Runforyourlife 5th Gear September 17, 2018 Share September 17, 2018 Here the new Mercedes A Class 35 AMG https://www.motori.news/mercedes-classe-a35-amg-la-sportiva-arriva-a-dicembre-27599.html Wonder who will actually buy this lol. At the price point prob better off with many others. ↡ Advertisement Link to post Share on other sites More sharing options...
DACH Supersonic September 20, 2018 Share September 20, 2018 Mercedes-AMG A35 revealed with 302bhphttps://www.autocar.co.uk/car-news/new-cars/mercedes-amg-a35-revealed-302bhp The highly-anticipated Mercedes-AMG A35 4Matic will feature a uniquely-tuned turbocharged 2.0-litre engine delivering 302bhp as well as a seven-speed dual clutch gearbox, on-demand four-wheel drive and a specially stiffened body when it goes on sale in the UK later this year. The new AMG model, planned to make its public debut at the Paris motor show in early October, is positioned between the latest A250 and upcoming second-generation A45 4Matic in the German car maker’s performance car line-up as a rival to the BMW M140i and Audi S3 as well as a raft of other hot hatchbacks, including the Volkswagen Golf R. Conceived to offer greater performance potential than the front-wheel drive A250 but at a price that is expected to see it pitched some £6,000 below that of the £41,230 A45 4Matic in the UK at around £35,000, the launch of the A35 4Matic comes after strong sales of the A45 4Matic and other four-cylinder AMG models, including the CLA45 4Matic, CLA45 Shooting Brake 4Matic and GLA45 4Matic. "The demand for our compact models has developed in recent years. This success has encouraged us to further expand our portfolio and place it on a broader footing," says Tobias Moers, CEO of Mercedes-AMG. At the heart of the A35 4Matic is a revised version of Mercedes-Benz’s M260 engine, as used by the A250. It is described by AMG as a new development, although the new four-cylinder unit shares its 83.0mm bore and 92.0mm stroke measurements and design of its die-cast aluminium crankcase with the M133 engine of the A45 4Matic. Key engineering attributes of the AMG tweaked powerplant include uniquely-tuned twin-scroll turbochargers with reduced back pressure, reprogrammed Camtronic variable valve control, special liners that contribute to conically shaped cylinders and a bespoke exhaust system with an automatically controlled flap that modulates the exhaust note depending on the driving mode. With 302bhp at 5800rpm and 295lb ft of torque between 3000 and 4000rpm, the transversely-mounted engine delivers 81bhp and 77lb ft more than the less heavily tuned version of the M260 unit used by the A250 but 74bhp and 55lb ft less than the more highly strung M133 engine used by the A45 4Matic. At the heart of the A35 4Matic is a revised version of Mercedes-Benz’s M260 engine, as used by the A250. It is described by AMG as a new development, although the new four-cylinder unit shares its 83.0mm bore and 92.0mm stroke measurements and design of its die-cast aluminium crankcase with the M133 engine of the A45 4Matic. Key engineering attributes of the AMG tweaked powerplant include uniquely-tuned twin-scroll turbochargers with reduced back pressure, reprogrammed Camtronic variable valve control, special liners that contribute to conically shaped cylinders and a bespoke exhaust system with an automatically controlled flap that modulates the exhaust note depending on the driving mode. With 302bhp at 5800rpm and 295lb ft of torque between 3000 and 4000rpm, the transversely-mounted engine delivers 81bhp and 77lb ft more than the less heavily tuned version of the M260 unit used by the A250 but 74bhp and 55lb ft less than the more highly strung M133 engine used by the A45 4Matic. Allied to the A35’s gearbox is a heavily revised version of the 4Matic four-wheel drive system used by the first-generation A45. It boasts variable distribution of drive, from front-wheel drive only to a 50:50 apportioning to the front and rear axles, via an electro-mechanically operated multi-plate clutch integrated into the rear axle assembly. The driver is able to choose between five different driving modes via an AMG Dynamic Select controller, including Slippery, Comfort, Sport, Sport+ and Individual. The Slippery mode, a new development that is also planned to appear on the new A45 when it is launched in 2019, is programmed for wet road conditions, with reduced power and torque and earlier upshifts in automatic mode. Also new is a so-called “gliding” function. It allows the driver to choose between “reduced and “moderate” settings for differing engine braking characteristics while coasting on a trailing throttle within the Individual driving mode. With the Sport+ mode and Race Start function engaged, the A35 4Matic is claimed to accelerate from 0-to-62mph in 4.7sec and reach a top speed limited to 155mph. Combined cycle consumption is put at 38.7mpg, equating to average CO2 emissions of 167g/km on the recently superseded NEDC (New European Driving Cycle). This gives the A35 4Matic a slight edge over the M140i and S3, which are claimed to accelerate to 62mph in 4.8sec and 5.3sec respectively, in outright straight-line performance. To cope with the added performance potential brought on the A35 4Matic’s new drivetrain, Mercedes-AMG has stiffened the bodyshell of the A-class hatchback upon which it is based with the addition of a so-called “shear panel” underneath the engine. The aluminium structure is bolted to the existing steel body shell and, in combination with two additional diagonal braces, is claimed to provide added torsional stiffness to the front end. The stiffened body structure supports a MacPherson strut front suspension. It uses a newly developed aluminium carrier and radially bolted steering knuckle that AMG claims reduces the unsprung masses and provides more sensitive response to the system used by the A45 4Matic. The rear suspension is based around the four-link system used by upper range A-class models, with three transverse arms and the trailing arm, the wheel carrier and bearings shared with those of the A45 4Matic. Passive dampers are standard, though buyers can option the new entry-level AMG model with an adaptive damping system that provides three different levels of stiffness. The electro-mechanical steering uses variable assistance and a more rigid mounting than the system used by other new A-class models. The brakes, meanwhile, use four-piston monoblock callipers and 350mm vented and perforated discs up front and single piston callipers and 330mm discs at the rear. The A35 4Matic builds on the sharpened appearance of the fourth-generation A-class with a unique grille, more heavily structured front bumper, standard 18-inch alloy wheels, wider sills, bold tailgate-mounted spoiler and a new rear bumper featuring a prominent diffuser element bookmarked each side by blackened round tailpipes. Inside, the standard A-class interior has been reworked with unique upholstery for the seats an AMG steering wheel with touch-pad controls and AMG specific graphics for the digital instruments, including a so-called Supersport mode with a large central round rev counter. Other new features include AMG Track Pace as part of the MBUX infotainment system. It permanently records data during track driving, enabling the driver to analyse a range of information including acceleration, braking and lap times. Following its appearance on the new fourth-generation A-class hatchback, the new 35 badge is also planned to grace successor models to the CLA, CLA Shooting Brake, GLA as well as the newly-unveiled A-class saloon and upcoming GLB compact SUV, in a move that will provide a new six-model strong entry-level range for Mercedes-Benz’s performance sub-brand. 2 Link to post Share on other sites More sharing options...
Vratenza Supersonic September 21, 2018 Share September 21, 2018 A35 looks good! 1 Link to post Share on other sites More sharing options...
Runforyourlife 5th Gear September 21, 2018 Share September 21, 2018 Coe is allocated for my car liao. Car in sg but stuck with lta. Link to post Share on other sites More sharing options...
Freeder Hypersonic September 21, 2018 Share September 21, 2018 Mercedes-AMG A35 revealed with 302bhp https://www.autocar.co.uk/car-news/new-cars/mercedes-amg-a35-revealed-302bhp The highly-anticipated Mercedes-AMG A35 4Matic will feature a uniquely-tuned turbocharged 2.0-litre engine delivering 302bhp as well as a seven-speed dual clutch gearbox, on-demand four-wheel drive and a specially stiffened body when it goes on sale in the UK later this year. The new AMG model, planned to make its public debut at the Paris motor show in early October, is positioned between the latest A250 and upcoming second-generation A45 4Matic in the German car makerâs performance car line-up as a rival to the BMW M140i and Audi S3 as well as a raft of other hot hatchbacks, including the Volkswagen Golf R. Conceived to offer greater performance potential than the front-wheel drive A250 but at a price that is expected to see it pitched some £6,000 below that of the £41,230 A45 4Matic in the UK at around £35,000, the launch of the A35 4Matic comes after strong sales of the A45 4Matic and other four-cylinder AMG models, including the CLA45 4Matic, CLA45 Shooting Brake 4Matic and GLA45 4Matic. "The demand for our compact models has developed in recent years. This success has encouraged us to further expand our portfolio and place it on a broader footing," says Tobias Moers, CEO of Mercedes-AMG. At the heart of the A35 4Matic is a revised version of Mercedes-Benzâs M260 engine, as used by the A250. It is described by AMG as a new development, although the new four-cylinder unit shares its 83.0mm bore and 92.0mm stroke measurements and design of its die-cast aluminium crankcase with the M133 engine of the A45 4Matic. Key engineering attributes of the AMG tweaked powerplant include uniquely-tuned twin-scroll turbochargers with reduced back pressure, reprogrammed Camtronic variable valve control, special liners that contribute to conically shaped cylinders and a bespoke exhaust system with an automatically controlled flap that modulates the exhaust note depending on the driving mode. With 302bhp at 5800rpm and 295lb ft of torque between 3000 and 4000rpm, the transversely-mounted engine delivers 81bhp and 77lb ft more than the less heavily tuned version of the M260 unit used by the A250 but 74bhp and 55lb ft less than the more highly strung M133 engine used by the A45 4Matic. At the heart of the A35 4Matic is a revised version of Mercedes-Benzâs M260 engine, as used by the A250. It is described by AMG as a new development, although the new four-cylinder unit shares its 83.0mm bore and 92.0mm stroke measurements and design of its die-cast aluminium crankcase with the M133 engine of the A45 4Matic. Key engineering attributes of the AMG tweaked powerplant include uniquely-tuned twin-scroll turbochargers with reduced back pressure, reprogrammed Camtronic variable valve control, special liners that contribute to conically shaped cylinders and a bespoke exhaust system with an automatically controlled flap that modulates the exhaust note depending on the driving mode. With 302bhp at 5800rpm and 295lb ft of torque between 3000 and 4000rpm, the transversely-mounted engine delivers 81bhp and 77lb ft more than the less heavily tuned version of the M260 unit used by the A250 but 74bhp and 55lb ft less than the more highly strung M133 engine used by the A45 4Matic. Allied to the A35âs gearbox is a heavily revised version of the 4Matic four-wheel drive system used by the first-generation A45. It boasts variable distribution of drive, from front-wheel drive only to a 50:50 apportioning to the front and rear axles, via an electro-mechanically operated multi-plate clutch integrated into the rear axle assembly. The driver is able to choose between five different driving modes via an AMG Dynamic Select controller, including Slippery, Comfort, Sport, Sport+ and Individual. The Slippery mode, a new development that is also planned to appear on the new A45 when it is launched in 2019, is programmed for wet road conditions, with reduced power and torque and earlier upshifts in automatic mode. Also new is a so-called âglidingâ function. It allows the driver to choose between âreduced and âmoderateâ settings for differing engine braking characteristics while coasting on a trailing throttle within the Individual driving mode. With the Sport+ mode and Race Start function engaged, the A35 4Matic is claimed to accelerate from 0-to-62mph in 4.7sec and reach a top speed limited to 155mph. Combined cycle consumption is put at 38.7mpg, equating to average CO2 emissions of 167g/km on the recently superseded NEDC (New European Driving Cycle). This gives the A35 4Matic a slight edge over the M140i and S3, which are claimed to accelerate to 62mph in 4.8sec and 5.3sec respectively, in outright straight-line performance. To cope with the added performance potential brought on the A35 4Maticâs new drivetrain, Mercedes-AMG has stiffened the bodyshell of the A-class hatchback upon which it is based with the addition of a so-called âshear panelâ underneath the engine. The aluminium structure is bolted to the existing steel body shell and, in combination with two additional diagonal braces, is claimed to provide added torsional stiffness to the front end. The stiffened body structure supports a MacPherson strut front suspension. It uses a newly developed aluminium carrier and radially bolted steering knuckle that AMG claims reduces the unsprung masses and provides more sensitive response to the system used by the A45 4Matic. The rear suspension is based around the four-link system used by upper range A-class models, with three transverse arms and the trailing arm, the wheel carrier and bearings shared with those of the A45 4Matic. Passive dampers are standard, though buyers can option the new entry-level AMG model with an adaptive damping system that provides three different levels of stiffness. The electro-mechanical steering uses variable assistance and a more rigid mounting than the system used by other new A-class models. The brakes, meanwhile, use four-piston monoblock callipers and 350mm vented and perforated discs up front and single piston callipers and 330mm discs at the rear. The A35 4Matic builds on the sharpened appearance of the fourth-generation A-class with a unique grille, more heavily structured front bumper, standard 18-inch alloy wheels, wider sills, bold tailgate-mounted spoiler and a new rear bumper featuring a prominent diffuser element bookmarked each side by blackened round tailpipes. Inside, the standard A-class interior has been reworked with unique upholstery for the seats an AMG steering wheel with touch-pad controls and AMG specific graphics for the digital instruments, including a so-called Supersport mode with a large central round rev counter. Other new features include AMG Track Pace as part of the MBUX infotainment system. It permanently records data during track driving, enabling the driver to analyse a range of information including acceleration, braking and lap times. Following its appearance on the new fourth-generation A-class hatchback, the new 35 badge is also planned to grace successor models to the CLA, CLA Shooting Brake, GLA as well as the newly-unveiled A-class saloon and upcoming GLB compact SUV, in a move that will provide a new six-model strong entry-level range for Mercedes-Benzâs performance sub-brand. Congrats on your Neu Car 6 Link to post Share on other sites More sharing options...
BobbyTan_74287 4th Gear September 21, 2018 Share September 21, 2018 Coe is allocated for my car liao. Car in sg but stuck with lta. You buy from C&C and SE told u car stuck at LTA? When can deliver? 2 Link to post Share on other sites More sharing options...
Runforyourlife 5th Gear September 21, 2018 Share September 21, 2018 You buy from C&C and SE told u car stuck at LTA? When can deliver?No yes dont know. Link to post Share on other sites More sharing options...
Kar_lover Supercharged September 21, 2018 Share September 21, 2018 Nice but isn't this A3 SEDAN thread? Haha... Mercedes-AMG A35 revealed with 302bhp https://www.autocar.co.uk/car-news/new-cars/mercedes-amg-a35-revealed-302bhp The highly-anticipated Mercedes-AMG A35 4Matic will feature a uniquely-tuned turbocharged 2.0-litre engine delivering 302bhp as well as a seven-speed dual clutch gearbox, on-demand four-wheel drive and a specially stiffened body when it goes on sale in the UK later this year. The new AMG model, planned to make its public debut at the Paris motor show in early October, is positioned between the latest A250 and upcoming second-generation A45 4Matic in the German car maker’s performance car line-up as a rival to the BMW M140i and Audi S3 as well as a raft of other hot hatchbacks, including the Volkswagen Golf R. Conceived to offer greater performance potential than the front-wheel drive A250 but at a price that is expected to see it pitched some £6,000 below that of the £41,230 A45 4Matic in the UK at around £35,000, the launch of the A35 4Matic comes after strong sales of the A45 4Matic and other four-cylinder AMG models, including the CLA45 4Matic, CLA45 Shooting Brake 4Matic and GLA45 4Matic. "The demand for our compact models has developed in recent years. This success has encouraged us to further expand our portfolio and place it on a broader footing," says Tobias Moers, CEO of Mercedes-AMG. At the heart of the A35 4Matic is a revised version of Mercedes-Benz’s M260 engine, as used by the A250. It is described by AMG as a new development, although the new four-cylinder unit shares its 83.0mm bore and 92.0mm stroke measurements and design of its die-cast aluminium crankcase with the M133 engine of the A45 4Matic. Key engineering attributes of the AMG tweaked powerplant include uniquely-tuned twin-scroll turbochargers with reduced back pressure, reprogrammed Camtronic variable valve control, special liners that contribute to conically shaped cylinders and a bespoke exhaust system with an automatically controlled flap that modulates the exhaust note depending on the driving mode. With 302bhp at 5800rpm and 295lb ft of torque between 3000 and 4000rpm, the transversely-mounted engine delivers 81bhp and 77lb ft more than the less heavily tuned version of the M260 unit used by the A250 but 74bhp and 55lb ft less than the more highly strung M133 engine used by the A45 4Matic. At the heart of the A35 4Matic is a revised version of Mercedes-Benz’s M260 engine, as used by the A250. It is described by AMG as a new development, although the new four-cylinder unit shares its 83.0mm bore and 92.0mm stroke measurements and design of its die-cast aluminium crankcase with the M133 engine of the A45 4Matic. Key engineering attributes of the AMG tweaked powerplant include uniquely-tuned twin-scroll turbochargers with reduced back pressure, reprogrammed Camtronic variable valve control, special liners that contribute to conically shaped cylinders and a bespoke exhaust system with an automatically controlled flap that modulates the exhaust note depending on the driving mode. With 302bhp at 5800rpm and 295lb ft of torque between 3000 and 4000rpm, the transversely-mounted engine delivers 81bhp and 77lb ft more than the less heavily tuned version of the M260 unit used by the A250 but 74bhp and 55lb ft less than the more highly strung M133 engine used by the A45 4Matic. Allied to the A35’s gearbox is a heavily revised version of the 4Matic four-wheel drive system used by the first-generation A45. It boasts variable distribution of drive, from front-wheel drive only to a 50:50 apportioning to the front and rear axles, via an electro-mechanically operated multi-plate clutch integrated into the rear axle assembly. The driver is able to choose between five different driving modes via an AMG Dynamic Select controller, including Slippery, Comfort, Sport, Sport+ and Individual. The Slippery mode, a new development that is also planned to appear on the new A45 when it is launched in 2019, is programmed for wet road conditions, with reduced power and torque and earlier upshifts in automatic mode. Also new is a so-called “gliding” function. It allows the driver to choose between “reduced and “moderate” settings for differing engine braking characteristics while coasting on a trailing throttle within the Individual driving mode. With the Sport+ mode and Race Start function engaged, the A35 4Matic is claimed to accelerate from 0-to-62mph in 4.7sec and reach a top speed limited to 155mph. Combined cycle consumption is put at 38.7mpg, equating to average CO2 emissions of 167g/km on the recently superseded NEDC (New European Driving Cycle). This gives the A35 4Matic a slight edge over the M140i and S3, which are claimed to accelerate to 62mph in 4.8sec and 5.3sec respectively, in outright straight-line performance. To cope with the added performance potential brought on the A35 4Matic’s new drivetrain, Mercedes-AMG has stiffened the bodyshell of the A-class hatchback upon which it is based with the addition of a so-called “shear panel” underneath the engine. The aluminium structure is bolted to the existing steel body shell and, in combination with two additional diagonal braces, is claimed to provide added torsional stiffness to the front end. The stiffened body structure supports a MacPherson strut front suspension. It uses a newly developed aluminium carrier and radially bolted steering knuckle that AMG claims reduces the unsprung masses and provides more sensitive response to the system used by the A45 4Matic. The rear suspension is based around the four-link system used by upper range A-class models, with three transverse arms and the trailing arm, the wheel carrier and bearings shared with those of the A45 4Matic. Passive dampers are standard, though buyers can option the new entry-level AMG model with an adaptive damping system that provides three different levels of stiffness. The electro-mechanical steering uses variable assistance and a more rigid mounting than the system used by other new A-class models. The brakes, meanwhile, use four-piston monoblock callipers and 350mm vented and perforated discs up front and single piston callipers and 330mm discs at the rear. The A35 4Matic builds on the sharpened appearance of the fourth-generation A-class with a unique grille, more heavily structured front bumper, standard 18-inch alloy wheels, wider sills, bold tailgate-mounted spoiler and a new rear bumper featuring a prominent diffuser element bookmarked each side by blackened round tailpipes. Inside, the standard A-class interior has been reworked with unique upholstery for the seats an AMG steering wheel with touch-pad controls and AMG specific graphics for the digital instruments, including a so-called Supersport mode with a large central round rev counter. Other new features include AMG Track Pace as part of the MBUX infotainment system. It permanently records data during track driving, enabling the driver to analyse a range of information including acceleration, braking and lap times. Following its appearance on the new fourth-generation A-class hatchback, the new 35 badge is also planned to grace successor models to the CLA, CLA Shooting Brake, GLA as well as the newly-unveiled A-class saloon and upcoming GLB compact SUV, in a move that will provide a new six-model strong entry-level range for Mercedes-Benz’s performance sub-brand. Link to post Share on other sites More sharing options...
Robin 4th Gear September 21, 2018 Share September 21, 2018 Coe is allocated for my car liao. Car in sg but stuck with lta.Lta officers still admiring your a200? Link to post Share on other sites More sharing options...
Runforyourlife 5th Gear September 22, 2018 Share September 22, 2018 Lta officers still admiring your a200?Trying to find ways to make it ves surcharge maybe ha 2 Link to post Share on other sites More sharing options...
Toeknee_33 Turbocharged September 24, 2018 Share September 24, 2018 Get used to this backside, we are gonna be seeing lots of it soon! 4 Link to post Share on other sites More sharing options...
Robin 4th Gear September 24, 2018 Share September 24, 2018 Get used to this backside, we are gonna be seeing lots of it soon!Nice! 1 Link to post Share on other sites More sharing options...
Douglam 4th Gear September 24, 2018 Share September 24, 2018 Get used to this backside, we are gonna be seeing lots of it soon!Yep, already seeing quite a few. No? LOL 2 Link to post Share on other sites More sharing options...
Wt_know Supersonic September 25, 2018 Share September 25, 2018 (edited) isn't we have seen these tailights for many yearssss already? Edited September 25, 2018 by Wt_know 3 Link to post Share on other sites More sharing options...
Fuelsaver Supercharged September 25, 2018 Share September 25, 2018 Saw Edmund Motor listing the A hatch for some 148k for sports / amg. Not an attractive price if u ask me. Was expecting some 13xk already I felt quite max. Cabin space not anticipated as spacious as C class, rear quarters sitting kinda upright. Even equipment level is too notch, likely to consider other models at this price. 1 Link to post Share on other sites More sharing options...
kennytansk 3rd Gear September 25, 2018 Share September 25, 2018 isn't we have seen these tailights for many yearssss already? Yup, agree with u. Merc A backside looks really like the rear end of K3. Seem they copy cat Kia. So Y need to pay premium? 1 Link to post Share on other sites More sharing options...
DACH Supersonic September 25, 2018 Share September 25, 2018 Some good news to CLA buyers https://www.carscoops.com/2018/09/new-mercedes-benz-class-sedan-sold-alongside-current-cla/ Link to post Share on other sites More sharing options...
Runforyourlife 5th Gear October 3, 2018 Share October 3, 2018 So who else getting their ride? ↡ Advertisement Link to post Share on other sites More sharing options...
Mercedes Owners Thread
2021 5th Generation Mercedes Benz C-Class (W206)
2016 Mercedes E-class (W213)
[Spyshots] 2026 2nd Generation Mercedes Benz GLB
Mercedes Extended Warranty
