Leesheng Neutral Newbie September 22, 2020 Author Share September 22, 2020 Giving you a quick peek of what goes on behind the scenes when we spray paint your car! Spray painting is a tedious process that requires a lot of patience & care to see through a perfect finish. If you are having any issues with your vehicle, feel free to give us a call @ 91546133 or 67477397 to make an appointment to head down to our workshop to get a quick diagnostics check! Link to post Share on other sites More sharing options...
Leesheng Neutral Newbie October 9, 2020 Author Share October 9, 2020 (edited) Are you taking your car maintenance seriously?? Car Service Promotion from $78/- Fukuoka Syn $78/- 24 Pts Check + 4L Syn Oil from $78- Premium Package + Car Wash Premium 24 points package + 1pc Oil filter + 4L Syn Oil Shell Syn Pkg fr $98/- Castrol Syn Pkg fr $118/- Motul Syn Pkg fr $118/- Economy Commercial Pkg 24Points Check Pkg + 7 L Oil + 1pc Oil filter 14W/40 Van/Lorry Pkg fr $68/- 5w/30 Van/ Lorry Pkg fr $128/- Getting your car maintenance regularly not only reduce unnecessary breakdowns also prevent further damage due to sudden failure of parts leading to consequences damages . An overdue maintenance may also lead to poor fuel economy and performance. Get your car service on time , Call us now at 67477397 or pm 91546133 Edited October 9, 2020 by Leesheng Link to post Share on other sites More sharing options...
Leesheng Neutral Newbie October 23, 2020 Author Share October 23, 2020 Toyota Hiace for weekly / month rental. WhatsApp to 91546133 Link to post Share on other sites More sharing options...
Leesheng Neutral Newbie November 5, 2020 Author Share November 5, 2020 Much like yourself, we wish to protect the people we love by keeping ourselves safe. Hence we provide free antibacterial fumigation for every vehicle that we service to give you peace of mind. Let's stay safe and strong together! Link to post Share on other sites More sharing options...
Leesheng Neutral Newbie December 11, 2020 Author Share December 11, 2020 (edited) Out of all the non-engine vehicle parts, the brake system is the most vital component to keep in check. Most owners know to change their brake pads regularly, but brake disc rotors also need to be paid attention to as brake pads only work when it grips onto the disc rotor to slow the wheels down. This BMW customer’s brake disk rotor and brake pads were worn out. Here, we’re inspecting and replacing them to put the vehicle back at 100% performance. Signs to look out for when your brake system needs maintenance: Brake discs are unevenly worn, cracked, or badly scored (looks like “vinyl record” with grooves) Squealing or squeaking when braking Rattling, wobbling, or shaking while braking. Prevention is better than cure Failing to replace your brake pads when they are worn down will lead to your brake disc rotor being worn out as well. Bring your vehicle in for servicing at Lee Sheng Auto before total brake failure occurs. Safe driving! WhatsApp us for more info. Edited December 11, 2020 by Leesheng Link to post Share on other sites More sharing options...
Leesheng Neutral Newbie December 21, 2020 Author Share December 21, 2020 Drive shafts are constantly moving at very fast paces to keep up with your vehicle’s speed. They need to remain balanced and weighted evenly to do this properly. If you feel: Vibrations, especially at the steering wheel Clunking noises when accelerating Squeaky noises from underneath the vehicle Heavy resistance from wheels from turning You may have a bad drive shaft that needs replacing. Although there are many car maintenance tasks you can DIY, this is one better left to a professional. Leave it in the knowledgeable hands of the mechanics at Lee Sheng Auto. WhatsApp us for more info. Link to post Share on other sites More sharing options...
Leesheng Neutral Newbie January 6, 2021 Author Share January 6, 2021 The engine mount holds the engine in your car. The most common problem that we see is when the rubber part breaks/separates or when the mount leaks Some drivers, like this VW owner, detected an increase in engine noise and vibration when the car was at idle. This is a common sign of many other car issues thus all other issues need to be ruled out by the process of elimination. Although there are many car videos out there for this easy fix, we still recommend drivers to consult a mechanic to do a thorough check to find the root cause of the vibration/noise. Let Lee Sheng Auto assist you in troubleshooting the probable issues WhatsApp us for more info. Link to post Share on other sites More sharing options...
Leesheng Neutral Newbie January 22, 2021 Author Share January 22, 2021 Always go to a proper mechanic to replace your car tyres! It is the only part of the car that comes in direct contact with the roads, and it supports the entire weight of the vehicle. Thus, proper maintenance and installation of car tyres is vital to a smooth drive There are many issues that can present itself with car tyres: Improper car inflation: Overinflated tyres loses road grip and under-inflated tyres wear and tear easily Cracking and Bulging: These car tyres cannot be repaired and need to be replaced immediately Heat Damage: Common issue in Singapore, but drivers that speed regularly also result in heat damaged tyres. Overall, tyres have an average life span of 5-10 years. The better the quality of the tyre, the longer its longevity. Replacement of car tyres are usually inevitable and will naturally happen over the course of your driving life. A reputable workshop, like Lee Sheng Auto, will ensure that only good quality, branded car tyres are used and properly installed WhatsApp us for more info. Link to post Share on other sites More sharing options...
Innocuous 3rd Gear January 26, 2021 Share January 26, 2021 Hi If I wanna spray my B200 silver color to Emerald green How much and how long ?? Thanks Link to post Share on other sites More sharing options...
Leesheng Neutral Newbie February 5, 2021 Author Share February 5, 2021 Testing testing 1-2-3 Checking your car battery’s health once or twice a year could save you from a lot of unnecessary trouble. The car battery is essential to many of the car’s assistive functions (e.g. lights, powering up the car, managing the AC). A simple and quick job such as a battery test can help to maximise battery life and ensure that it is performing optimally for your car. WhatsApp us at Lee Sheng Auto for all your car servicing needs! Link to post Share on other sites More sharing options...
Leesheng Neutral Newbie February 16, 2021 Author Share February 16, 2021 Refurbishing of an old Alpa Romeo WhatsApp us for any enquiry. Link to post Share on other sites More sharing options...
Leesheng Neutral Newbie March 11, 2021 Author Share March 11, 2021 Servicing Promo Delay in oil change affect engine performance and harm car engine . Hence is important to get your car service on time Servicing packages from $98/- only 4L engine Oil 5w/40 1 pc oil filter 24 points check Car wash Free wireless charger 𝙾𝚃𝙷𝙴𝚁 𝙿𝙰𝙲𝙺𝙰𝙶𝙴 𝙰𝚅𝙰𝙸𝙻𝙰𝙱𝙻𝙴 ! Motul 5w/40 $118/- Castrol 5w/40 $118/- Honda 0w/20 $128/- Shell diesel 14w/40 $78/- 𝐖𝐇𝐀𝐓𝐒𝐀𝐏𝐏 us f𝐨𝐫 𝐀𝐩𝐩𝐨𝐢𝐧𝐭𝐦𝐞𝐧𝐭𝐬 / 𝐄𝐧𝐪𝐮𝐢𝐫𝐲 Link to post Share on other sites More sharing options...
Leesheng Neutral Newbie June 14, 2021 Author Share June 14, 2021 Is your air con cold enough?? Do you know that like engine oil , the air con compressor oil need to be replace periodically as the metal friction in the compressor will cause the oil to be dirty and affect the performance of the air con compressor. Send in your car for a general air con service which include changing the compressor oil and flush and top up air con gas at $60/- 𝐖𝐇𝐀𝐓𝐒𝐀𝐏𝐏 us f𝐨𝐫 𝐀𝐩𝐩𝐨𝐢𝐧𝐭𝐦𝐞𝐧𝐭𝐬 / 𝐄𝐧𝐪𝐮𝐢𝐫𝐲 Link to post Share on other sites More sharing options...
Leesheng Neutral Newbie July 9, 2021 Author Share July 9, 2021 Accidentally scratched your car ? Had an accident and need to make an insurance claim? Be it a small dent or an insurance claim, call or whatsapp to us @ 91546133 for an without obligation quotation Link to post Share on other sites More sharing options...
Leesheng Neutral Newbie August 4, 2021 Author Share August 4, 2021 Car Servicing are necessary to prevent expensive repairs. All parts in the car will eventually breakdown . Regular servicing ensure mechanical wear are tackle before it caused you to be stranded on the road and lead to expensive repair such as a leaking water hose may lead to overheating and a blow gasket. We are an established workshop with 42 over years history. We offer experienced and trust worthy repairs on car servicing and maintenance on all Japanese and Continental make vehicle . Don’t missed out on our Servicing Promotion .Enjoy free: Interior Disinfection Clean Absorbent Car Wash Cloth Call or Whatsapp our friendly advisor today to find out more :WhatsApp Lay Hoon / WhatsApp Ah Ching Link to post Share on other sites More sharing options...
Leesheng Neutral Newbie August 30, 2021 Author Share August 30, 2021 Engine Mounting holds the engine to the car body and cushioned the vibration of the engine. A good engine mounting is necessary for a comfortable ride. When the rubber portion of the engine mounting break apart it no longer cushioned the vibration of the engine vibration. You will experience excess vibration of the car at idle and increasing engine rattling noise .This is especially so when you engage transmission at idle . Most car works on 4 engine mounting , namely the left mounting , right mounting , front & gear box mounting . Any one of it cracked will affect your otherwise smooth and comfortable ride. Send in your car for a free engine mounting check if you feel your car is vibrating excessively. Our careful and mechanic will inspect and advise you whether the vibration is due to a cracked engine mount. You can also send your car in for an Engine Servicing which will include inspection of such wear and tear parts. We are an established workshop with over 42 years of history. We offer experienced and trust worthy engine repairs , accident repairs & spray painting on all Japanese and Continental make vehicle . We are also the authorized accident reporting and repairs workshop for NTUC Income Insurance . Call or Whatsapp our friendly advisor today to find out more : WhatsApp Lay Hoon / WhatsApp Ah Ching Lay Hoon 91546133 / Ah Ching 81827966 Link to post Share on other sites More sharing options...
Leesheng Neutral Newbie September 16, 2021 Author Share September 16, 2021 Accidentally scratched your car ? Had an accident ? We specialized in accident claim , accident repairs and spray painting. We are the authorized workshop for NTUC Income Insurance Co-operative Ltd and India International Insurance . Call or WhatsApp to 91546133 on any accident claim , accident reporting or repair matters. Link to post Share on other sites More sharing options...
Leesheng Neutral Newbie September 28, 2021 Author Share September 28, 2021 Is the amber engine warning light blinking on your dashboard? Don't worry. When the engine light is illuminated it does not necessarily mean something serious had happened. Sometimes a simple reset may solve the problem. We specialized in all kinds of engine check light reset and repair. Our up to date scanner will pick up the reason the light is illuminated. Call or Whatsapp our friendly advisor today to find out more : WhatsApp Lay Hoon / WhatsApp Ah Ching Lay Hoon 91546133 / Ah Ching 81827966 Link to post Share on other sites More sharing options...
Car repair and maintenance
Catalyst converter issue
Workshops with engine oil flushing machine
