Discoburg Supersonic April 21, 2019 Share April 21, 2019 Anyone using the above mentioned router from Starhub? Any reviews of it? Am planning a purchase for a new router. Currently using the Asus AC68U. The wifi connection in my master room is very bad once the door closes. worse is when the Mrs and I are using our individual iPads or Macs. ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Ash2017 Twincharged April 21, 2019 Share April 21, 2019 Anyone using the above mentioned router from Starhub? Any reviews of it? Am planning a purchase for a new router. Currently using the Asus AC68U. The wifi connection in my master room is very bad once the door closes. worse is when the Mrs and I are using our individual iPads or Macs. I always though when door close you would be very busy and no time for surfing 7 Link to post Share on other sites More sharing options...
Discoburg Supersonic April 21, 2019 Author Share April 21, 2019 Sigh, now old liao. Need to google for some porn to start the business behind close door. I always though when door close you would be very busy and no time for surfing Link to post Share on other sites More sharing options...
Lala81 Hypersonic April 21, 2019 Share April 21, 2019 Ac routers can only do so much. You may want to consider a mesh router if still not good reception. I don't have one since I use a separate ac router for my room but my friend recommends. Link to post Share on other sites More sharing options...
Discoburg Supersonic April 21, 2019 Author Share April 21, 2019 Don't wish to spend that much and mine is just a 5 room HDB flat. Not THAT big either. Ac routers can only do so much. You may want to consider a mesh router if still not good reception.I don't have one since I use a separate ac router for my room but my friend recommends. Link to post Share on other sites More sharing options...
Ghgan 6th Gear April 21, 2019 Share April 21, 2019 (edited) You can consider Asus RT-AC88U or NETGEAR Nighthawk X4S R7800 for an all in one router solution as compare to mesh access point. Having said that, you need to place the router to be at the center of your house to have the best coverage. If you have too many wall to your bedroom, then mesh access point is the only solution. Edited April 21, 2019 by Ghgan 1 Link to post Share on other sites More sharing options...
Lala81 Hypersonic April 21, 2019 Share April 21, 2019 Don't wish to spend that much and mine is just a 5 room HDB flat. Not THAT big either. Why not just put a long cat 6 lan cable and put your router in the middle room of your flat. I live in 5 room. But my router is in living room. But if its in the middle or 3rd bedroom, my room will have WiFi.If not use mesh. Link to post Share on other sites More sharing options...
Discoburg Supersonic April 21, 2019 Author Share April 21, 2019 Great idea. I should pull lan cables into all rooms. That settles it. Why not just put a long cat 6 lan cable and put your router in the middle room of your flat. I live in 5 room. But my router is in living room. But if its in the middle or 3rd bedroom, my room will have WiFi.If not use mesh. 1 Link to post Share on other sites More sharing options...
Ender Hypersonic April 21, 2019 Share April 21, 2019 (edited) Anyone using the above mentioned router from Starhub? Any reviews of it? Am planning a purchase for a new router. Currently using the Asus AC68U. The wifi connection in my master room is very bad once the door closes. worse is when the Mrs and I are using our individual iPads or Macs. I am using the same AC68u router and I find the reach to every corner of my HDB flat decent. It's located centrally in my living room. Using WIFI Master apps. I measured at my toilet with one wall partition, signal is still at 65%. And washing machine area (furthest reach with one wall partition) at around 48%. Both have decent speed. If I changed to 2.4 ghz, the strength at the toilet is 94% (excellent rating) and washing machine area 85%. I played with the antenna positions, until I see the signal strength rises. And my WIFI ECO mode is turned on, i.e. the power is at reduced mode to save electricity. I attached the picture of my final antenna positions for maximum signal strength across my house. It just happens to be the recommended one from website. Edited April 21, 2019 by Ender Link to post Share on other sites More sharing options...
Jamesc Hypersonic April 21, 2019 Share April 21, 2019 My router has 4 antenna and after 4 beers I am sure the signal was stronger. 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic April 21, 2019 Share April 21, 2019 Not sure whether red cans are better or blues cans are better so maybe try both to see which one gives a better signal. Link to post Share on other sites More sharing options...
Jamesc Hypersonic April 21, 2019 Share April 21, 2019 If anyone don't drink beer I can come to your place to help you. Better if you have those 8 antenna routers. Link to post Share on other sites More sharing options...
zipping Supersonic April 21, 2019 Share April 21, 2019 tested e ea8100....i can still get good signal (3/4 bar on 2.4Mhz, 1/4 to 1/2 bar on 5Mhz) in e bdrm w closed doors fr e living room pass 2 solid walls. Cost $ Or...since u alr hav an Asus AC68U...get another Asus AC68U to link it up on Mesh system, which of cos will giv you good signal str but more $$$$ 3 Link to post Share on other sites More sharing options...
Kb27 Supersonic April 21, 2019 Share April 21, 2019 (edited) Use the 2.4GHz band, if you have problem connecting. The higher the frequency, the shorter the range, like 5GHz. Edited April 21, 2019 by Kb27 Link to post Share on other sites More sharing options...
Kusje Supersonic April 21, 2019 Share April 21, 2019 Great idea. I should pull lan cables into all rooms. That settles it. Is yours a very old HDB? Newer HDBs already have lan cables in each room. Just need to change the faceplate for the phone lines. Anyone using the above mentioned router from Starhub? Any reviews of it? Am planning a purchase for a new router. Currently using the Asus AC68U. The wifi connection in my master room is very bad once the door closes. worse is when the Mrs and I are using our individual iPads or Macs. You can buy the EA8100 for like 60 bucks on caoursell Link to post Share on other sites More sharing options...
Discoburg Supersonic April 21, 2019 Author Share April 21, 2019 I am using the same AC68u router and I find the reach to every corner of my HDB flat decent. It's located centrally in my living room. Using WIFI Master apps. I measured at my toilet with one wall partition, signal is still at 65%. And washing machine area (furthest reach with one wall partition) at around 48%. Both have decent speed. If I changed to 2.4 ghz, the strength at the toilet is 94% (excellent rating) and washing machine area 85%. I played with the antenna positions, until I see the signal strength rises. And my WIFI ECO mode is turned on, i.e. the power is at reduced mode to save electricity. I attached the picture of my final antenna positions for maximum signal strength across my house. It just happens to be the recommended one from website. Problem is the router is in the foyer. Didn’t want the OpenNet cables to run through my living room after the Reno I paid for to hide all cables, wires and PowerPoint. Use the 2.4GHz band, if you have problem connecting. The higher the frequency, the shorter the range, like 5GHz. Only use 5ghz for products in the living room. Is yours a very old HDB? Newer HDBs already have lan cables in each room. Just need to change the faceplate for the phone lines. You can buy the EA8100 for like 60 bucks on caoursell It’s kinda old, maybe 15+ years old already. Yeah I saw that price tag in Carousell. Some member here wanted to sell it to me at $90. Link to post Share on other sites More sharing options...
Freeder Hypersonic April 21, 2019 Share April 21, 2019 Problem is the router is in the foyer. Didn’t want the OpenNet cables to run through my living room after the Reno I paid for to hide all cables, wires and PowerPoint. Only use 5ghz for products in the living room. It’s kinda old, maybe 15+ years old already. Yeah I saw that price tag in Carousell. Some member here wanted to sell it to me at $90. 2 Link to post Share on other sites More sharing options...
1fast1 Supersonic April 21, 2019 Share April 21, 2019 If anyone don't drink beer I can come to your place to help you. Better if you have those 8 antenna routers. I don't know if the signal strength is better. But after many beers, the porn quality certainly looks better. But don't use too many beers. The antenna may not be able to remain upright. And I don't like the 8 antenna one. If I wanted something that looked like a dead spider, I just have to look behind the cabinet on which my router sits. That area is hard to clean. ↡ Advertisement Link to post Share on other sites More sharing options...
Fibre broadband
Fibre broadband
StarHub customers affected by home broadband disruption can register for one-time 20% rebate on monthly fee
Better router or wifi extender
Wireless Portable Speaker For Home Entertainment System
Starhub Free viewing
Issue with starhub simcard
Car wireless charger...
