Ronkovic 5th Gear June 6, 2019 Share June 6, 2019 I've been using the Miele front load for close to 10 years now. 2 full washing cycles per day - Ranging to kids clothes, normal regular clothes, to heavier stuff like jeans, bed sheets and even curtains. Pretty solid washing machine with various settings to suit different materials/cycles/timings, and a honeycomb drum which is gentle on the clothes. So far (touch wood) no major issues with it except 1 wear-and-tear replacement of the washing machine suspension. Another thing I like is that the build quality is great and the outer surfaces do not turn yellow like I've seen on other brands. For front loads, good maintenance is through ensuring that the rubber gaskets are always wiped dry after each wash to prevent warpage and accumulation of scum and mould. Also, it is preferred that low-suds detergent is used - Usually the most recommended would be Persil. From other relatives or friends' feedback, I hear the higher-end Electrolux models (Made in Italy ones, iirc) are also not bad. ↡ Advertisement Link to post Share on other sites More sharing options...
Carbon82 Moderator June 6, 2019 Share June 6, 2019 Front load or top load, it is all about physics (just observe what happened with the drum spin), so it is front load machine for me. I am currently using Panasonic NA-120VX6 (~13 months old), very satisfied with the quietness and performance so far. I dare to say that it is better than my previous Samsung washer (broke down after ~6 years) and on par with Bosch (expensive but durable - my 1st unit last me ~10 years)Washing powder wise, I have been toggling between these few brands, which worked well for me throughout the past 20+ years (across 4 different top load machines from Bosch - 2, Samsung - 1 and Panasonic - 1):1) Top (green packaging)2) Max Kleen (orange packaging)3) Persil4) SpinAs to which is my preferred choice, I follow my wallet. Now using this, which I bought in JB for ~RM28 (5Kg). 5 Link to post Share on other sites More sharing options...
Kb27 Supersonic June 6, 2019 Share June 6, 2019 Samsung AddWash add the top loader advantage to front loader https://www.samsung.com/sg/washing-machines/washer-ww90k6410qw/ Link to post Share on other sites More sharing options...
Silverkris 5th Gear June 6, 2019 Share June 6, 2019 Europe uses a lot of front load washing machine because they can just stack the dryer on top. Most washing machines has a good base to mount the dryer. Link to post Share on other sites More sharing options...
Ganwb79 5th Gear June 6, 2019 Share June 6, 2019 On 6/6/2019 at 6:48 AM, Watwheels said: Just have to look out for the low water and low power consumption. One thing to note when using a front loading washing machine. Use low sud washing powder instead of liquid washing detergent. Have been using Dynamo on my front load washer for years. Is there any reason liquid detergent is not good for front load? Link to post Share on other sites More sharing options...
MatthewOkamoto July 12, 2019 Share July 12, 2019 I think after using one machine for more than 15 years, one should go replacement in order to avoid emergency repair. As after a certain period of time, old devices unable to maintain a perfect efficiency and required more power to run. Link to post Share on other sites More sharing options...
Sdf4786k Twincharged August 13, 2021 Share August 13, 2021 On 6/6/2019 at 8:23 AM, Carbon82 said: Front load or top load, it is all about physics (just observe what happened with the drum spin), so it is front load machine for me. I am currently using Panasonic NA-120VX6 (~13 months old), very satisfied with the quietness and performance so far. I dare to say that it is better than my previous Samsung washer (broke down after ~6 years) and on par with Bosch (expensive but durable - my 1st unit last me ~10 years) Washing powder wise, I have been toggling between these few brands, which worked well for me throughout the past 20+ years (across 4 different top load machines from Bosch - 2, Samsung - 1 and Panasonic - 1): 1) Top (green packaging) 2) Max Kleen (orange packaging) 3) Persil 4) Spin As to which is my preferred choice, I follow my wallet. Now using this, which I bought in JB for ~RM28 (5Kg). Expand Am using a Samsung washer /dryer WD8122CVB.. still going strong dispite the fact that it 11 years old. I just call Samsung to buy the Front door gasket. They mention no more parts avalable. So now on the hunt for another Washer / Dryer .. quite attracted to the PAnasonic but as I had pretty good experience with my current Samsung, I have short listed to 3 brands. Panasonic, LG and Samsung. Any clue which has the lowest retail cost for the same brand and model? Will probably try my luck at Harvey norman warehouse at Chai Chee Link to post Share on other sites More sharing options...
Volvobrick Supersonic August 13, 2021 Share August 13, 2021 On 8/13/2021 at 8:45 AM, Sdf4786k said: Am using a Samsung washer /dryer WD8122CVB.. still going strong dispite the fact that it 11 years old. I just call Samsung to buy the Front door gasket. They mention no more parts avalable. So now on the hunt for another Washer / Dryer .. quite attracted to the PAnasonic but as I had pretty good experience with my current Samsung, I have short listed to 3 brands. Panasonic, LG and Samsung. Any clue which has the lowest retail cost for the same brand and model? Will probably try my luck at Harvey norman warehouse at Chai Chee Expand Have a Panasonic which has been around for quite a few years already, longer than the last Electrolux. Seems reliable. 2 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged August 13, 2021 Share August 13, 2021 On 8/13/2021 at 9:21 AM, Volvobrick said: Have a Panasonic which has been around for quite a few years already, longer than the last Electrolux. Seems reliable. Expand looks like there is some love for panasonic.. Have your gasket give u problems? Link to post Share on other sites More sharing options...
Twister 5th Gear August 13, 2021 Share August 13, 2021 On 8/13/2021 at 8:45 AM, Sdf4786k said: Am using a Samsung washer /dryer WD8122CVB.. still going strong dispite the fact that it 11 years old. I just call Samsung to buy the Front door gasket. They mention no more parts avalable. So now on the hunt for another Washer / Dryer .. quite attracted to the PAnasonic but as I had pretty good experience with my current Samsung, I have short listed to 3 brands. Panasonic, LG and Samsung. Any clue which has the lowest retail cost for the same brand and model? Will probably try my luck at Harvey norman warehouse at Chai Chee Expand Can try ParisSilk. IIRC, they provide free delivery and disposal of old machine. Usually can negotiate a bit off the price. 1 Link to post Share on other sites More sharing options...
Volvobrick Supersonic August 13, 2021 Share August 13, 2021 On 8/13/2021 at 10:24 AM, Sdf4786k said: looks like there is some love for panasonic.. Have your gasket give u problems? Expand So far so good. 1 Link to post Share on other sites More sharing options...
Blueray Hypersonic August 13, 2021 Share August 13, 2021 used my previous Panasonic front loader for 7 years. Motor was working fine, just that belt was slipping sometimes and the rust became more apparent and started minor leaking. so ordered a new Panasonic front loader from Panasonic Store on Shopee after CNY during Shopee home appliances sale. 4 Link to post Share on other sites More sharing options...
Kxbc Turbocharged August 13, 2021 Share August 13, 2021 I am using SS add load front loader for the past two years. So far so good. I think the main thing to ensuring long life is not to overload the machine. And buy the biggest capacity you can afford since you will reduce the chance of overload. My old 6kg Electrolux was serving me well for 7 years till I overloaded it many times, causing it to malfunction. My new 9kg SS surprisingly has a similar footprint as the lower capacity Electrolux. 3 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic August 14, 2021 Share August 14, 2021 (edited) I bought a fridge recently and I realized the best price is buying online. Qoo, Lazada or Shopee. Just have the brand and model you have in mind. I bought from Qoo in the end because they have voucher $100 off minimum $900. Keep a lookout. Bought from Audio House at Qoo in the end. Edited August 14, 2021 by Fcw75 5 Link to post Share on other sites More sharing options...
Lala81 Hypersonic August 14, 2021 Share August 14, 2021 (edited) Bosch > LG/Electrolux > Samsung/Panny That being said, all of them won't last super long. Expect a superior white goods machine nowadays to last about 6-7 years without issue at best. Get a 5 year extended warranty for front loaders. For top loaders just buy and throw. All the brands we have here are the same as they get in Australia more or less. There is one review site over there. I believe mustank junked his SS front loader within a few years. For those people expecting your current product to last as long as the previous one, sorry to say this isnt AC. Internationally, white goods are the most often junked household appliances. Edited August 14, 2021 by Lala81 3 Link to post Share on other sites More sharing options...
Lala81 Hypersonic August 14, 2021 Share August 14, 2021 https://www.productreview.com.au/c/front-loading-washing-machines?brands[0]=Fisher %26 Paykel||fisher-paykel||c285ddc6-cfd8-36bf-b1af-506b8a7fd264&brands[1]=LG||lg||95f9d0e0-06cd-32e8-912d-27f2e995d494&brands[2]=Samsung||samsung||4b5ad250-5aa7-38fc-b388-2e6f3cd61eea&brands[3]=Bosch Home Appliances||bosch||b4f46095-f770-3cfd-a83d-ca59ced77751&brands[4]=Electrolux||electrolux||b9103498-8722-31ae-9a71-f35b3a8c2a79&brands[5]=Haier||haier||d5ba7cde-5c64-3936-a71c-44f9efb67a65&price[0]=59900&price[1]=269900&94fa71be-855f-440c-b353-4632d910ab57[0]=5.5&94fa71be-855f-440c-b353-4632d910ab57[1]=10&sort=numberOfReviews Looks like panasonic exited the Aussie market, not available for selection. F&P is generally the favorite but they have limited models here. 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic August 14, 2021 Share August 14, 2021 We have good experience with electrolux front loading ($600, made in Italy). My mother bought the first one over 30 yrs ago. We decided to replace it, bcuz the handle (design) was not reliable at 12 yrs old. After a myriad of other brands (Bosch, F&P, SS), I'm back with electrolux ($550 made in Thailand), and still using. I'll never buy another Bosch again. It was the most expensive at $2k, and I had to replace the shocks every 2 yrs. Otherwise, it jump around during spin cycle. 3 Link to post Share on other sites More sharing options...
Lala81 Hypersonic August 14, 2021 Share August 14, 2021 If u know the salesman, can find good deals that u can't get online one. ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Black flakes from washing machine
Washing machine repair
Asian Games 2023
Asian Games 2023
Continental ExtremeContact Sport 02 Challenges Michelin Pilot Sport 4S
