ER-3682 Twincharged February 21, 2022 Share February 21, 2022 29 minutes ago, D3badge said: What you guys say is correct the different oil weight for different climate, but more for cold weather bah, and the heavier oil weight for older engine that run hotter and require heavier oil but I think Borneo kiasu use weight 30 for more protection thus less warranty claim. ownside is heavier weight rob the engine performance……fuel economy and power yes Toyota mention A25A TNGA engine uses weight 16 only Borneo motor feed my ride weight 30 too I just changed my Oil back to 0w16...it have difference..better stick to Factory Specs. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic February 21, 2022 Author Share February 21, 2022 25 minutes ago, D3badge said: What you guys say is correct the different oil weight for different climate, but more for cold weather bah, and the heavier oil weight for older engine that run hotter and require heavier oil but I think Borneo kiasu use weight 30 for more protection thus less warranty claim. ownside is heavier weight rob the engine performance……fuel economy and power yes Toyota mention A25A TNGA engine uses weight 16 only Borneo motor feed my ride weight 30 too I think it was mentioned that this engine uses an electric oil pump that may not run all the time. Unlike mechanical one. Someone posted a video on that in this thread. Lastly, TNGA => Chassis. Dynamic Force => engine. Link to post Share on other sites More sharing options...
t0y0ta Supercharged February 21, 2022 Share February 21, 2022 17 minutes ago, inlinesix said: I think it was mentioned that this engine uses an electric oil pump that may not run all the time. Unlike mechanical one. Someone posted a video on that in this thread. Lastly, TNGA => Chassis. Dynamic Force => engine. Electric water pump... To regulate temp very well. Oil pump is probably still belt driven Link to post Share on other sites More sharing options...
inlinesix Hypersonic February 21, 2022 Author Share February 21, 2022 7 minutes ago, t0y0ta said: Electric water pump... To regulate temp very well. Oil pump is probably still belt driven Going through car care nut video. It is an electric pump. Accordingly, he mentioned that the viscosity of EO is very important. 1 Link to post Share on other sites More sharing options...
ER-3682 Twincharged February 21, 2022 Share February 21, 2022 Thicker make the Engine Cut i lazier..thinner Oil..Cut in less Vibration. Link to post Share on other sites More sharing options...
Heartlander Turbocharged February 21, 2022 Share February 21, 2022 From 11"25 onwards for the difference in back row. Link to post Share on other sites More sharing options...
D3badge 6th Gear February 21, 2022 Share February 21, 2022 1 hour ago, ER-3682 said: I just changed my Oil back to 0w16...it have difference..better stick to Factory Specs. Problem is I have service credit with Borneo motor, so servicing sure go back to them😂 then they will use weight 30 only. Cannot possible after that 5k mileage later I go outside change EO to 20 weight since 16 weight maybe challenging to find hahah Link to post Share on other sites More sharing options...
ER-3682 Twincharged February 21, 2022 Share February 21, 2022 @D3badge If i not wrong,Borneo have 5w20 Motul Oil,can check with them,5w20 is still better than 5w30. 1 Link to post Share on other sites More sharing options...
D3badge 6th Gear February 21, 2022 Share February 21, 2022 10 hours ago, ER-3682 said: @D3badge If i not wrong,Borneo have 5w20 Motul Oil,can check with them,5w20 is still better than 5w30. Ok cool will ask them next servicing Link to post Share on other sites More sharing options...
Westin 1st Gear February 22, 2022 Share February 22, 2022 What happens after 5 years? Thought canry hybrid can last 10 years no problem? Link to post Share on other sites More sharing options...
csf 2nd Gear February 22, 2022 Share February 22, 2022 I think the 0W is more critical on hybrid engines due to frequent restarting. Unlike conventional engines, it only start once and thereafter the oil continues to circulate. I would choose 0W30 (if available) rather than 5W20. Link to post Share on other sites More sharing options...
ER-3682 Twincharged February 22, 2022 Share February 22, 2022 3 hours ago, csf said: I think the 0W is more critical on hybrid engines due to frequent restarting. Unlike conventional engines, it only start once and thereafter the oil continues to circulate. I would choose 0W30 (if available) rather than 5W20. 5w30 & 0w30 are same thickness...follow Specs 0w16 best...Factory Engineers..knew the Engine best. 2 Link to post Share on other sites More sharing options...
D3badge 6th Gear February 23, 2022 Share February 23, 2022 Link to post Share on other sites More sharing options...
D3badge 6th Gear February 23, 2022 Share February 23, 2022 (edited) 2 minutes ago, D3badge said: Borneo Motor uses weight 30 as it is mention in owner manual, uses the highest viscosity for "more protection". below after about 6 min mark, he kinda indirect mention Dynamic force engine! engine uses 0w-16 EO with 40% or more thermal efficiency 😁 Edited February 23, 2022 by D3badge Link to post Share on other sites More sharing options...
t0y0ta Supercharged February 24, 2022 Share February 24, 2022 On 2/22/2022 at 10:46 AM, csf said: I think the 0W is more critical on hybrid engines due to frequent restarting. Unlike conventional engines, it only start once and thereafter the oil continues to circulate. I would choose 0W30 (if available) rather than 5W20. 0W or 5W or 10W refers to the oil viscosity under Winter (below zero C) temperatures.... nothing to do with hybrid or starting 1 Link to post Share on other sites More sharing options...
rotidjon Neutral Newbie March 31, 2022 Share March 31, 2022 Hi fellow Camry Hybrid owners, can I check if anyone finds the wiper speed inadequate? Other than this issue, I love the car. But seriously, "normal" Singapore rainfall, I need to use the fastest speed already. Visibility is quite poor during heavier rains, compared to any previous car I have driven in local rain. Mine is an 11-month old Ascent Sport PI model. Highlighted during servicing, was told "all the newer camry is the same". Wondering if I'm the only one, or if anyone has managed to resolve this? Thanks in advance for any help. Link to post Share on other sites More sharing options...
ER-3682 Twincharged March 31, 2022 Share March 31, 2022 @rotidjon No Problem for me,i used Rain-X. Link to post Share on other sites More sharing options...
Heartlander Turbocharged March 31, 2022 Share March 31, 2022 4 hours ago, rotidjon said: Hi fellow Camry Hybrid owners, can I check if anyone finds the wiper speed inadequate? Other than this issue, I love the car. But seriously, "normal" Singapore rainfall, I need to use the fastest speed already. Visibility is quite poor during heavier rains, compared to any previous car I have driven in local rain. Mine is an 11-month old Ascent Sport PI model. Highlighted during servicing, was told "all the newer camry is the same". Wondering if I'm the only one, or if anyone has managed to resolve this? Thanks in advance for any help. Think is more due to windscreen not cleaned properly lah. If used rainx or glare or some other treatment sure can repel water very well. ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota Land Cruiser Mini
Toyota Corolla Cross
2024 camry
2024 camry
2020 Toyota GranAce Premium
2018 3rd Generation Toyota Century
