latisern2 Neutral Newbie October 18, 2019 Share October 18, 2019 I just recenlty got a COE lexus IS250. a, mot sure what fuel grade to pump so i just pump 98 to be safe, as i read on some manual that the min RON is 96. am i wasting money by pumping 98 ? ↡ Advertisement Link to post Share on other sites More sharing options...
Spring Moderator October 18, 2019 Share October 18, 2019 3 minutes ago, latisern2 said: I just recenlty got a COE lexus IS250. a, mot sure what fuel grade to pump so i just pump 98 to be safe, as i read on some manual that the min RON is 96. am i wasting money by pumping 98 ? We got no RON 96 so pump RON 98 is correct. U cant pump RON 95 since the manual says min RON 96. 4 Link to post Share on other sites More sharing options...
Angcheek Hypersonic October 18, 2019 Share October 18, 2019 1 hour ago, Spring said: We got no RON 96 so pump RON 98 is correct. U cant pump RON 95 since the manual says min RON 96. waaa Lexus so atas on petrol requirement ................. 3 1 Link to post Share on other sites More sharing options...
Mattchan Clutched December 28, 2019 Share December 28, 2019 How is a coe is250? What repair is done? Price? Link to post Share on other sites More sharing options...
ismailmiller 1st Gear November 14, 2020 Share November 14, 2020 I pumped 95 to my COE Lexus IS250. No issues leh. Power still okay. Getting around 11-11.4KM/L and full tank average between 650-700KM. Link to post Share on other sites More sharing options...
ER-3682 Twincharged November 15, 2020 Share November 15, 2020 95 could be use,but Performance may be down a bit....if there are ''Knocking'' detected..then better switch back to 98. Link to post Share on other sites More sharing options...
ismailmiller 1st Gear November 19, 2020 Share November 19, 2020 No knocking sound. Most lexus cars in US use Ron 92 only. Most important is using fully synthetic engine oil preferably 5W-30 for a bit more power and smoothness. Just once in a while pump V Power to clean the engine required Link to post Share on other sites More sharing options...
q1n3fer 1st Gear November 23, 2020 Share November 23, 2020 On 11/15/2020 at 2:00 AM, ismailmiller said: I pumped 95 to my COE Lexus IS250. No issues leh. Power still okay. Getting around 11-11.4KM/L and full tank average between 650-700KM. waa.. yr fc is good sia! am on 95 also. but getting 550 - 600 max. 9 - 10km/l usually Link to post Share on other sites More sharing options...
Toeknee_33 Turbocharged November 23, 2020 Share November 23, 2020 59 minutes ago, q1n3fer said: waa.. yr fc is good sia! am on 95 also. but getting 550 - 600 max. 9 - 10km/l usually 9 to 10km/l sounds about right. 11km/l is amazing. Link to post Share on other sites More sharing options...
q1n3fer 1st Gear November 23, 2020 Share November 23, 2020 1 hour ago, Toeknee_33 said: 9 to 10km/l sounds about right. 11km/l is amazing. haha ya! most prob his foot super light 1 Link to post Share on other sites More sharing options...
Mooose 6th Gear November 23, 2020 Share November 23, 2020 i had an IS250 years ago and had not problem with 95 petrol. Link to post Share on other sites More sharing options...
ismailmiller 1st Gear November 23, 2020 Share November 23, 2020 The trick is I removed the spare tires plus rims to lighten the boot load. A bit of light footing when I just got the car cos still new. After a while I usually whack the accelerator after light turns green. Also I usually slow down early before reaching the red traffic light. Usually expressway I do 90-100 or more depending on the traffic. Plus my car is still mostly stock.. Still using 17 inch. Maybe that's why still good FC. now using 5W-40 oil because I got gasket leak earlier which I only fixed recently. Next servicing will try 5W-30 oil to have better mileage. Try to also ensure tire pressure is based on the recommended pressure during cold weather. 1 Link to post Share on other sites More sharing options...
t0y0ta Supercharged November 24, 2020 Share November 24, 2020 6 hours ago, ismailmiller said: The trick is I removed the spare tires plus rims to lighten the boot load. A bit of light footing when I just got the car cos still new. After a while I usually whack the accelerator after light turns green. Also I usually slow down early before reaching the red traffic light. Usually expressway I do 90-100 or more depending on the traffic. Plus my car is still mostly stock.. Still using 17 inch. Maybe that's why still good FC. now using 5W-40 oil because I got gasket leak earlier which I only fixed recently. Next servicing will try 5W-30 oil to have better mileage. Try to also ensure tire pressure is based on the recommended pressure during cold weather. Yours is COE car? Any other major issues encountered? Link to post Share on other sites More sharing options...
Toeknee_33 Turbocharged November 24, 2020 Share November 24, 2020 16 hours ago, ismailmiller said: The trick is I removed the spare tires plus rims to lighten the boot load. A bit of light footing when I just got the car cos still new. After a while I usually whack the accelerator after light turns green. Also I usually slow down early before reaching the red traffic light. Usually expressway I do 90-100 or more depending on the traffic. Plus my car is still mostly stock.. Still using 17 inch. Maybe that's why still good FC. now using 5W-40 oil because I got gasket leak earlier which I only fixed recently. Next servicing will try 5W-30 oil to have better mileage. Try to also ensure tire pressure is based on the recommended pressure during cold weather. Removing spare tyre is quite an immoderate move to save fuel. And tyre pressures are to be checked when they are cold, nothing to do with the weather. I am no guru when it comes to engine oil, but I was told that for an older well run-in engine, best to use thicker oil for better protection. Do you measure your FC physically (ie full tank to empty tank vs mileage)? Or rely on onboard FC meter? Toyota FC meters are optimistic by about 5%. Link to post Share on other sites More sharing options...
ismailmiller 1st Gear November 28, 2020 Share November 28, 2020 I have done it in my previous altis which I scrap / sold off, it works because you reduce the weight of the car. 5W40 is thicker and is asked by workshops to use because it is more cheaper. Best to use the recommended original manufacturer EO. I measure physically. Calculation is done as follows; total distance traveled on meter divided by the amount of fuel pumped. I always made sure that the pump attendant fills the petrol fuel to the brim to ensure consistency in calculations. The car meter not that accurate. And yes this is a COE car, only 1 owner previously with 120K KM. ↡ Advertisement Link to post Share on other sites More sharing options...
2022 2nd Generation Lexus NX
[Official] 2024 Lexus LBX
2018 / 2019 7th Generation Lexus ES
2020 Lexus LC Convertible
Lightning strike damaged Lexus electronics and electrical systems, repair costs $220K
2024 2nd Generation Lexus LM
Buy your own car parts and auto accessories from Toyota & Lexus CarParts Stockist | Transglober Auto Pte Ltd
