Mkl22 Supersonic June 6, 2019 Share June 6, 2019 (edited) Just had a brisk run on the north south highway and there’s a vibration at higher speeds I’m guessing it has something to do with the new tires? Any place which does a good balancing? KL or SG? KL. Not balancing, but I did my alignment at a continental shop and it was spot on. it was only $30RM. Edited June 6, 2019 by Mkl22 ↡ Advertisement Link to post Share on other sites More sharing options...
therock Supersonic June 6, 2019 Author Share June 6, 2019 KL. Not balancing, but I did my alignment at a continental shop and it was spot on. it was only $30RM.Do you have a name for this shop bro? Thanks Link to post Share on other sites More sharing options...
Mkl22 Supersonic June 6, 2019 Share June 6, 2019 Do you have a name for this shop bro? Thanks ðFew years ago. Can’t remember. Sorry Link to post Share on other sites More sharing options...
therock Supersonic June 7, 2019 Author Share June 7, 2019 Anyone knows a place in KL? Thanks Link to post Share on other sites More sharing options...
therock Supersonic June 8, 2019 Author Share June 8, 2019 Found a place Hup Shun in Subang Jaya Did high speed balancing and wheel alignment They also weighed the wheels and cleaned them Very pro but not so cheap Nice chap M$400 for PS4 - cheap? $140m Link to post Share on other sites More sharing options...
Columbian78 6th Gear June 30, 2019 Share June 30, 2019 Any recommendations for a 12V car powered tire pump and tire repair kit? I am looking at the steelmate PO3 at the moment, around $70. Usually how long it takes to fully inflat a flat tyre using these 12V powered pump? Link to post Share on other sites More sharing options...
Adrianli Hypersonic June 30, 2019 Share June 30, 2019 Any recommendations for a 12V car powered tire pump and tire repair kit? I am looking at the steelmate PO3 at the moment, around $70. Usually how long it takes to fully inflat a flat tyre using these 12V powered pump? I am using this, bought from Qoo10. It works but not yet pump my car tyres from flat before. Used to pump bicycle tyre and football, no problem at all. Pretty silent too. https://youtu.be/p1mehvLU_UE 3 Link to post Share on other sites More sharing options...
Mkl22 Supersonic June 30, 2019 Share June 30, 2019 Any recommendations for a 12V car powered tire pump and tire repair kit? I am looking at the steelmate PO3 at the moment, around $70. Usually how long it takes to fully inflat a flat tyre using these 12V powered pump? Bought viair 87p from amazon. Used it once. Was quite fast. Pumped up in 2-3mins max. Didn’t want the cig lighter version as the fuse might pop and then you are screwed in an emergency. 1 Link to post Share on other sites More sharing options...
Roberttan 5th Gear July 1, 2019 Share July 1, 2019 Any recommendations for a 12V car powered tire pump and tire repair kit? I am looking at the steelmate PO3 at the moment, around $70. Usually how long it takes to fully inflat a flat tyre using these 12V powered pump? used it before and find it very efficient , it takes around 2 to 5 mins depending the size of your tire (volume ) is always good to do a dry run every 3 months. I am using this, bought from Qoo10. It works but not yet pump my car tyres from flat before. Used to pump bicycle tyre and football, no problem at all. Pretty silent too. https://youtu.be/p1mehvLU_UE had used before , still the power source from your car power point more reliable MHO 1 Link to post Share on other sites More sharing options...
Columbian78 6th Gear July 1, 2019 Share July 1, 2019 Update. I bought the steelmate PO3 at autobacs cos it is on offer $49.90. Quite small and easy to store cos it all winds up to 1 small square box. Link to post Share on other sites More sharing options...
Albeniz Turbocharged February 6, 2021 Share February 6, 2021 (edited) Dear folks, After owning and driving a few cars for more than 23 years, I still have 2 noob questions about spare tyres. I have almost never checked the condition of my spare. My 4 normal tyres are inflated with the pump usually set at 32psi. During inflating, the weight of the whole car is pressing against these 4 tyres. For spare tyre: 1. When pumping this standalone tyre (without any car weight acting on it), do we also set the pump at 32psi? 2. Can we inflate the spare tyre directly at the car boot without taking it out? -> Too strenuous to take it out for old uncle like me. Many thanks. Edited February 6, 2021 by Albeniz Link to post Share on other sites More sharing options...
Mkl22 Supersonic February 6, 2021 Share February 6, 2021 31 minutes ago, Albeniz said: Dear folks, After owning and driving a few cars for more than 23 years, I still have 2 noob questions about spare tyres. I have almost never checked the condition of my spare. My 4 normal tyres are inflated with the pump usually set at 32psi. During inflating, the weight of the whole car is pressing against these 4 tyres. For spare tyre: 1. When pumping this standalone tyre (without any car weight acting on it), do we also set the pump at 32psi? 2. Can we inflate the spare tyre directly at the car boot without taking it out? -> Too strenuous to take it out for old uncle like me. Many thanks. Depends on if the spare is a slim compact type. Typically with a blue, yellow or red rim. Those need to be pumped at a higher pressure. If not then, 32 psi or slightly higher for the spare. I would pump it higher so that I don’t have to pump it so often. Of course you can leave it inside when pumping. On another note, forget about the spare when traveling in Singapore. I have never encountered a massive puncture or blow out. You just need a TPMS and pump up the tire when the TPMS screams and hobble to a tire shop to get it mended. Heck typically the air will hold for a day after you pump it up as long as you don’t itchy and touch the nail or screw embedded. unless you are very unlucky to have a blow out, then that is when the spare comes in handy. 2 Link to post Share on other sites More sharing options...
Albeniz Turbocharged February 6, 2021 Share February 6, 2021 Very true. Indeed, throughout my 23 years, there was only once when the spare tyre was activated. I parked the car for more than 12 hours and it was completely flat, at that time. Link to post Share on other sites More sharing options...
Roberttan 5th Gear February 9, 2021 Share February 9, 2021 On 2/6/2021 at 11:38 AM, Albeniz said: Dear folks, After owning and driving a few cars for more than 23 years, I still have 2 noob questions about spare tyres. I have almost never checked the condition of my spare. My 4 normal tyres are inflated with the pump usually set at 32psi. During inflating, the weight of the whole car is pressing against these 4 tyres. For spare tyre: 1. When pumping this standalone tyre (without any car weight acting on it), do we also set the pump at 32psi? 2. Can we inflate the spare tyre directly at the car boot without taking it out? -> Too strenuous to take it out for old uncle like me. Many thanks. is very common for most driver not to check his spare tire. please get to workshop to check your spare tire pressure whenever you are there to buy new tires. i always inflat to 40psi for normal tire 60 psi for compact spare ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Stockist for Genuine Toyota Spare Parts?
Do I need to change tire ?
Tire patching types and prices
Spare tire. do u remove or leave in boot?
Continental's New Sustainable Tire Concept Revealed At Munich
Top Quiet Car
Top Quiet Car
