Theoldjaffa Hypersonic August 19, 2018 Share August 19, 2018 Saw this on FB. Walls hacked during Reno only to reveal newspapers being stuffed in with concrete. This takes renewability and sustainability of materials to a whole new level of meaning ↡ Advertisement 9 Link to post Share on other sites More sharing options...
WangWang888 5th Gear August 19, 2018 Share August 19, 2018 Will the garang guni price for my old newspaper increase? Keke 1 Link to post Share on other sites More sharing options...
Carbon82 Moderator August 19, 2018 Share August 19, 2018 The photo look legit to me. The HDB flat in the background look like from the early 80s, and tie with the old Nissan logo (pre - 1988) in the one of newspaper advertisement. And I guess it was ST too, as I saw "Life" in it... On a closer look, I don't think the place where the papers were stuff into are the critical building struture, which come under the prevail of HDB or BCA. Might be the work of sub-con (window installer). But still, it is a safety hazard, since the weak bond between the frame and contrete structure may resulted in the entire window falling off from height (leading to fatality). 7 Link to post Share on other sites More sharing options...
Mustank Hypersonic August 19, 2018 Share August 19, 2018 I thought now all prefab? Link to post Share on other sites More sharing options...
Solar Turbocharged August 19, 2018 Share August 19, 2018 (edited) Looks like outer external layer. Perhaps incidents like falling outer fixtures might become common in years to come. Edited August 19, 2018 by Solar Link to post Share on other sites More sharing options...
Mockngbrd Supersonic August 19, 2018 Share August 19, 2018 This is newspaper worthy 5 Link to post Share on other sites More sharing options...
Solar Turbocharged August 19, 2018 Share August 19, 2018 The photo look legit to me. The HDB flat in the background look like from the early 80s, and tie with the old Nissan logo (pre - 1988) in the one of newspaper advertisement. And I guess it was ST too, as I saw "Life" in it... On a closer look, I don't think the place where the papers were stuff into are the critical building struture, which come under the prevail of HDB or BCA. Might be the work of sub-con (window installer). But still, it is a safety hazard, since the weak bond between the frame and contrete structure may resulted in the entire window falling off from height (leading to fatality). Looks like the ID or renovation contractor that cut corner.This industry got no regulation? 1 Link to post Share on other sites More sharing options...
Dafansu Turbocharged August 19, 2018 Share August 19, 2018 what's this about, newspaper found inside after removing certain structural? Then the newspaper still looks very new and in good condition. Link to post Share on other sites More sharing options...
RadX Moderator August 19, 2018 Share August 19, 2018 See la even shitty times no value until liddat 1 Link to post Share on other sites More sharing options...
Evillusion Supersonic August 19, 2018 Share August 19, 2018 See la even shitty times no value until liddatWhat you expect......shitty time is only good at holding up the 'facade'..... 3 Link to post Share on other sites More sharing options...
Ash2017 Twincharged August 19, 2018 Share August 19, 2018 this proves the 3 little pigs wrong 3 Link to post Share on other sites More sharing options...
Staff69 Hypersonic August 19, 2018 Share August 19, 2018 1 Link to post Share on other sites More sharing options...
Camrysfa Turbocharged August 19, 2018 Share August 19, 2018 can make out some words ... Singapore, 100 Plus, Prudential, Slazenger. how much cement/cost can they save? weird 1 Link to post Share on other sites More sharing options...
Freeder Hypersonic August 19, 2018 Share August 19, 2018 Singapore is gradually n literally going to the dumps..no pun intended.. Link to post Share on other sites More sharing options...
mersaylee Hypersonic August 19, 2018 Share August 19, 2018 See la even shitty times no value until liddat What you see there is the real value... Link to post Share on other sites More sharing options...
Evillusion Supersonic August 19, 2018 Share August 19, 2018 can make out some words ... Singapore, 100 Plus, Prudential, Slazenger. how much cement/cost can they save? weird that is only for 1 unit.....if its for the whole building its rather substantial and if you time that amount for whatever the contractor or subcon are building throughout the industries.....you get millions saved. My friends used to check the new incoming concrete even after the surveyor has signed off and rejects if the concrete is not up to standard. Do that a few times and then randomly the concrete will be up to standard.....no hanky panky from the main con. You dont check they will cut corners to save on costs and the result is as above. 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic August 19, 2018 Share August 19, 2018 can make out some words ... Singapore, 100 Plus, Prudential, Slazenger. how much cement/cost can they save? weird Not just cost...but laziness on the part of the worker. 1 Link to post Share on other sites More sharing options...
Evillusion Supersonic August 19, 2018 Share August 19, 2018 (edited) Not just cost...but laziness on the part of the worker.it takes energy and is much longer for a worker to do that. Imagine need to plaster the inner layers with newspaper for the unit or the whole block before concrete is poured in. As a construction worker, I rather watch them pour in the concrete after finishing the form works. Edited August 19, 2018 by Eviilusion ↡ Advertisement Link to post Share on other sites More sharing options...
Higher property tax for most 3-room HDB flats, all bigger units from Jan 1, 2022: Iras
Used Car, what STA Inspection grade then can buy?
Used car dealers tampering odometer readings
Get a new car plate number for used car
Recommend lawyer to take dealer to court for mileage / odometer tampering?
Properties info
Properties info
