What to do with torn $10 notes?
Bonafidestack
Anyone experience this before? I didn't check the note is passed to me by the hawker.
Then this morning when I take out my note i realised it's torn.
Nowadays not all bank have people station there. What do you all do with torn note? any tips?
if you return to the bank, this will probably worth only $8 plus.
that sneaky hawker very smart.... pass that torn bill to you... so in the end your lunch/dinner cost more now since that bill has been depreciated when one part of it had been "written off"
i thought pass it to the bank they will exchange with you, no?
Supersonic
go bank and change la. what a question. it's 10 bucks. if it is $2, then throw it away, no need to waste time.
I once received a 1USD coin instead of 1 SGD coin. Knn, kanna cheated. Threw the coin away also.
Supersonic
Tape it and go exchange with the bank. $10 for $10. If got issues, go MAS to do it.
As long as set of serial numbers intact, no problem. Otherwise can frame it or laminate it as a reminder to check the change, if u want to avoid the hassle.
Safe ride
Cheers
  • Praise 3
Safe ride
Cheers
Yes, just stick it with scotch tape and exchange at bank, or re-circulate by using it to purchase something after you've patched it.
Just note that with regards to serial numbers, if you wish to have a full refund of the amount - both sets of complete serial numbers must be on the note, If the note is half torn and only holds one full serial number and without / partial second serial number, you will only get half the amount.
  • Praise 3
Hypersonic
At least you receive torn notes can exchange one back .... I kenna coins in foreign currency, never usually check the coins until I come home or give other people then I kenna or later check ..... KNN kenna shortchange with Malaysian and even Thai one also got, by the time can’t remember which shop I also went
Edited by BanCoe
  • Praise 2
Hypersonic
Buy again from the same hawker and use the $10.
Did you give him a $50?
:D
