Fcw75 Hypersonic August 14, 2021 Share August 14, 2021 (edited) 54 minutes ago, Lala81 said: If u know the salesman, can find good deals that u can't get online one. I actually don’t want any salesman to kacau me at the physical shops but they keep asking. 😁 I just want to explore the products myself. Edited August 14, 2021 by Fcw75 ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic August 14, 2021 Share August 14, 2021 1 hour ago, yishunite said: Not exactly ... I recently bought LG washing machine from Courts and they had further slash the "sales" price that all the online sellers can beat or match... so turned out Courts still cheaper plus some freebies The price advertised by online sellers is before or after the cart voucher? Link to post Share on other sites More sharing options...
Fcw75 Hypersonic August 14, 2021 Share August 14, 2021 9 minutes ago, yishunite said: Even after. Difference was as much as $200+ for the model I went with Roughly it was something like this: RRP: $2,500 Courts sale price: $2,250 Online price: $2,100-2,200 Courts further price slash: $2,000 + freebie But you have to talk to salesman to find out Ok, noted bro. 😁 1 Link to post Share on other sites More sharing options...
Carbon82 Moderator August 14, 2021 Share August 14, 2021 18 hours ago, Sdf4786k said: Am using a Samsung washer /dryer WD8122CVB.. still going strong dispite the fact that it 11 years old. I just call Samsung to buy the Front door gasket. They mention no more parts avalable. So now on the hunt for another Washer / Dryer .. quite attracted to the PAnasonic but as I had pretty good experience with my current Samsung, I have short listed to 3 brands. Panasonic, LG and Samsung. Any clue which has the lowest retail cost for the same brand and model? Will probably try my luck at Harvey norman warehouse at Chai Chee Yes, you should go to Harvey Norman Chai Chee factory outlet. Look out for display set, which can be ~30% cheaper than BNIB unit. For washer, since they are typically not being operated during the period they are on display, the discount is too good to be ignored. My Panasonic was a display unit and so far so good *touch wood*. Actually do you often use the dryer function? My previous Samsung I only use for a few time (during prolong wet weather) and after a while, there is a "mouldy" smell whenever I use the function. Upon checking by the technician, what he said make perfect sense. The outer layer of the drum has all sort of dirt and mould sticking on the surface, yet we are not able to reach it to have it clean up. So when hot air blown through the holes on the drum, we are actually introducing the dirt and bacteria back to our newly washed laundry. 9 Link to post Share on other sites More sharing options...
Hamburger Hypersonic August 14, 2021 Share August 14, 2021 HN chai Chee is a good venue for domestic appliances that's with a R(refurbish) tag. Get ready though for a cold should as they might not be too eager to entertain as I suspect the commission for such type R products is minimum. 2 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged August 20, 2021 Share August 20, 2021 (edited) On 8/14/2021 at 11:48 AM, Carbon82 said: Yes, you should go to Harvey Norman Chai Chee factory outlet. Look out for display set, which can be ~30% cheaper than BNIB unit. For washer, since they are typically not being operated during the period they are on display, the discount is too good to be ignored. My Panasonic was a display unit and so far so good *touch wood*. Actually do you often use the dryer function? My previous Samsung I only use for a few time (during prolong wet weather) and after a while, there is a "mouldy" smell whenever I use the function. Upon checking by the technician, what he said make perfect sense. The outer layer of the drum has all sort of dirt and mould sticking on the surface, yet we are not able to reach it to have it clean up. So when hot air blown through the holes on the drum, we are actually introducing the dirt and bacteria back to our newly washed laundry. Thanks .. best price in Chai Chee is 1749 .. courts on line special $1819 but rebate 10 % to your next purchase.. so it should work out well for my mesh router IMG_4481.MP4 Edited August 20, 2021 by Sdf4786k 2 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic May 16, 2023 Share May 16, 2023 My old 10kg Panasonic washing machine is probably gone case. Need urgent replacement. Deciding between Toshiba (cheaper) and Panasonic front loader (9 to 11kg range). Anyone can comment on Toshiba washing machine? Vs Panasonic? I don't need anything fancy. Link to post Share on other sites More sharing options...
Lala81 Hypersonic May 16, 2023 Share May 16, 2023 (edited) On 5/16/2023 at 2:54 PM, Volvobrick said: My old 10kg Panasonic washing machine is probably gone case. Need urgent replacement. Deciding between Toshiba (cheaper) and Panasonic front loader (9 to 11kg range). Anyone can comment on Toshiba washing machine? Vs Panasonic? I don't need anything fancy. Get the cheaper one. I don't think Panasonic have long term reliable wm. Edited May 16, 2023 by Lala81 1 Link to post Share on other sites More sharing options...
Tohto Hypersonic May 16, 2023 Share May 16, 2023 On 5/16/2023 at 2:54 PM, Volvobrick said: My old 10kg Panasonic washing machine is probably gone case. Need urgent replacement. Deciding between Toshiba (cheaper) and Panasonic front loader (9 to 11kg range). Anyone can comment on Toshiba washing machine? Vs Panasonic? I don't need anything fancy. My current Samsung front loader washer + dryer coming to 8yrs. Still going good. 2 Link to post Share on other sites More sharing options...
inlinesix Hypersonic May 16, 2023 Share May 16, 2023 Harvey Norman has sale for 9.5kg front load Midea for $728 1 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic May 16, 2023 Share May 16, 2023 On 5/16/2023 at 2:56 PM, Lala81 said: Get the cheaper one. I don't think Panasonic have long term reliable wm. Looks like going to move onto Toshiba. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic October 5, 2023 Share October 5, 2023 Who got kenna this ah? 😅 https://mustsharenews.com/samsung-washer-dryer-shredded/?mibextid=Zxz2cZ 1 Link to post Share on other sites More sharing options...
Ender Hypersonic October 6, 2023 Share October 6, 2023 (edited) On 10/5/2023 at 7:02 PM, Fcw75 said: Who got kenna this ah? 😅 https://mustsharenews.com/samsung-washer-dryer-shredded/?mibextid=Zxz2cZ Last time, but damage not as jia lat as hers. We suspect it was those metallic zipper or hooks from some garment. So now we put those garments with any metallic parts in a laundry net before putting in the WM. Edited October 6, 2023 by Ender 3 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic October 6, 2023 Share October 6, 2023 (edited) On 10/6/2023 at 12:30 PM, Ender said: Last time, but damage not as jia lat as hers. We suspect it was those metallic zipper or hooks from some garment. So now we put those garments with any metallic parts in a laundry net before putting in the WM. Her one like got piranhas living inside. 🤪 Edited October 6, 2023 by Fcw75 1 Link to post Share on other sites More sharing options...
Lala81 Hypersonic October 6, 2023 Share October 6, 2023 On 10/6/2023 at 12:30 PM, Ender said: Last time, but damage not as jia lat as hers. We suspect it was those metallic zipper or hooks from some garment. So now we put those garments with any metallic parts in a laundry net before putting in the WM. hmm all my work pants got zip. My wife still conscientious will zip up all the zips before she put them into WM. I never bother one lol. 2 1 Link to post Share on other sites More sharing options...
Tohto Hypersonic October 6, 2023 Share October 6, 2023 (edited) Never have this type of problem on my Samsung Washer Dryer that use for many years. I think is the improper usage lah. Edited October 6, 2023 by Tohto 1 1 Link to post Share on other sites More sharing options...
Jman888 Moderator November 25, 2024 Share November 25, 2024 On 5/16/2023 at 2:54 PM, Volvobrick said: My old 10kg Panasonic washing machine is probably gone case. Need urgent replacement. Deciding between Toshiba (cheaper) and Panasonic front loader (9 to 11kg range). Anyone can comment on Toshiba washing machine? Vs Panasonic? I don't need anything fancy. last few days my 8yo samsung washer started to sound funny when spinning, and yesterday it cut off half way during spinning and left the laundry 80% dry, wanted to buy the same model from online but decide to go check out other brands. went HV at Millenia walk where they have almost every brands and models, we manage to talk to a salesperson who explained the details of almost every washers and some reasons for our washer to kaput. In the end we bought the Toshiba 12.5kg/8kg washer/dryer, didn't expect the machine come with dryer when we look at the model as we only want a bigger load. Good thing the $300 climate voucher still valid and HV top up another $100 of what energy voucher thingy. 3 Link to post Share on other sites More sharing options...
13177 Hypersonic November 25, 2024 Share November 25, 2024 On 11/25/2024 at 10:46 AM, Jman888 said: last few days my 8yo samsung washer started to sound funny when spinning, and yesterday it cut off half way during spinning and left the laundry 80% dry, wanted to buy the same model from online but decide to go check out other brands. went HV at Millenia walk where they have almost every brands and models, we manage to talk to a salesperson who explained the details of almost every washers and some reasons for our washer to kaput. In the end we bought the Toshiba 12.5kg/8kg washer/dryer, didn't expect the machine come with dryer when we look at the model as we only want a bigger load. Good thing the $300 climate voucher still valid and HV top up another $100 of what energy voucher thingy. Thought 2 in 1 washer/dryer not really recommended to buy? ↡ Advertisement Link to post Share on other sites More sharing options...
Human Washing Machine from Japan
Continental closing Alor Setar plant
Black flakes from washing machine
Washing machine repair
Asian Games 2023
Asian Games 2023
