Charmaine12 3rd Gear April 28, 2018 Share April 28, 2018 Just to check, if 1.5l of mineral bottle burst and the water all went down to the floor carpet. Will it drain off from the bottom of the car ? Driving a VW, wanted to peel the carpet off to see underneath but cannot find the starting part of the carpet ↡ Advertisement Link to post Share on other sites More sharing options...
ER-3682 Twincharged April 28, 2018 Share April 28, 2018 On 4/28/2018 at 12:34 PM, Charmaine12 said: Just to check, if 1.5l of mineral bottle burst and the water all went down to the floor carpet. Will it drain off from the bottom of the car ? Driving a VW, wanted to peel the carpet off to see underneath but cannot find the starting part of the carpet Nope,if the Floorpan got holes,it means if you drive in the Rain,your interior will be Wet. Luckily is just Plain Water,if Sugar Drinks...good luck to You. 2 1 Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged April 28, 2018 Share April 28, 2018 There should be drain holes on the floor pan sealed with rubber cap. Jack up the car and take a look. 1 Link to post Share on other sites More sharing options...
Vratenza Supersonic April 29, 2018 Share April 29, 2018 My personal opinion. Since just mineral water, just go at it with hair dryer. Unless you are good with your hands. Not worth the while to pull the floor carpet lining as it usually requires removal of the side sill/door frame weather seal trimmings. I removed car seats and pulled back the carpet lining before for DIY sound cladding project many many cars ago.... Not easy....probably loss the same amount of sweat after you are done. 2 Link to post Share on other sites More sharing options...
ER-3682 Twincharged April 29, 2018 Share April 29, 2018 These few Morning got some very Hot Sun...open the Windows..just let it dry. Link to post Share on other sites More sharing options...
inlinesix Hypersonic April 29, 2018 Share April 29, 2018 How come you always have spillage in car? 1 Link to post Share on other sites More sharing options...
So_nice 6th Gear April 30, 2018 Share April 30, 2018 Put some a couple layers of newspaper over the affected area to soak up the moisture. Put 2 thirsty hippo also. Park under the sun and it should be fine. At least it’s not flavored drinks Link to post Share on other sites More sharing options...
Kb27 Supersonic April 30, 2018 Share April 30, 2018 Baking soda is always a good alternative to soak up excess water, and using a microfiber cloth. The cheap way is just to leave the car directly under the hot sun for a few hours. Link to post Share on other sites More sharing options...
Brass 6th Gear April 30, 2018 Share April 30, 2018 On 4/30/2018 at 4:08 PM, Kb27 said: Baking soda is always a good alternative to soak up excess water, and using a microfiber cloth. The cheap way is just to leave the car directly under the hot sun for a few hours. But second method might stink...given that it's damp.Just spend a dollar or two to get 500g of baking soda to dry it. Won't be stinky then. ↡ Advertisement Link to post Share on other sites More sharing options...
Anyone missing a car plate?
COE Bidding – Mar 2025
Xiaomi EV is Coming
Xiaomi EV is Coming
2024 Suzuki Swift
2024 Suzuki Swift
