Kklee 6th Gear September 2, 2024 Share September 2, 2024 On 9/2/2024 at 12:59 PM, myfoot2024 said: Okay. Done. 1 hour job. I opted for normal gas instead of nitrogen! 🙂 Running on the new Yokohama ADVAN dB V552 now. 😙 IMHO. Enjoy ! Take note it will take a while to break-in. Yokohama India says < 80km/h for at least 100km. So how is the comfort level so far ? A bit on the harsh side? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
myfoot2024 1st Gear September 2, 2024 Share September 2, 2024 (edited) On 9/2/2024 at 1:44 PM, Kklee said: IMHO. Enjoy ! Take note it will take a while to break-in. Yokohama India says < 80km/h for at least 100km. So how is the comfort level so far ? A bit on the harsh side? I see. Okay. Got it. Don't know! The siao Mechanic pumped 40psi on both 4 tyres whereas the CN7 spec. stated front 35, rear 31 for normal load and front 35, rear 35 for heavy load. He said no worries. Tested just now at 80kmph on empty ECP section, turning steering wheel left. Right, centre. Pretty responsive and light, may be due to high 40 psi. They are really quiet. I could hear the difference from the road noise! Quieter than the stock aging Hankook tyres for the obvious reason. Tested braking. It is as good as normal. Anyway, I will pump down the tyres to may be 38psi or even lower at 36psi scarifying the wheel turning responsiveness for more softer ride. 40psi is crazily high although it gives very responsive wheel turning / cornering but more bumpy and danger for the obvious reason. Turning wheel at my car park produces zero sound now. 😙 Edited September 2, 2024 by myfoot2024 1 Link to post Share on other sites More sharing options...
Kklee 6th Gear September 2, 2024 Share September 2, 2024 On 9/2/2024 at 2:06 PM, myfoot2024 said: I see. Okay. Got it. Don't know! The siao Mechanic pumped 40psi on both 4 tyres whereas the CN7 spec. stated front 35, rear 31 for normal load and front 35, rear 35 for heavy load. He said no worries. Tested just now at 80kmph on empty ECP section, turning steering wheel left. Right, centre. Pretty responsive and light, may be due to high 40 psi. They are really quiet. I could hear the difference from the road noise! Quieter than the stock aging Hankook tyres for the obvious reason. Tested braking. It is as good as normal. Anyway, I will pump down the tyres to may be 38psi or even lower at 36psi scarifying the wheel turning responsiveness for more softer ride. 40psi is crazily high although it gives very responsive wheel turning / cornering but more bumpy and danger for the obvious reason. Turning wheel at my car park produces zero sound now. 😙 IMHO. When ambient/tyre temperature is hot, the pressure is higher. My cold tyre pressure and operating tyre pressure on a hot day, about 4.4 PSI difference. Best is to leave overnight and measure again the next morning. Zero sound means got traction. 👍 1 Link to post Share on other sites More sharing options...
myfoot2024 1st Gear September 2, 2024 Share September 2, 2024 (edited) On 9/2/2024 at 5:23 PM, Kklee said: IMHO. When ambient/tyre temperature is hot, the pressure is higher. My cold tyre pressure and operating tyre pressure on a hot day, about 4.4 PSI difference. Best is to leave overnight and measure again the next morning. Zero sound means got traction. 👍 I see! It's a super hot day today while I was testing the tyre just now! Anyway, I pumped them down to Front 36psi and Rear 35psi for the tine being now to see if I'm okay with the softness/comfy ride. If I still find it too hard the ride. I will pump them down further to Front 34, Rear 33. Edited September 2, 2024 by myfoot2024 Link to post Share on other sites More sharing options...
Kklee 6th Gear September 2, 2024 Share September 2, 2024 On 9/2/2024 at 5:36 PM, myfoot2024 said: I see! It's a super hot day today while I was testing the tyre just now! Anyway, I pumped them down to Front 36psi and Rear 35psi for the tine being now to see if I'm okay with the softness/comfy ride. If I still find it too hard the ride. I will pump them down further to Front 34, Rear 33. IMHO. Now u pump down, when cold, the pressure will be below the recommended. Need to take at least maybe 5 hours for the tyres to cool down to ambient. Link to post Share on other sites More sharing options...
myfoot2024 1st Gear September 2, 2024 Share September 2, 2024 On 9/2/2024 at 5:58 PM, Kklee said: IMHO. Now u pump down, when cold, the pressure will be below the recommended. Need to take at least maybe 5 hours for the tyres to cool down to ambient. I see. Okay, okay. I will monitor it and adjust it accordingly. Thanks. 1 Link to post Share on other sites More sharing options...
myfoot2024 1st Gear September 2, 2024 Share September 2, 2024 (edited) Anyway, just finished my first night driving on a relatively light traffic highway. The V552 is really a low noise tyre as I could even hear my already quite-silent CN7's engine roaring when stepped on the gas pedal. (I muted all media sound) to hear how silent the V552 was). A pretty impressive silent tyre indeed. 🙂 Also, since it was not much traffic on the highway. I did a few brake checks. The braking is more gentle and probably takes a few milliseconds longer than my previous stock tyre but it was a firm and controlled braking. Not an issue once one knows the braking behavior! Edited September 2, 2024 by myfoot2024 1 Link to post Share on other sites More sharing options...
badlammy 6th Gear September 2, 2024 Share September 2, 2024 I'm really amazed by the feedback documented. Wow. 1 Link to post Share on other sites More sharing options...
myfoot2024 1st Gear September 4, 2024 Share September 4, 2024 (edited) Okay! 3rd day after getting the new V552! All the 4 new tyres pressurse have been stabilized at Front 35psi (As per CN7 spec.), and Rear 32psi (I set it to 1psi higher than recommended by CN7). Just still don't get use to the braking behavior of the new tyres. It's a very firm, steady, total silent and controlled brake/stop unlike my previous old tyres which produced a short audible scratching sound right before the car comes to a complete brake/stop, being aging tyres. 😁 Cheers all! 🙂 Edited September 4, 2024 by myfoot2024 1 Link to post Share on other sites More sharing options...
sgjy Neutral Newbie September 13, 2024 Share September 13, 2024 (edited) New user here.Got a used CN7 yr2021 recently. Would love to join telegram. Please add me. @DioPqu Edited September 13, 2024 by sgjy 1 Link to post Share on other sites More sharing options...
RyanCN7 Neutral Newbie September 19, 2024 Share September 19, 2024 Hi, please add me into the telegram group! Just confirm my purchased CN7! Can't wait!! @Ryancn7 Link to post Share on other sites More sharing options...
myfoot2024 1st Gear September 20, 2024 Share September 20, 2024 (edited) Err... Please add me to the telegram also @kelvintino Thank you. Edited September 20, 2024 by myfoot2024 Link to post Share on other sites More sharing options...
tailtwist 3rd Gear September 21, 2024 Share September 21, 2024 On 7/30/2024 at 12:02 PM, draagonball said: I realize i forgot to enable adding to group from non-contact. Thanks for those who tried to add me before, can someone try to add me to the telegram group again? @SmilezGurl BTW ended up getting the new 2024 Avante Hybrid 😁 How's the new Avante Hybrid? S trim or Elite trim? Link to post Share on other sites More sharing options...
myfoot2024 1st Gear September 26, 2024 Share September 26, 2024 (edited) Today, sent my CN7 for the 6 months periodic service and since I'm there. I opted to install the new OBU screen package. Let's how it looks after getting my CN7 back in the afternoon. Creating a right hand forward corner blindspot for me? Let me see later .... Edited September 26, 2024 by myfoot2024 Link to post Share on other sites More sharing options...
myfoot2024 1st Gear September 26, 2024 Share September 26, 2024 (edited) Okay. As far as I'm concerned based on my seat position. The display doesn't create any significant blindspot on the forward right corner view. So, I'm perfectly okay with the ERP 2.0 display placement. https://imgur.com/a/BkBxBx7 Edited September 26, 2024 by myfoot2024 1 Link to post Share on other sites More sharing options...
sgjy Neutral Newbie October 4, 2024 Share October 4, 2024 My reverse camera give me blur fog image on right top corner. Wonder if it is inside or outside lens got problem. How do I dismate it properly? Link to post Share on other sites More sharing options...
Des29 Neutral Newbie October 9, 2024 Share October 9, 2024 Hi guys. I just got my CN7! What is the link for the telegram chat? Link to post Share on other sites More sharing options...
Des29 Neutral Newbie October 9, 2024 Share October 9, 2024 Please add me @prataman789 ↡ Advertisement Link to post Share on other sites More sharing options...
2022 Kia EV6
2022 Kia EV6
[Official] 2025 Hyundai Ioniq 9
About the new Hyundai Accent 1.4 litre
2021 5th Generation Mercedes Benz C-Class (W206)
Nissan N7
Nissan N7
