN westlake on numbers if Taxi on the road. other 4 brands never see here I think is nothing wrong to use this MIC tyre so long the QC is there . 1 1 Link to post Share on other sites More sharing options...
Kklim Supercharged November 30, 2020 Share November 30, 2020 Am on these: https://www.amazon.com/Westlake-RP18-Touring-Radial-Tire/dp/B00MZB4V16 (195/65/R15). Super quiet and very good wet and dry grip 👍 2 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator November 30, 2020 Share November 30, 2020 On 11/24/2020 at 7:55 AM, awhtc said: Worst Tire Brands to Avoid Purchasing in 2020 6 Worst Tire Brands to purchase Chaoyang Goodride Westlake AKS Tires Telluride Compass Tires https://mechanicbase.com/tires/tire-brands-to-avoid-purchasing/ AKS stand for Ang Kong Siao? Last time I have a friend name his company AKS because he is really an ang kong siao. 🤣 4 Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear November 30, 2020 Share November 30, 2020 1 hour ago, Roberttan said: OK SEEN westlake on numbers if Taxi on the road. other 4 brands never see here I think is nothing wrong to use this MIC tyre so long the QC is there . Problem is the QC is not up to standard. 1 Link to post Share on other sites More sharing options...
Karoon Turbocharged November 30, 2020 Share November 30, 2020 On 11/23/2020 at 8:27 AM, shrjun said: Here is someone who believes in cheap tyres 🤣 Maybe he is the importer.. sharing his belief with us so he can buy a 7-series 1 1 Link to post Share on other sites More sharing options...
Karoon Turbocharged November 30, 2020 Share November 30, 2020 On 10/28/2020 at 2:47 PM, Dpow7 said: whether to buy China tires becos its was cheaper that may hv cost my whole family life. Never again i will risk it. If you ever hv constant tires pressure leak always take it out totally to hv its inspect. both the rear tires has crack side walls What year/week is this tyre? Also, should do frequent thread depth check. Easiest way is this "Take a 50-cent coin, with the tails side facing you, and place it upright into the tire tread groove. If you are able to see the word “Singapore” while the coin is sat in the groove, the tire tread depth is too shallow and you are due to replace your tires." 1 1 Link to post Share on other sites More sharing options...
Fitvip Supersonic November 30, 2020 Share November 30, 2020 (edited) Tyre is not just brand. Model also makes a lot of difference. I have used Malaysian Silverstone. The side walls cracked when they were still very new. I changed to Pirreli P6 or something. Not bad. I have stuck to S-drive since, after switching to KU31 once. KU31's grip is not as good as S-Drive's from Yoko. Both tyres are noisy, but, S-Drive's grip is really good in both wet and dry. Unless some new tyres receive good reviews, I will not ditch S-Drive. My mechanic friend recommended Mchelin for its quietness. I have yet to try. Again, it also depends on the model. Not all Michelin tyres receive good reviews. Edited November 30, 2020 by Fitvip 3 Link to post Share on other sites More sharing options...
RevStarZen 1st Gear November 30, 2020 Share November 30, 2020 6 hours ago, Fitvip said: Tyre is not just brand. Model also makes a lot of difference. I have used Malaysian Silverstone. The side walls cracked when they were still very new. I changed to Pirreli P6 or something. Not bad. I have stuck to S-drive since, after switching to KU31 once. KU31's grip is not as good as S-Drive's from Yoko. Both tyres are noisy, but, S-Drive's grip is really good in both wet and dry. Unless some new tyres receive good reviews, I will not ditch S-Drive. My mechanic friend recommended Mchelin for its quietness. I have yet to try. Again, it also depends on the model. Not all Michelin tyres receive good reviews. If u’re looking for quiet Michelin tyres-Primacy 4 is your most common best bet at least in 🇸🇬. Google around to see mostly good reviews if u dun mind the pricing!😉 1 Link to post Share on other sites More sharing options...
Flying_genie 6th Gear November 30, 2020 Share November 30, 2020 11 hours ago, Fitvip said: Tyre is not just brand. Model also makes a lot of difference. I have used Malaysian Silverstone. The side walls cracked when they were still very new. I changed to Pirreli P6 or something. Not bad. I have stuck to S-drive since, after switching to KU31 once. KU31's grip is not as good as S-Drive's from Yoko. Both tyres are noisy, but, S-Drive's grip is really good in both wet and dry. Unless some new tyres receive good reviews, I will not ditch S-Drive. My mechanic friend recommended Mchelin for its quietness. I have yet to try. Again, it also depends on the model. Not all Michelin tyres receive good reviews. Agreed. I have used the Yokohama S-Drive too. These are good tyres. They are quiet and sticky, due to the soft rubber. Unfortunately, the softness also means that they wear out really fast. 2 Link to post Share on other sites More sharing options...
Zep Neutral Newbie December 10, 2020 Share December 10, 2020 I saw too many drivers using Tourador but none in the forum for a review....... Link to post Share on other sites More sharing options...
Beregond Supersonic December 10, 2020 Share December 10, 2020 4 minutes ago, Zep said: I saw too many drivers using Tourador but none in the forum for a review....... They diam diam using cheap and good tyres dun want share😂 4 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator December 10, 2020 Share December 10, 2020 Hahahha. This is quite funny! 3 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator December 11, 2020 Share December 11, 2020 seems like stamford is doing the same. 😂 Link to post Share on other sites More sharing options...
Tohto Hypersonic December 14, 2020 Share December 14, 2020 On 12/1/2020 at 2:10 AM, RevStarZen said: If u’re looking for quiet Michelin tyres-Primacy 4 is your most common best bet at least in 🇸🇬. Google around to see mostly good reviews if u dun mind the pricing!😉 The good thing about Primacy 4 is the low noise maintain even when tyre getting old. My current set 47k+ mileage, close to 2yrs. Noise still relatively low. Plan to change when hit 50kmeven though thread still ok. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Portable Tyre Pump
Portable Tyre Pump
Tyre puncture
Tyre puncture
Continental CSC 7.
Continental CSC 7.
