Phluvcat 6th Gear June 9, 2019 Share June 9, 2019 (edited) My COE car dun have aux input, which is a no no in the modern times as I cannot play music from gadgets such as phones and ipods, etc. Hence completed a simple upgrade to improve the flexibility of the existing sound system and make full use of the speakers and tweeters which are pretty decent and good enough for me. I share my humble and cheapo DIY project with fellow bros. Appreciate suggestions if can improve the "setup", make it neater or more presentable. Hahahaha Edited June 16, 2019 by Lightsabre ↡ Advertisement 8 Link to post Share on other sites More sharing options...
Lplater 1st Gear June 10, 2019 Share June 10, 2019 My COE car dun have aux input, which is a no no in the modern times as I cannot play music from gadgets such as phones and ipods, etc. Hence completed a simple upgrade to improve the flexibility of the existing sound system and make full use of the speakers and tweeters which are pretty decent and good enough for me. I share my humble and cheapo DIY project with fellow bros. Appreciate suggestions if can improve the "setup", make it neater or more presentable. Hahahaha Cheaporest Car Audio System Upgrade.jpg interesting work done for your car. so with this done, does your CD changer still work? Or it wasn't linked to any changer at all from the start? Link to post Share on other sites More sharing options...
Phluvcat 6th Gear June 10, 2019 Author Share June 10, 2019 interesting work done for your car. so with this done, does your CD changer still work? Or it wasn't linked to any changer at all from the start? Good question. I actually do not use the CD changer as nowadays streaming music from gadgets is much more convenient. After I try I will update here. Previously the CD changer was functioning. There is a empty 6-8 socket at the soffit of the CD changer which I connect the aux adopter. Link to post Share on other sites More sharing options...
Fastfive1 5th Gear June 11, 2019 Share June 11, 2019 It would have been better to spend just under $200 for a proper headunit that has bluetooth, usb and aux. While you can save about 150 dollars going this route, this isn't really an upgrade. Link to post Share on other sites More sharing options...
Heartlander Turbocharged June 11, 2019 Share June 11, 2019 This at $88 brand new to me is a better upgrade: https://sg.carousell.com/p/pioneer-head-unit-232978713/?ref=search&ref_query=head%20unit%20&ref_referrer=%2Fsearch%2Fproducts%2F%3Fquery%3Dhead%2520unit%2520&ref_reqId=IyxlLBhFbBuhCL1MIaTizHdU99BRokEa If look for used ones even cheaper. 1 Link to post Share on other sites More sharing options...
Phluvcat 6th Gear June 11, 2019 Author Share June 11, 2019 It would have been better to spend just under $200 for a proper headunit that has bluetooth, usb and aux. While you can save about 150 dollars going this route, this isn't really an upgrade.Hahaha for me this is really all I need base on my usage from my previous car. The only thing I ever use is the radio and aux input (from handphones), not even bluetooth. Plus now I can switch 3 aux sources. And I do not wanna lose the huge compartment in place of a head unit,got a lot of stuff inside. 2 Link to post Share on other sites More sharing options...
inlinesix Hypersonic June 12, 2019 Share June 12, 2019 Taobao has some ciggy plug which has USB input and output via lalio. For my 1st 2 cars which has cassette tape, i only need to buy belkin ciggy adaptor to listen to ipod classic. 1 Link to post Share on other sites More sharing options...
Knoobie Supercharged June 12, 2019 Share June 12, 2019 TS you forgot most phones out there does not have 3.5mm audio jack.. Link to post Share on other sites More sharing options...
Ichibawa 5th Gear June 12, 2019 Share June 12, 2019 Since you have an aux in plug you might as well plug in a bluetooth dongle and hook up devices in a wireless manner. Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator June 12, 2019 Share June 12, 2019 still can plug into this! TS you forgot most phones out there does not have 3.5mm audio jack.. 2 Link to post Share on other sites More sharing options...
Fastfive1 5th Gear June 12, 2019 Share June 12, 2019 Hahaha for me this is really all I need base on my usage from my previous car. The only thing I ever use is the radio and aux input (from handphones), not even bluetooth. Plus now I can switch 3 aux sources. And I do not wanna lose the huge compartment in place of a head unit,got a lot of stuff inside. Link to post Share on other sites More sharing options...
Phluvcat 6th Gear June 12, 2019 Author Share June 12, 2019 Hmm what kind of stock headunit are you using? It's not a single din?Its built-in type, come with the car. If change very troublesome. For me this is the easiest route and still preserve my huge compartment below the audio system Link to post Share on other sites More sharing options...
Johnbrown June 25, 2019 Share June 25, 2019 I also wanted to upgrade my car audio system. Great experience shared by you. What about the product quality of car audio systems available in Amazon? Link to post Share on other sites More sharing options...
makeanewcall 3rd Gear June 28, 2019 Share June 28, 2019 Am dekitting my android atoto a6 pro headunit if anyone is keen! Link to post Share on other sites More sharing options...
Phluvcat 6th Gear July 9, 2019 Author Share July 9, 2019 Update: Bought a DAP and bluetooth receiver/transmitter all certified Hi-Res Wireless Audio. The bluetooth device expanded the flexibilty of car audio system. The DAP which has bluetooth, coaxial, LO, PO, etc connectivity, is mobile and I can use it in the car and at home, or any place which can receive stream of music be it wired or wireless. Now looking for a suitable audiophile app to further enhance the sound quality. I tried Neutron Player on my mobile, a lot of difference. Link to post Share on other sites More sharing options...
Kklim Supercharged July 9, 2019 Share July 9, 2019 My stock Clarion HU has AUX port but can't get it to work. Missing cable? Link to post Share on other sites More sharing options...
nineapple Neutral Newbie August 18, 2019 Share August 18, 2019 buy a bluetooth to Radio adpater is much easier and cheaper~~~ Link to post Share on other sites More sharing options...
Sdf4786k Twincharged August 18, 2019 Share August 18, 2019 https://sg.creative.com/p/speakers/sound-blaster-roar-2 Worth considering if you want to bypass all those wring and speaker upgrades. Only problem is need to power on after every time the car is started. But nowadays with spotify, I can bypass all those irritating DJs and use android auto... ↡ Advertisement Link to post Share on other sites More sharing options...
New Honda Shuttle 2015
[Concept] Honda 0 Series EVs
