Sdf4786k Twincharged March 20, 2020 Share March 20, 2020 On 3/18/2020 at 1:55 AM, boonhat_91 said: Thanks all, starting to see a clearer picture now! So in theory only, you could just cut shorter and weld back your stock links if you lowered your ride? Expand for 200 dollars worth of parts.. dont waste time. ↡ Advertisement Link to post Share on other sites More sharing options...
meobleminibus 1st Gear March 20, 2020 Share March 20, 2020 On 3/16/2020 at 10:09 AM, kobayashiGT said: Why you need to change sway bar link when you change your coilover. Recently I have a chat with @Sdf4786k and we were discussing our rides. And then when we talk about the suspension, he enlightens me about a small yet important upgrade that is necessary for every car that has changed to a coilover. What is the Purpose of a Sway Bar Link? Automobiles are carefully designed by experts to help the users experience a smooth, comfortable, and safe ride. A sway bar link is a small but significant part of the complex mechanism that serves the purpose. The sway bar link allows the user of an automobile to adapt it in accordance with the type of terrain upon which it is to be driven. The bushings at the end of the links can be dismantled to remove the sway bar to prepare the vehicle for a rugged terrain and can be fitted back in while traversing the smoother roads. The horizontal leveling of the car, with the path it is being driven upon, is elementary to the comfort of its passengers. A long and hollow arched steel bar known as the sway bar or a stabilizer bar is fitted at the front and rear end of the vehicle to suffice for the purpose. Additionally, it ‘shifts’ the compression force from one end’s suspension to the other. This prevents the car from ‘flipping over’ while cornering at a bend in the path. The bar in itself is a torsional spring. As a counter action to the torsion produced in the bar due to irregularities of the driven path, the link at both the ends raise or lower the springs attached to the control arm of the wheel. A sway bar link can, therefore, be said to function in favor of smoothing the motion transfer between the sway bar and the control arms in the car’s suspension mechanism. Purpose of the Sway Bar Link While the driver tries to turn around a bend in a road, the suspension of the outer wheels is compressed relatively more than the suspension for the inner wheel. The inner wheel rises, but the axle attached to it lowers where the link is connected. The sway bar link transfers this change in the position of the control arm to the sway bar, which gets raised at that side. The sway bar undergoes torsion and gets twisted in order to resist the movement, and consequently the spring on the other side expands. Thus, the sway bar link transfers a change in spring compression to the sway bar that raises the spring constant for the other spring. In this manner, the difference in compression cancels out the total lean experienced by the car, and the horizontal alignment of the chassis with respect to the path remains parallel. In the absence of this action, the inner wheel of the vehicle would tend to take a wild spin and lose traction of the road. The sway bar link maintains the camber angle of the inner wheels to control its direction of motion. The portion highlighted is a sway bar link When the car is driven over a bump that extends over to both the opposite wheels (front or rear), then the sway bar does not do much, since the bump was equal. Equal and normal compressional forces are implied on the springs at both the ends of the sway bar. It is when either of the wheels out of the pairs present at the front or rear suffers a bump or a dip, then the sway bar links come into play. The change in the level of the wheel axle traverses through the links and enables the sway bar to twist so as to equalize the compression in the springs of the two ends. The net effect is that the ‘bump’ or ‘dip’ is spread evenly by the sway bar among the connected pair of wheels. To dampen these jerks, additional suspension elements are employed. Because of the differences in spring rate between a conventional shock absorber and aftermarket coilover, this upgrade should be done together when you are changing your coilover. So without further ado, I am now deciding which brand should I go for. 🤔 Hardrace from taiwan Tegiwa from UK. Most probably I will get from Hardrace, cause there is a dealer in Singapore. better be safe than sorry. hahah. Thanks @Sdf4786k 🙂 Expand This is good, interesting topic and information you posted. ↡ Advertisement Link to post Share on other sites More sharing options...
BC coilover servicing - Where and how much?
Best deal on car insurance! Instant cash for scrap car!
Gecko Performance Coilover $1300 Only (Usual $1500)
Any place to service coilover oil seal leak?
Need A Good WS To Raise My Coilover
