Jamesc Hypersonic August 30, 2018 Share August 30, 2018 You should be familiar with doing it from the behind. It is not the only way. Another way is doing from the front or top side siphon. Insert your (vac) tube into the dip stick hole, then start the pump, and once you have enough (say 1L), withdraw your tube. This is called the early withdrawal method. Ofc if you use from the behind method, once all the sai zhap starts to gush out, neither sticking your finger in or attempt to screw back is going to be helpful. Haha I like your detailed explanation. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Kusje Supersonic August 30, 2018 Share August 30, 2018 Any workshops buy engine oil in drums? Link to post Share on other sites More sharing options...
DACH Supersonic August 30, 2018 Share August 30, 2018 Seriously so many conspiracy theory. Please go back AD if so unsecured. ADs don't even let you see how they service the car. Link to post Share on other sites More sharing options...
Hamburger Hypersonic August 30, 2018 Share August 30, 2018 ADs don't even let you see how they service the car. 用人不疑 疑人不用 2 Link to post Share on other sites More sharing options...
Locknload 5th Gear August 30, 2018 Share August 30, 2018 Any workshops buy engine oil in drums? Yes, serviced my car at Loyang (Spark Comfort Delgro) long ago and remembered that I used their promo in-house oil which were in drums. Link to post Share on other sites More sharing options...
Silviasam September 4, 2018 Share September 4, 2018 Did you check the oil channel? 1 Link to post Share on other sites More sharing options...
Adrianli Hypersonic September 25, 2018 Share September 25, 2018 @Radx Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear September 25, 2018 Share September 25, 2018 ADs don't even let you see how they service the car. This is to avoid any disputes they damage your car Link to post Share on other sites More sharing options...
beepbeepph September 26, 2018 Share September 26, 2018 Sometimes engine oil can be dark (looks black sometimes) but its still effective to use. But, in general clean oil indicates an amber color. The oil gets darker means that such factor affects it such as high heal, contaminants or worse there is an additive which causes it to darken. I suggest you directly ask the car shop you have it serviced for proper explanation on that matter. Link to post Share on other sites More sharing options...
Vinceng Turbocharged July 31, 2020 Share July 31, 2020 I switched from Mobil 1 to Castrol Edge, both are 5W30. Registered at least 10% increase in fuel consumption. Could it be due to the engine oil used? 1 Link to post Share on other sites More sharing options...
Mkl22 Supersonic July 31, 2020 Share July 31, 2020 1 minute ago, Vinceng said: I switched from Mobil 1 to Castrol Edge, both are 5W30. Registered at least 10% increase in fuel consumption. Could it be due to the engine oil used? Could be. Not all 5w30 are the same. One could be in the lower end of the viscosity range and the other on the opposite end. Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear July 31, 2020 Share July 31, 2020 14 minutes ago, Vinceng said: I switched from Mobil 1 to Castrol Edge, both are 5W30. Registered at least 10% increase in fuel consumption. Could it be due to the engine oil used? Oh ....... something dying ...... How you count consumption ? Car built-in or Ownself count ? Link to post Share on other sites More sharing options...
inlinesix Hypersonic July 31, 2020 Share July 31, 2020 33 minutes ago, Vinceng said: I switched from Mobil 1 to Castrol Edge, both are 5W30. Registered at least 10% increase in fuel consumption. Could it be due to the engine oil used? Which Mobil1? Which Castrol Edge? Link to post Share on other sites More sharing options...
Vinceng Turbocharged July 31, 2020 Share July 31, 2020 Switched from Mobil 1 ESP to Castrol Edge Professional. Both are 5W30. Fuel consumption is calculated based on taking total distance travelled divide by litres pumped. No change in driving habits over last 3 tanks, after oil change. Link to post Share on other sites More sharing options...
Hyde333 3rd Gear July 31, 2020 Share July 31, 2020 3 hours ago, Vinceng said: I switched from Mobil 1 to Castrol Edge, both are 5W30. Registered at least 10% increase in fuel consumption. Could it be due to the engine oil used? Both engine oil differ very little in viscosities and viscosity index. Did you check your engine oil level before and after the oil change? The oil level could be at the halfway mark before the oil change or the mechanic could have overserved the new oil. Link to post Share on other sites More sharing options...
Mkl22 Supersonic July 31, 2020 Share July 31, 2020 (edited) 32 minutes ago, Hyde333 said: Both engine oil differ very little in viscosities and viscosity index. Did you check your engine oil level before and after the oil change? The oil level could be at the halfway mark before the oil change or the mechanic could have overserved the new oil. Not true. Like I said. One can be at top band and the other at lower band. Go read bobistheoilguy. 30wt oil can be cst 9.3-12.5 https://www.kewengineering.co.uk/Auto_oils/oil_viscosity_explained.htm Edited July 31, 2020 by Mkl22 Link to post Share on other sites More sharing options...
Hyde333 3rd Gear July 31, 2020 Share July 31, 2020 23 minutes ago, Mkl22 said: Not true. Like I said. One can be at top band and the other at lower band. Go read bobistheoilguy That what's I trying to drive at. Both oil are actually quite low in the band! Viscosity, @ 40°C, cSt (ASTM D445)/ Viscosity @ 100°C, cSt (ASTM D445)/Viscosity Index Mobil 1 62.6 / 11.8 / 187 Castrol 70 / 12.1 / 173 There are some oil like Castrol 0W30 (German Castrol) which falls in a viscosity band which is very close to a 0W40 (Mobil 1) oil just as an example. Link to post Share on other sites More sharing options...
Vinceng Turbocharged July 31, 2020 Share July 31, 2020 Engine oil is at full mark on the dip stick in both instances. ↡ Advertisement Link to post Share on other sites More sharing options...
Hybrid cars 0w8 engine oil
Volvo Servicing
Volvo Servicing
The ownself service car hobbyist! Pls come in Share your lobangs/parts hoot
Car aircon blows cold and hot air at the same time!!
2025 Mazda 6e
2025 Mazda 6e
