Chogokin 1st Gear February 27, 2020 Share February 27, 2020 Hi All, My ride is Altis 2008 model. Need advise from ppl here. Currently looking to upgrade from stock rim. Look at OZ rim, 17" 5x100, 7.5J +35 offset. Some shop say +35 too out , recommend +48. Got another shop say +35 flush with fender , say +48 too in. So duno if use offset +35 will there be any issue like will bua fender if go over hump al this ..... My car not lowered. Thanks Chogokin ↡ Advertisement Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator February 28, 2020 Share February 28, 2020 you can use this calculator as a rough gauge. https://tiresize.com/wheel-offset-calculator/ you are currently on 16" ? Link to post Share on other sites More sharing options...
Ct3833 Supersonic February 28, 2020 Share February 28, 2020 On 2/27/2020 at 2:48 PM, Chogokin said: Hi All, My ride is Altis 2008 model. Need advise from ppl here. Currently looking to upgrade from stock rim. Look at OZ rim, 17" 5x100, 7.5J +35 offset. Some shop say +35 too out , recommend +48. Got another shop say +35 flush with fender , say +48 too in. So duno if use offset +35 will there be any issue like will bua fender if go over hump al this ..... My car not lowered. Thanks Chogokin Expand What is your 2008 stock size and offset? Simple rule is from your current stock tyre width, for every 10 mm increase in new tyre width, you offset +5mm inward, but you may not exactly 5mm, so anything close to 5mm would be good. Experts here feel free to correct me if I am wrong. 1 Link to post Share on other sites More sharing options...
Chogokin 1st Gear February 28, 2020 Author Share February 28, 2020 On 2/27/2020 at 11:54 PM, yishunite said: I look up ur default and it says +39/40. Best to stick around this region. +35 still ok. +50 maybe a bit too in unless using wider tyres (7.5-8j) Expand The shop say stock rim should be +40 . I looking at OZ HyperGT 17", 7.5J either +48 or +35. offset .So now confused.... Link to post Share on other sites More sharing options...
Chogokin 1st Gear February 28, 2020 Author Share February 28, 2020 On 2/28/2020 at 5:22 AM, Ct3833 said: What is your 2008 stock size and offset? Simple rule is from your current stock tyre width, for every 10 mm increase in new tyre width, you offset +5mm inward, but you may not exactly 5mm, so anything close to 5mm would be good. Experts here feel free to correct me if I am wrong. Expand Currently on stock rim and tire profile 195/65/15. I looking at OZ HyperGT 17", 7.5J either +48 or +35. offset .So now confused.... Link to post Share on other sites More sharing options...
Ct3833 Supersonic February 28, 2020 Share February 28, 2020 (edited) On 2/28/2020 at 12:06 PM, Chogokin said: Currently on stock rim and tire profile 195/65/15. I looking at OZ HyperGT 17", 7.5J either +48 or +35. offset .So now confused.... Expand Use this for reference. Looks like for 7.5j 17" with a 215mm tyre, the offset should be +40. What tyre width are you reconsidering? https://www.wheel-size.com/size/toyota/corolla-altis/2008/ Edited February 28, 2020 by Ct3833 1 Link to post Share on other sites More sharing options...
Chogokin 1st Gear March 1, 2020 Author Share March 1, 2020 On 2/28/2020 at 1:13 PM, Ct3833 said: Use this for reference. Looks like for 7.5j 17" with a 215mm tyre, the offset should be +40. What tyre width are you reconsidering? https://www.wheel-size.com/size/toyota/corolla-altis/2008/ Expand 225mm tyre width and +35 offset Link to post Share on other sites More sharing options...
Ct3833 Supersonic March 1, 2020 Share March 1, 2020 On 3/1/2020 at 7:02 AM, Chogokin said: 225mm tyre width and +35 offset Expand if you refer back to the Altis rim offset spec, 225mm at 7.5J 17" should go with ET35. Link to post Share on other sites More sharing options...
Chogokin 1st Gear March 3, 2020 Author Share March 3, 2020 On 3/1/2020 at 2:48 PM, Ct3833 said: if you refer back to the Altis rim offset spec, 225mm at 7.5J 17" should go with ET35. Expand ok thks. Link to post Share on other sites More sharing options...
Roberttan 5th Gear March 5, 2020 Share March 5, 2020 On 2/27/2020 at 2:48 PM, Chogokin said: Hi All, My ride is Altis 2008 model. Need advise from ppl here. Currently looking to upgrade from stock rim. Look at OZ rim, 17" 5x100, 7.5J +35 offset. Some shop say +35 too out , recommend +48. Got another shop say +35 flush with fender , say +48 too in. So duno if use offset +35 will there be any issue like will bua fender if go over hump al this ..... My car not lowered. Thanks Chogokin Expand the information your collected is 99.99% correct. my only answer is Ask your self what do your want (not need) 1 issue you have to remember is the tire Size also. for me if I upgrade , I will do 225/45/17 with 7jx17 offset +40 Link to post Share on other sites More sharing options...
Chogokin 1st Gear March 7, 2020 Author Share March 7, 2020 On 3/5/2020 at 2:17 AM, Roberttan said: the information your collected is 99.99% correct. my only answer is Ask your self what do your want (not need) 1 issue you have to remember is the tire Size also. for me if I upgrade , I will do 225/45/17 with 7jx17 offset +40 Expand 7J with 225 tire will be buck out alot ? Link to post Share on other sites More sharing options...
Mkl22 Supersonic March 8, 2020 Share March 8, 2020 On 3/7/2020 at 5:32 PM, Chogokin said: 7J with 225 tire will be buck out alot ? Expand Yes. A 225 needs 7.5 to sit well. All the more at 45 profile. If 7in width rim, then 205-215 Link to post Share on other sites More sharing options...
ismailmiller 1st Gear March 10, 2020 Share March 10, 2020 225/45/r17.. This was the rim I used to use for my 2008 altis. But I downgraded cos of fuel consumption. This should work Link to post Share on other sites More sharing options...
Chogokin 1st Gear March 11, 2020 Author Share March 11, 2020 On 3/10/2020 at 12:30 PM, ismailmiller said: 225/45/r17.. This was the rim I used to use for my 2008 altis. But I downgraded cos of fuel consumption. This should work Expand Oh did i make the correct decision ? hahaha Link to post Share on other sites More sharing options...
Roberttan 5th Gear March 12, 2020 Share March 12, 2020 On 3/7/2020 at 5:32 PM, Chogokin said: 7J with 225 tire will be buck out alot ? Expand it depending the tires , some tire physically broader. ↡ Advertisement Link to post Share on other sites More sharing options...
