Dordor 1st Gear November 18, 2018 Share November 18, 2018 I just recently bought a resale car. The exterior is white in color, log card stated primary is white color. However, when I send to repair, the mechanic open up the side mirror and realise the original color should be red. The interior of side mirror casing is red, one part of the the side mirror (after dismantle) is also partially red. Can the primary colour be changed after respray? Will I able to find out what is the original colour of the car? Thank you! ↡ Advertisement 1 Link to post Share on other sites More sharing options...
UncleAtas Turbocharged November 18, 2018 Share November 18, 2018 On 11/18/2018 at 6:25 AM, Dordor said: I just recently bought a resale car. The exterior is white in color, log card stated primary is white color. However, when I send to repair, the mechanic open up the side mirror and realise the original color should be red. The interior of side mirror casing is red, one part of the the side mirror (after dismantle) is also partially red. Can the primary colour be changed after respray? Will I able to find out what is the original colour of the car? Thank you! In order to find the original color, got to find the 1st owner. Any change of color to the vehicle can be updated via OneMotoring. Doesn't necessarily the log card will only reflect the original color. 1 Link to post Share on other sites More sharing options...
Dordor 1st Gear November 18, 2018 Author Share November 18, 2018 How do I find the first owner? I bought it from dealer... Link to post Share on other sites More sharing options...
Soya Supersonic November 18, 2018 Share November 18, 2018 Find first owner for what? If the current LTA logcard say white n car is white, doesn't matter what the previous colour was I would be more concerned if u think u bought a Lexus RX and logcard say Toyota Harrier....lol 1 1 Link to post Share on other sites More sharing options...
Sugimoto 6th Gear November 18, 2018 Share November 18, 2018 (edited) Wat car are you driving? You can check out your original color by looking at your chassis plate. The plate will show your car's color code & you can check it on the internet, example Toyota 070 = Toyota White Pearl. The plate can be found on the engine bay area or side pillar between front & rear passenger. Edited November 18, 2018 by Sugimoto 12 Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged November 18, 2018 Share November 18, 2018 On 11/18/2018 at 6:25 AM, Dordor said: I just recently bought a resale car. The exterior is white in color, log card stated primary is white color. However, when I send to repair, the mechanic open up the side mirror and realise the original color should be red. The interior of side mirror casing is red, one part of the the side mirror (after dismantle) is also partially red. Can the primary colour be changed after respray? Will I able to find out what is the original colour of the car? Thank you! if everything tallied.. the worst case is that door is replaced with a used one with original color red and resprayed to white. Link to post Share on other sites More sharing options...
So_nice 6th Gear November 18, 2018 Share November 18, 2018 Rather then worried about the colour, I think you should ask your mech to check the chassis for signs of major accident. 1 Link to post Share on other sites More sharing options...
Dordor 1st Gear November 18, 2018 Author Share November 18, 2018 Thank you very much! On 11/18/2018 at 7:27 AM, Sugimoto said: Wat car are you driving? You can check out your original color by looking at your chassis plate. The plate will show your car's color code & you can check it on the internet, example Toyota 070 = Toyota White Pearl. The plate can be found on the engine bay area or side pillar between front & rear passenger. 1 Link to post Share on other sites More sharing options...
13177 Hypersonic November 18, 2018 Share November 18, 2018 Thought when you changed your car colour, your log card also changed? Esp now log card is all E-copy de, should be easily changed. Last time when log card is hard copy, maybe the initial colour stated on the log card would not able to change if the car is respray to another color. Link to post Share on other sites More sharing options...
Dilemma 5th Gear November 19, 2018 Share November 19, 2018 Is the car from an AD? If yes, you can check with the AD. Link to post Share on other sites More sharing options...
Silviasam November 19, 2018 Share November 19, 2018 If you find owner, then he/she will help you. ↡ Advertisement Link to post Share on other sites More sharing options...
2026 8th Generation Lexus ES
Prepaid card
Prepaid card
[Official] 2024 Lexus LBX
2022 2nd Generation Lexus NX
Car colour as a search option in SGcarmart
2018 / 2019 7th Generation Lexus ES
2020 Lexus LC Convertible
