Surf2004 Clutched March 10, 2018 Share March 10, 2018 Hi,Anyone using the above car mount ? Does it fall off when parked under the hot sun ?TIA ! ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Discoburg Supersonic March 10, 2018 Share March 10, 2018 Not sure about heat but it is marketed to stick to any surface so i guess it will stay. Hi,Anyone using the above car mount ? Does it fall off when parked under the hot sun ?TIA ! Link to post Share on other sites More sharing options...
Fcw75 Hypersonic March 11, 2018 Share March 11, 2018 Iottie is good stuff. Very sticky one, don’t worry. 1 Link to post Share on other sites More sharing options...
Surf2004 Clutched March 11, 2018 Author Share March 11, 2018 I’m now using Neo Grab. Stick on we’ll but after a few hours of baking under the sun, it falls off with my phone. So irritating that I decide to change it. 1 Link to post Share on other sites More sharing options...
Discoburg Supersonic March 11, 2018 Share March 11, 2018 Anyone using Spigen Kuel or have any reviews? Link to post Share on other sites More sharing options...
Dreamer_toons 2nd Gear March 14, 2018 Share March 14, 2018 Anyone using Spigen Kuel or have any reviews? I'm using their Kuel QS11 air con vent magnetic mount. It is stable and doesn't rattles compared to some other wind screen mounts. I bought quite a few wind screen mounts prior to this and all of them, regardless of brands and prices, dropped off after some time since I parked my car outdoor where I work. I have better experience with iOttie and it lasted the longest but it still dropped off 1 day. Hence, I switched to a magnetic ones. 2 Link to post Share on other sites More sharing options...
Discoburg Supersonic March 14, 2018 Share March 14, 2018 I'm using their Kuel QS11 air con vent magnetic mount. It is stable and doesn't rattles compared to some other wind screen mounts. I bought quite a few wind screen mounts prior to this and all of them, regardless of brands and prices, dropped off after some time since I parked my car outdoor where I work. I have better experience with iOttie and it lasted the longest but it still dropped off 1 day. Hence, I switched to a magnetic ones. Was looking at the Kiel suction holder. Now I just put the phone on my seat. Link to post Share on other sites More sharing options...
Wormee 5th Gear March 14, 2018 Share March 14, 2018 Hi, Anyone using the above car mount ? Does it fall off when parked under the hot sun ? TIA ! I'm using one gen earlier. Instead of having only the suction cup layer, Iottie has another sticky pad layer. Super sticky and does not fall off. It's quite hard to peel off if you intend to relocate it so stick it properly the first time. It does not leaves residue so don't worry. Cheers. 2 Link to post Share on other sites More sharing options...
kdash Supersonic March 16, 2018 Share March 16, 2018 please provide more info on your services... Link to post Share on other sites More sharing options...
Noelleon69 Clutched April 1, 2018 Share April 1, 2018 Iottie is worth the purchase. I used to be cheapo and just keep buying those cheap few bucks kind of phone mounts, but they always fall off and the moving part (which lets you adjust the angle) becomes loose after short while. Its irritating and so much hassle of having to buy new mounts again and again. I bought the iottie one touch 2 about 3 years ago from Amazon and never regretted the purchase, later upgraded to the version 3 and still using till date. I also like it for its ability to let you adjust the distance towards you and the flexibility of the angles. I've seen rebranded copycats on Taobao (cheaper of course) but I've no clue on the quality. I've also seen on qoo10 before, can also consider buying from there when there is discount coupon available. 1 Link to post Share on other sites More sharing options...
Janling3 6th Gear April 1, 2018 Share April 1, 2018 Hi, Anyone using the above car mount ? Does it fall off when parked under the hot sun ? TIA ! Yup, Iottie brand is very lasting. I bought it from Amazon for about $20, and have been using it since 2013 until now. All you need to do is just rinse the sticky gel pad once it drop off, then you got it like brand new again. Very satisfied with this Korean made product. Other cheaper stuff always fail and it is a waste of time and money. Link to post Share on other sites More sharing options...
Janling3 6th Gear April 1, 2018 Share April 1, 2018 (edited) I'm using their Kuel QS11 air con vent magnetic mount. It is stable and doesn't rattles compared to some other wind screen mounts. I bought quite a few wind screen mounts prior to this and all of them, regardless of brands and prices, dropped off after some time since I parked my car outdoor where I work. I have better experience with iOttie and it lasted the longest but it still dropped off 1 day. Hence, I switched to a magnetic ones. this brand look good, but I haven't tried. The IOttie one, just rinse the sticky gel pad, you can reuse it as good as new... :) Edited April 1, 2018 by Janling3 2 Link to post Share on other sites More sharing options...
Extremme 4th Gear April 8, 2018 Share April 8, 2018 Yup, Iottie brand is very lasting. I bought it from Amazon for about $20, and have been using it since 2013 until now. All you need to do is just rinse the sticky gel pad once it drop off, then you got it like brand new again. Very satisfied with this Korean made product. Other cheaper stuff always fail and it is a waste of time and money.Will the suction create a mark on the dashboard after a prolong time? Link to post Share on other sites More sharing options...
Noelleon69 Clutched April 10, 2018 Share April 10, 2018 Will the suction create a mark on the dashboard after a prolong time? Possible but I believe any marks left behind can be cleaned away easily. Link to post Share on other sites More sharing options...
Pancgom 1st Gear June 27, 2018 Share June 27, 2018 this brand look good, but I haven't tried. The IOttie one, just rinse the sticky gel pad, you can reuse it as good as new... :) There is a sales going on in Causeway point. SGD10 cheaper than list price. I got the one posted here. There is also the quick charge holder and iPad holder too. Sale is on at the atrium. 1 Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear June 27, 2018 Share June 27, 2018 Touch 4 is 39.90 if you buy online Link to post Share on other sites More sharing options...
fupo 1st Gear June 28, 2018 Share June 28, 2018 Once I started using Iottie the rest cannot make it. Very sticky. I changed from the normal version to the one with wireless charging. Very happy with it. Link to post Share on other sites More sharing options...
V-280 1st Gear June 28, 2018 Share June 28, 2018 Once I started using Iottie the rest cannot make it. Very sticky. I changed from the normal version to the one with wireless charging. Very happy with it. I don't have this brand but have another with wireless charging. The wireless charging is a game changer! ↡ Advertisement Link to post Share on other sites More sharing options...
Touch 'n Go App
Touch 'n Go App
Where is the most difficult and easiest place on Earth to gain citizenship?
Huawei Mate XT Tri Fold Phone
UMIDIGI mobile phone
Charging phone in car and impact on car battery
Malaysia Touch 'N Go Card post-COVID-19
Nothing Phone, Nothing but it's New to Me
FT discrimination agst locals
