Ysc3 Twincharged September 29, 2018 Share September 29, 2018 last night during our weekly gathering, my uncle told us my cousin moving into her new BTO flat. she got an installer to come to her flat to fix up the flat TV on the wall. however, when the installer came, he told her cannot .... and then he knocked on the "wall" and it turned out to be hollow !! as such, he explained it will not be able to sustain the weight of the Tv over time. in the end, he installed the bracket on the outlining solid wall instead of the partition inside the flat. anyone else got new flats and the "walls" inside the house separating the bedrooms are plasterboard walls ? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Jtb 6th Gear September 30, 2018 Share September 30, 2018 1st time to know this. get the builder to provide a layout on it. nv know new flats built in this way now! whether to absorb noise... Link to post Share on other sites More sharing options...
Naughty9795 2nd Gear September 30, 2018 Share September 30, 2018 It is common nowadays, EC and condo also having gypsum board walls. Easier if you want to demolish walls to reconfigure the layout. It is also cheaper and faster to build. last night during our weekly gathering, my uncle told us my cousin moving into her new BTO flat. she got an installer to come to her flat to fix up the flat TV on the wall. however, when the installer came, he told her cannot .... and then he knocked on the "wall" and it turned out to be hollow !! as such, he explained it will not be able to sustain the weight of the Tv over time. in the end, he installed the bracket on the outlining solid wall instead of the partition inside the flat. anyone else got new flats and the "walls" inside the house separating the bedrooms are plasterboard walls ? 3 Link to post Share on other sites More sharing options...
Ysc3 Twincharged September 30, 2018 Author Share September 30, 2018 lucky SG don't have earthquake ... or else the flat dunno can tahan or not ... now that the internal "pillars" are nolonger there. 1st time to know this. get the builder to provide a layout on it. nv know new flats built in this way now! whether to absorb noise... poor noise insulation within the house. Link to post Share on other sites More sharing options...
Carbon82 Moderator September 30, 2018 Share September 30, 2018 From 2015 onwards, it become mandatory for non-landed residential unit (HDB flats inclusive) to have certain % of walls (typically non-structural inner wall) to use drywall system, for increasing productivity and sustainability (less reliance on sand and cement). These requirement falls under BCA's Building Control (Buildability and Productivity) Regulations 2011. Refer to Schedule 2 for the mandatory building systems and standard components to be used. And here are some info pertaining to the quality of drywall system (gypsum board). Sound insulation properties is heavily dependent on the type of material used, and can be further enhanced through the use of rockwool. 10 Link to post Share on other sites More sharing options...
golden_eagle 2nd Gear September 30, 2018 Share September 30, 2018 The BCA brouchure says dry walls is only 15% weight of brick wall. I wonder whether poorly build condos and ECs can support an additional 85% weight of a brick wall? It is common nowadays, EC and condo also having gypsum board walls. Easier if you want to demolish walls to reconfigure the layout. It is also cheaper and faster to build. Link to post Share on other sites More sharing options...
Kklim Supercharged September 30, 2018 Share September 30, 2018 Bottom part of wall is solid, hollow above a certain height. Should be able to mount TV using hollowblock anchors aka toggle bolts. Link to post Share on other sites More sharing options...
Ysc3 Twincharged September 30, 2018 Author Share September 30, 2018 (edited) Bottom part of wall is solid, hollow above a certain height. Should be able to mount TV using hollowblock anchors aka toggle bolts. dunno leh ... this is the tan-jiak man say one ... i have not seen it myself ... (actually makes no diff coz i am layman) anyway, below are some shots from a friend : Edited September 30, 2018 by Ysc3 Link to post Share on other sites More sharing options...
Neutrino Supercharged September 30, 2018 Share September 30, 2018 (edited) OK hollow walls. I know 'buyer beware' but really do HDB inform buyers about this new feature. I doubt buyers know this. Prolly won't effect their decision but I've got a lot of paintings on my solid walls and don't think I'd have them on hollow walls. Does bomb shelter have these hollow walls. Don't you have to wait 5 years before allowed to do alterations in HDB. By then got floor installed so not easy to make changes. Edited September 30, 2018 by Neutrino Link to post Share on other sites More sharing options...
Ysc3 Twincharged September 30, 2018 Author Share September 30, 2018 OK hollow walls. I know 'buyer beware' but really do HDB inform buyers about this new feature. I doubt buyers know this. Prolly won't effect their decision but I've got a lot of paintings on my solid walls and don't think I'd have them on hollow walls. Does bomb shelter have these hollow walls. Don't you have to wait 5 years before allowed to do alterations in HDB. By then got floor installed so not easy to make changes. actually got pro and cons for me now that i know about and will be expecting this. cons is i cannot anchor heavy things on the "wall". pros is most probably i will knock down the plasterboard walls and install sliding doors between the bedrooms. Link to post Share on other sites More sharing options...
inlinesix Hypersonic September 30, 2018 Share September 30, 2018 lucky SG don't have earthquake ... or else the flat dunno can tahan or not ... now that the internal "pillars" are nolonger there. poor noise insulation within the house. Huge quake in Sumatra can be felt in certain parts of Sg. Since these walls are not main beam, ok la Link to post Share on other sites More sharing options...
UncleAtas Turbocharged October 1, 2018 Share October 1, 2018 OK hollow walls. I know 'buyer beware' but really do HDB inform buyers about this new feature. I doubt buyers know this. Prolly won't effect their decision but I've got a lot of paintings on my solid walls and don't think I'd have them on hollow walls. Does bomb shelter have these hollow walls. Don't you have to wait 5 years before allowed to do alterations in HDB. By then got floor installed so not easy to make changes. Cheaper options but price of HDB still same.. Probably next we will go back to using stilt. Link to post Share on other sites More sharing options...
Lala81 Hypersonic October 1, 2018 Share October 1, 2018 Due to the prefab nature of my flat and predating the BCA changes, don't have these dry walls. Link to post Share on other sites More sharing options...
Jman888 Moderator October 1, 2018 Share October 1, 2018 dunno leh ... this is the tan-jiak man say one ... i have not seen it myself ... (actually makes no diff coz i am layman) anyway, below are some shots from a friend : 3c4a8b9f-c898-420a-b684-78eae1a47b92.jpg8b0b85ab-22cd-4e76-911e-257aaefa4341.jpg65f49506-dc9a-4265-b577-9a677b2f7fb4.jpgf53f6aeb-36e4-484c-80c0-48cf1eaf98a9.jpg these photos look like offices, some of the flat/EC allow you to choose 3-4 bedroom and the drywall will be used for easy configuration. Link to post Share on other sites More sharing options...
Watwheels Supersonic October 1, 2018 Share October 1, 2018 (edited) last night during our weekly gathering, my uncle told us my cousin moving into her new BTO flat. she got an installer to come to her flat to fix up the flat TV on the wall. however, when the installer came, he told her cannot .... and then he knocked on the "wall" and it turned out to be hollow !! as such, he explained it will not be able to sustain the weight of the Tv over time. in the end, he installed the bracket on the outlining solid wall instead of the partition inside the flat. anyone else got new flats and the "walls" inside the house separating the bedrooms are plasterboard walls ? This is old news. More dan 10years ago HDB already doing it on all kinds of flats. My mum's place the masterbedroom door(the piece of wall above the door frame), toilets' wall all plasterboard. Why cannot hold the TV? The one I fix in my mum's masterbed room the not so flat TV has been up there for 10+ years. Next to it I even install a shelf to put dvd player and setup box. Who said cannot hold over time is big BS. It's not a paperwall. Edited October 1, 2018 by Watwheels 2 Link to post Share on other sites More sharing options...
Jman888 Moderator October 1, 2018 Share October 1, 2018 This is old news. More dan 10years ago HDB already doing it on all kinds of flats. My mum's place the masterbedroom door(the piece of wall above the door frame), toilets' wall all plasterboard. Why cannot hold the TV? The one I fix in my mum's masterbed room the not so flat TV has been up there for 10+ years. Next to it I even install a shelf to put dvd player and setup box. Who said cannot hold over time is big BS. It's not a paperwall. drilling in this type of wall is much easier than brick wall, need a heavy duty drill and messy. Link to post Share on other sites More sharing options...
Watwheels Supersonic October 1, 2018 Share October 1, 2018 drilling in this type of wall is much easier than brick wall, need a heavy duty drill and messy. Yeah. I don't trust installers, they use cheapo steel screws that will rust. I used stainless steel self-tapping screws that don't require any drilling. Link to post Share on other sites More sharing options...
Silver_blade Turbocharged October 1, 2018 Share October 1, 2018 Actually, I much prefer drywall cos it is easier to run concealed wiring and easy enough to patch it up, light weight, better finishes and can specify the level of sound proofing I want. One of the earliest condo to use all drywall for the internal partition is Bayshore Park built in the 80's. This is old news. More dan 10years ago HDB already doing it on all kinds of flats. My mum's place the masterbedroom door(the piece of wall above the door frame), toilets' wall all plasterboard. Why cannot hold the TV? The one I fix in my mum's masterbed room the not so flat TV has been up there for 10+ years. Next to it I even install a shelf to put dvd player and setup box. Who said cannot hold over time is big BS. It's not a paperwall. It is ppl's perception rather than reality. Drywall can hold weight if we specify or add reinforcement eg. plywood, etc it correctly. ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Does HDB profit from selling flats?
Recommendations for wall paintings
First-timers must select BTO flats when invited by HDB or lose priority for a year from August launch
Renovation budget that blows your mind
Ford Doing BTO, KYM?
Over 900 flats to be built in Sin Ming; first new HDB project in the area in over 30 years
Creative BTOs in the RED!
Small little tiny bug on walls & ceiling
