11 Reasons Why Diesel Trumps Gasoline
kobayashiGT
Internal Moderator
source: https://www.drivingline.com/articles/11-reasons-why-diesel-trumps-gasoline/
Occasionally, we like to stir the automotive pot, and this one is sure to do it! It’s the age-old diesel vs. gas debate—and it’s guaranteed to get a few of you into a verbal throw down. While both forms of propulsion have their place, diesel tends to dominate when big jobs have to be tackled as efficiently and reliably as possible (hence its preferential use in the military, construction, transportation and railroad industries). On the racing scene, gasoline engines have long held the throne in most categories.
However, in recent years, diesel technology has advanced at a rapid pace, which has only promoted further versatility—namely in 3/4-ton and 1-ton trucks. No longer are these oil-burners limited to workday chores. It’s now common to spot an 8,000lb, diesel-powered Ford, GM or Ram tearing through the quarter-mile in 13, 12, 11 and even 10-second intervals. Diesels have also begun to draw large crowds at chassis dyno competitions and headline the biggest sled pulls in the country. Once upon a time, the Audi R10 TDI even infiltrated (and dominated) the esteemed Le Mans racing series.
So, with diesel excelling in so many key areas, is it the better engine choice? Judging by the title, it’s pretty clear which side yours truly plays for, but whose side are you on? Diesel or Gas?
1. High Compression = More Power & Better Efficiency
001-gas-vs-diesel-compression-ratio.jpg?
What do OEM manufacturers, aftermarket enthusiasts and all-out race teams do to increase power and efficiency in their gas engines? They up compression. Diesels range from roughly 16.5:1 to 19:1 vs. gasoline’s typical 9:1 to 10:1. This means higher cylinder pressures (hello torque), a cleaner in-cylinder burn and—being that diesels rely on compression ignition rather than spark—no worry of pre-ignition or detonation.
2. No Throttle Plate
002-no-throttle-plate.jpg?quality=70&mod
Unlike a gasoline engine, a diesel doesn’t have a throttle plate (which should more appropriately be labeled a “restriction plate”). This means a diesel’s cylinders are packed completely full of air during every intake stroke, regardless of the driving or operating conditions. By contrast, the only time a gas engine breathes this well occurs under wide-open throttle instances. A lack of throttle (restriction) plate also means no pumping losses for the diesel engine. Did you know a gas engine expends as much as 40-percent of its total power output trying to overcome its own air (throttle) restriction?
3. Any-Purpose Engine
003-dodge-ram-3500-cummins.jpg?quality=7
No other internal combustion engine is as versatile as a diesel. For instance, only a diesel-powered pickup can be used as an all-in-one work truck, tow rig, sled puller, drag racer and daily commuter and remain as reliable as it was the day it left the factory. There are thousands upon thousands of diesel trucks making 500hp (1,000 lb-ft) or more that serve all of the above functions, not to mention that four-wheel drive models offer year-round drivability and off-road capability. The allure of a diesel engine is its do-anything nature.
4. Better Ingredients
004-man-v8-diesel-engine-internals.jpg?q
Because diesels feature high compression ratios, see high cylinder pressures and are typically turbocharged—they’re built with burlier parts to withstand all the stress. This means premium items like forged-steel connecting rods, four-bolt mains, six head bolts per cylinder, compacted graphite iron blocks... even bed plates make it into a lot of diesel engines. As well, nearly all heavy-duty diesel engines are gear-driven (no timing chains or belts).
5. Leaner Air-Fuel Ratio
005-air-fuel-ratio-gauge-auto-meter-phan
When you run a gasoline engine too lean you kill its power potential, run the risk of overheating or worse, melting a piston. In an effort to cool down combustion, gas engines will dump extra fuel at wide-open throttle. The complete opposite is true of a diesel. Lean out the fuel and the engine runs cooler. Add fuel to the mix and combustion temps and exhaust gas temperature goes up. This is why diesels run a leaner air-fuel ratio than gas engines. In fact, some diesels utilize an air-fuel ratio as high as 90:1 or 100:1 at idle. Optimum gasoline air-fuel mixtures usually check in around 15:1, while most diesels operate at 18:1 or higher.
6. Better, Safer Fuel
006-diesel-fuel-pump-tank.jpg?quality=70
Diesel fuel’s chemical makeup makes it at least 15-percent more energy dense than gasoline. On top of that, diesel fuel is oil-based, which essentially makes it a lubricant when introduced to cylinder walls. By contrast, gasoline is a solvent. Gasoline is also much more volatile than diesel (i.e. more explosive/flammable), which makes diesel much safer in the event of an accident.
7. They Aren’t Picky Eaters
007-m35-military-truck.jpg?quality=70&mo
Being that diesel is an oil-based fuel, it shouldn’t come as a surprise that virtually any oil-based alternative can be burned. We’ve seen diesel engines running on vegetable oil, grease, used engine oil and even automatic transmission fluid. But the diesel engine has always been capable of operating on alternative fuel sources. Case in point, the original diesel engine was designed to run on coal dust, but Rudolf Diesel subsequently found that it would also run (much more safely) on peanut oil.
8. Most Powerful
008-wartsila-sulzer-rta96c-diesel-engine
The most powerful engine in the world is diesel. Measuring approximately 90-feet long, 44-feet high and weighing some 2,300 tons, the Wartsila-Sulzer RTA96-C cranks out 109,000hp. The Finnish-designed, 14-cylinder, low-speed two-stroke diesel behemoth spins a maximum of 102 rpm, but generates as much as 80,080 KW of power—enough to power a moderately sized suburban town. Fitting for the world’s largest engine, the Wartsila-Sulzer RTA96-C is used to propel the largest ocean-going vessels in the world, such as 1,300-foot long, 70,000-ton cargo ships.
9. Big Torque at Low RPM
009-x15-cummins-engine-dyno-graph.jpg?qu
Thanks in part to the extreme cylinder pressures they see, most diesel engine’s produce their peak torque figure at or below 2,000 rpm. This not only makes diesel the ideal means of getting heavy loads up and moving quickly, but makes it easier for them to maintain speed while out on the highway. An abundance of low-rpm torque is also why 8,000lb diesel trucks can cut 1.5 to 1.8-second 60-foot times at the drag strip. While most gas power plants are just beginning to come to life between 3,000 and 4,000 rpm, a diesel is ready for the next gear. Living life at a lower rpm also lends itself to a diesel engine’s long-term durability.
10. A Mechanical Diesel is the Ultimate Doomsday Engine
010-dodge-cummins-12-valve-mechanical-di
Older, mechanically injected diesel engines are stupid simple and require virtually zero electronics to run. Once started, all a fully mechanical diesel needs to stay running is a steady supply of fuel. There is no need to worry about air, as once you fuel the engine the air will follow. If things ever go dark, you’ll find us driving something with a 12-valve 5.9L Cummins under the hood.
11. Diesel Makes the World Go Round
011-john-deere-equipment-chevy-duramax.j
Frankly, if diesel isn’t superior to gasoline, why do the construction, trucking, shipping, railroad, aviation and mining industries rely on it almost exclusively? And why does every branch of the military depend on it? It’s because diesel is more efficient, powerful, reliable and versatile. With the power of diesel, you can travel farther, get more work done and even use an alternative fuel source if you have to.
So, still think gas is best? Or is electric now the future? Join the conversation in comments below.
  Quote
My favorite diesel car is Land Rover Defender
Expand
  • Praise 6
If you believe in clean diesel and the multiple accolade that vw revived and was the envy of the car industry, then yes diesel was advance n good. So good in fact, that the new bmw was the weapon of choice for the 320D M sports performance no less.
  • Praise 2
Internal Moderator
Expand
I think the article is pointing out in term of power and efficiency. Definitely gasoline is "cleaner"  but comparing it with electricity that is zero-emission, the comparision never ends.
Modern diesel engines have a lot of things I dont like.
That enormous torque comes at a price. It's dependent on the highly pressurized fuel system and high compression (in the combustion chamber). So any leak from the seal/gaskets or any impurities in the diesel fuel it will cripple the system. That power lost feeling sucks. We know that seals/gaskets are wear and tear items that dont lasts forever.
Water or moisture issue. Any water or moisture content in the diesel will cause the fuel system or fuel injectors to rust and fail.
The black particulate is still an issue. The dpf or diesel particulate filter is something that is not perfect to deal with the issue. The fuel addictive to deal with the issue such as adblue just add to cost.
I'm not saying the petrol internal combustion engine is better but both have their pros and cons. I guess we have to see what turns us off more. Especially the type of engines that require more maintenance cost.
  • Praise 2
  On 12/19/2019 at 4:52 AM, Mustank said:
I just take which ever cheaper :grin:
Expand
Same here. I bought a diesel car because of cost... i'm quite a high mileage driver easily averaging 2+K per month. So far my 3+ yr diesel car is near 80K. So far so good....only normal wear n tear maintenance (tyres & brakes).
My fuel bill went down from $400+ to just a hair below $200. Save quite a lot on an annual basis.
  • Praise 4
  • Shocked 1
Expand
I rather like the turbo n the low end torque of diesel .. it’s cost effective IF u don’t load the Govt taxes
  • Praise 2
Expand
 It u add the Govt tax can become less cost effective. Wonder if there will be more changes to encourage diesel
Expand
Actually I keep hearing non-diesel car owners say about diesel tax as if it's like COE. Ok... the diesel tax is for my case about $400 more per year than if I drive a petrol car of equivalent engine CC. So that works out to be like $33 per month nia.
The enormous torque..
I used to drive Sunday legacy GT, 2l turbo petrol and now Jaguar XE 2l turbo diesel.
The GT had 230nm torque but the XE packs a massive 430nm. The pull is really shiok.
The BHP in diesel is lower.. 245bhp vs 180bhp.
FC also double. The GT was doing 6 to 7km/l but XE is about 14-5km/l.
One issue I don't quite like is the rpm range of a diesel. U need to shift up at 4.5k rpm.
Going downhill will require more frequent physical braking cos u reach the redline easily.
But given a choice all over again, I'll still choose a diesel car. With these tech advances the pollution should be more controlled than before
  • Praise 2
Expand
U need to clock more mileage in order to offset the higher road tax. I do about 25k annually and am already saving..
Expand
My car is Euro 5 compliant.. Don't need adblue. But dpf might be an issue if one consistently drive slowly and the crap gets clogged.
So far in my 3 years driving there's not a problem.
New models of XE is Euro 6, heard they now need to top it up every servicing
  • Praise 2
In SG, diesel only makes sense if your mileage driven can overcome:
1. Price difference of diesel car compared to petrol equivalent
2. Special diesel car road tax
3. Servicing cost? Not too sure about this part.
Other than that, diesel cars will never make sense to those marginal owners who hardly drive.
  • Praise 2
Expand
Nice car! I've been eyeing this model!
How's the drive as in the handling vs your previous legacy. The gearbox is ZF8?
  • Praise 2
Expand
XE feels more planted on the handling. More confident driving fast and turns.
Right now Wearnes is clearing stock for the new facelift to come in next month or so.
One thing..I believe they aren't bringing anymore diesel models, but u can still check with them to confirm.
  • Praise 2
Expand
My Kia Carens manual said that I need to drive at 65km/h for 5~10mins to clean the DPF.  If that did not happen, it will still start the process when the car is stationary and RPM will go high for the same duration.  2 years driving it, nothing happen lor.  DPF and Fuel Filter warning never even light up once lor.
