Evillusion Supersonic November 24, 2018 Share November 24, 2018 On 11/24/2018 at 3:31 PM, Privacy said: i aspires to be like you when im older n retired.... spend a good afternoon doing things that i would never have done when i was younger... but whenever i tries to repair something it will end up worse. some people just don't have the touch! haha i not retired yet.....still have more than a decade if follow our cpf rule.... ↡ Advertisement Link to post Share on other sites More sharing options...
Vratenza Supersonic November 25, 2018 Share November 25, 2018 It is actually a software that needs to be installed and operated within a vpn environment. I bought it from an eBay seller ... This is an example: Reveal hidden contents https://www.ebay.com/itm/For-MERCEDES-BENZ-ALL-MODELS-SERVICE-REPAIR-WORKSHOP-MANUAL-1982-2017-/252522124225 This is mainly a very detailed manual which covers all mercedes models produced to date. Like where and in what sequence to remove the parts to an area. The parts numbers so that you can order the spare parts or accessories. On 11/24/2018 at 10:57 AM, Ct3833 said: hi, can share lobang in case i need one? So far my workshop is able to OBD dump and workshops like Sonic Racing is able to SW upgrade, but any better lobang would be appreciated . 1 Link to post Share on other sites More sharing options...
Heartlander Turbocharged November 25, 2018 Share November 25, 2018 On 11/25/2018 at 12:25 AM, Vratenza said: It is actually a software that needs to be installed and operated within a vpn environment. I bought it from an eBay seller ... This is an example: Reveal hidden contents https://www.ebay.com/itm/For-MERCEDES-BENZ-ALL-MODELS-SERVICE-REPAIR-WORKSHOP-MANUAL-1982-2017-/252522124225 This is mainly a very detailed manual which covers all mercedes models produced to date. Like where and in what sequence to remove the parts to an area. The parts numbers so that you can order the spare parts or accessories. Thanks for sharing the lobang! Got it the instant i saw it. Link to post Share on other sites More sharing options...
Ct3833 Supersonic November 25, 2018 Share November 25, 2018 On 11/25/2018 at 12:25 AM, Vratenza said: It is actually a software that needs to be installed and operated within a vpn environment. I bought it from an eBay seller ... This is an example: Reveal hidden contents https://www.ebay.com/itm/For-MERCEDES-BENZ-ALL-MODELS-SERVICE-REPAIR-WORKSHOP-MANUAL-1982-2017-/252522124225 This is mainly a very detailed manual which covers all mercedes models produced to date. Like where and in what sequence to remove the parts to an area. The parts numbers so that you can order the spare parts or accessories. Thanks. Good to have a service manual so that do not have to figure things out. In fact at times when i see mechanics trying to figure things out , i am quite worried. 1 Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear November 25, 2018 Share November 25, 2018 On 11/25/2018 at 3:52 AM, Roadrunner2029 said: Nowadays, newer cars have a lot of sensors for troubleshooting. But often, when one part or one sensor is faulty, other sensors also detects something wrong, then it depends on experience to locate the root cause. Some AD, just blindly follow their internal software and change one part, then another part, then another part.. when all you need could just be a single part change. It's not blindly following. It's following the manufacturers procedure. To you it's blindly, to the agent it's following sop. Your thinking need to change Link to post Share on other sites More sharing options...
Ct3833 Supersonic November 25, 2018 Share November 25, 2018 (edited) On 11/25/2018 at 3:52 AM, Roadrunner2029 said: Nowadays, newer cars have a lot of sensors for troubleshooting. But often, when one part or one sensor is faulty, other sensors also detects something wrong, then it depends on experience to locate the root cause. Some AD, just blindly follow their internal software and change one part, then another part, then another part.. when all you need could just be a single part change. Agree. Or some agents will just replace the entire assembly when a sub assembly replacment will do the job. Edited November 25, 2018 by Ct3833 Link to post Share on other sites More sharing options...
Fitvip Supersonic November 25, 2018 Share November 25, 2018 On 11/24/2018 at 2:16 AM, Beregond said: but the thing is even if the mech bring the spark plug right to the guy, he also dun know how to judge the conditions. like some bro say we cannot be the master of all trade. my dentist send me invitation letter to go check up and do teeth maintenance every 6 mth. 1 time 80buks. is it necessary?? i dun know i am not dentist but last time before i register my account there, i went 3 years once, my teeth still in very good condition. ever since i register , 6 mth must go once. if u get wat i mean. Dentists love PG card holders! They will max out the annual limit! 1 Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear November 25, 2018 Share November 25, 2018 On 11/25/2018 at 4:40 AM, Ct3833 said: Agree. Or some agents will just replace the entire assembly when a sub assembly replacment will do the job.That's how they make money. It's the shortest n fastest method Link to post Share on other sites More sharing options...
Evillusion Supersonic November 25, 2018 Share November 25, 2018 On 11/25/2018 at 4:40 AM, Ct3833 said: Agree. Or some agents will just replace the entire assembly when a sub assembly replacment will do the job.not only ad lor.....some normal ws will also recommend to change whole system. My friend's aircon had a prob, sg workshop say need to change condenser need to change compressor in the end he went to a jb ws and they added a washer to the existing aircon clutch....less than 50rm and its been 8 yrs liao.... 1 Link to post Share on other sites More sharing options...
Adrianli Hypersonic November 26, 2018 Share November 26, 2018 My current AD workshop has never upsell anything to me before. Always, i am the one to tell them what i want. Last servicing, ask them to change battery, knn they go do battery capacity test and show me results that battery still good. And i always leave my car there in the morning and collect in the afternoon. But when comes to repair, wow, their knife very sharp. 2 Link to post Share on other sites More sharing options...
Beregond Supersonic November 26, 2018 Share November 26, 2018 On 11/26/2018 at 6:15 AM, Adrianli said: My current AD workshop has never upsell anything to me before. Always, i am the one to tell them what i want. Last servicing, ask them to change battery, knn they go do battery capacity test and show me results that battery still good. And i always leave my car there in the morning and collect in the afternoon. But when comes to repair, wow, their knife very sharp. actually my ws very similar to your case. they alway check every thing even for basic servicing, some time i request stuff like replace brake disc, they say dun need, just replace brake pad enough. but their price not the cheapest around. i would say above average, but i like their upfront and honestly. Link to post Share on other sites More sharing options...
Daniu82 Supercharged November 26, 2018 Share November 26, 2018 Most of the time I don't even trust AD workshop. Read from online that engine flush should not be done unless your mileage is high, but my AD workshop asks me do engine flush and aircon servicing when my mileage is only 20k, I rejected them. When should engine flush be done? Comments experts? 2 Link to post Share on other sites More sharing options...
Adrianli Hypersonic November 26, 2018 Share November 26, 2018 On 11/26/2018 at 6:28 AM, Daniu82 said: Most of the time I don't even trust AD workshop. Read from online that engine flush should not be done unless your mileage is high, but my AD workshop asks me do engine flush and aircon servicing when my mileage is only 20k, I rejected them. When should engine flush be done? Comments experts? When i was driving a COE car, 15 years old car, all workshops i go to say dont do engine flush. Later everywhere also leak. And older car must use thicker lub oil. Newer car dont do engine flush. Old car dont do engine flush. So my conclusion is engine flush is snake oil. 1 Link to post Share on other sites More sharing options...
Tianmo Hypersonic November 26, 2018 Share November 26, 2018 On 11/25/2018 at 6:25 AM, Eviilusion said: not only ad lor.....some normal ws will also recommend to change whole system. My friend's aircon had a prob, sg workshop say need to change condenser need to change compressor in the end he went to a jb ws and they added a washer to the existing aircon clutch....less than 50rm and its been 8 yrs liao.... 1 Link to post Share on other sites More sharing options...
Evillusion Supersonic November 26, 2018 Share November 26, 2018 On 11/26/2018 at 6:35 AM, Tianmo said: When i drove the optra, there is one interesting fact which not many WS know. That is there is a regulator valve under the compressor, which needs to be replace every 60k km. I only manage to get it done at 3 places, once in woodlands, once in toh guan rd east and once in JB. Cost $150, but in JB i got it done at RM320 because I didnt want the filter. All other WS told me need to change the whole compressor, S$480... jb is bestest.... 1 Link to post Share on other sites More sharing options...
Beregond Supersonic November 26, 2018 Share November 26, 2018 (edited) On 11/26/2018 at 6:28 AM, Daniu82 said: Most of the time I don't even trust AD workshop. Read from online that engine flush should not be done unless your mileage is high, but my AD workshop asks me do engine flush and aircon servicing when my mileage is only 20k, I rejected them. When should engine flush be done? Comments experts? i no expert, but flush at 20k abit c--k?? new car 20 k aircon want service wat?? if got problem should'nt it be under warrently?? at most if the cabin filter very dirty, then just replace that only. ( personally i flush and put ceratec at around 40-50 k interval. ) Edited November 26, 2018 by Beregond 1 Link to post Share on other sites More sharing options...
Dilemma 5th Gear November 26, 2018 Share November 26, 2018 I pay $20 to eat Fish & Chips at swensons. According to TS, i should really go learn and cook myself which will cost only $3. 2 Link to post Share on other sites More sharing options...
Angcheek Hypersonic November 26, 2018 Share November 26, 2018 On 11/26/2018 at 6:28 AM, Daniu82 said: Most of the time I don't even trust AD workshop. Read from online that engine flush should not be done unless your mileage is high, but my AD workshop asks me do engine flush and aircon servicing when my mileage is only 20k, I rejected them. When should engine flush be done? Comments experts? hahha ..... you are correct . you shld suan them abit . ↡ Advertisement 1 Link to post Share on other sites More sharing options...
National Service in Singapore
The ownself service car hobbyist! Pls come in Share your lobangs/parts hoot
Singapore Reckless Drivers Part Xvi
Who needs tuition or teachers anymore these days? Why waste money?
Autobacs got 🔪 kah you?
Grab feature pairing women drivers with women passengers
Bad service from Top93, ubi
