Adrianli Hypersonic December 21, 2017 Share December 21, 2017 Like I said, most likely don't need to do that. Go check if your telephone lines are actually network cables or not first. I have most of the DIY tools you'd need to get it done if you wanna DIY (gotta find them from my storeroom first). My HDB flat already comes wired with network cable to all power sockets. I am currently tapping on this wired network for my mio tv. But it is not suitable if i wana move my router out of the cabinet to my desired location. ↡ Advertisement Link to post Share on other sites More sharing options...
Kusje Supersonic December 21, 2017 Share December 21, 2017 My HDB flat already comes wired with network cable to all power sockets. I am currently tapping on this wired network for my mio tv. But it is not suitable if i wana move my router out of the cabinet to my desired location. Oh. Then set the router in the cabinet as a bridge. Buy a new router (for the bedroom) and connect to the bridge. 1 Link to post Share on other sites More sharing options...
Dleodleo Twincharged December 21, 2017 Share December 21, 2017 I am not sure what is the market rate, I asked one that I found from Gumtree. they came to take out the 3 old ceiling lights and install the new ones I bought. $40 each light for their service. but I won't recommend the one I engaged they are not that bad but probably 80% of my expectations Mine is first ceiling light $40 and subsequent light S$10 each (for replacing of ceiling light). He's a Singaporean uncle. 2 Link to post Share on other sites More sharing options...
Atrecord Supersonic December 21, 2017 Share December 21, 2017 Another useful topic after the aircon one... My place is coming to 6 yr, and things are reaching the stage where they stop working one by one. sigh... Those knowledgeable bros here, need some advice: 1) for a 32 year-old flat, is there any pressing or serious need to rewire the whole flat? If wires are 30+ year old, is there any reason why they cannot continue to be used for the next, say, 20 yr? 2) i'm also thinking of changing my current cove lights from energy-saving T5 (i think), to LEDs. Is it really simple plug and play, and just replace the whole tube(s), or the connector, cable needs to be replaced? 3) In 2 bedrooms, we have cove lights (2-3 tubes), plus 2 down lights (energy-saving and on i recall electronic ballast or something - the shops said that will flicker less and so are more recommended for studying, as they will be better for the kids' eyes). The T5 (again, i think) cove lights had blown a few. I should be able to either buy new ones or change to LED, if not difficult/expensive. But the down lights are all blown, and merely changing the bulbs don't solve the problem. I'm not sure whether the ballasts are the problem, or could it be the wiring (is that likely/possible?)? tks... 2 Link to post Share on other sites More sharing options...
dcb Turbocharged December 21, 2017 Author Share December 21, 2017 1. I will replace them for a better piece of mind. 2. I just did that. My current T5 bulbs have a different connector to the new LED T5 thats why i was looking for a electrician to help me changed them all. 3. No idea Another useful topic after the aircon one... My place is coming to 6 yr, and things are reaching the stage where they stop working one by one. sigh... Those knowledgeable bros here, need some advice: 1) for a 32 year-old flat, is there any pressing or serious need to rewire the whole flat? If wires are 30+ year old, is there any reason why they cannot continue to be used for the next, say, 20 yr? 2) i'm also thinking of changing my current cove lights from energy-saving T5 (i think), to LEDs. Is it really simple plug and play, and just replace the whole tube(s), or the connector, cable needs to be replaced? 3) In 2 bedrooms, we have cove lights (2-3 tubes), plus 2 down lights (energy-saving and on i recall electronic ballast or something - the shops said that will flicker less and so are more recommended for studying, as they will be better for the kids' eyes). The T5 (again, i think) cove lights had blown a few. I should be able to either buy new ones or change to LED, if not difficult/expensive. But the down lights are all blown, and merely changing the bulbs don't solve the problem. I'm not sure whether the ballasts are the problem, or could it be the wiring (is that likely/possible?)? tks... Any make and model to recommend? My MBR also gets poor wifi. Bro - go Challenger buy a Pair of Home plug will do.. cheap and good and fast. Link to post Share on other sites More sharing options...
AndrewLee72 6th Gear December 21, 2017 Share December 21, 2017 Hi Adrianli - Homeplug disrupt neighbour signal? hahahaha - first time i hear such bull crap - I got 3 home plugs in my house - all swee swee. If you already home network points in your rooms, just buy Access Points put in yr room will do. Must configure though. Make sure room lan points all go back to your existing fibre router. If not enough ports buy a 8 port Gigabyte switch will do. Try SLS - 5th floor - Mediapro shop. Very pro in AP. Price oso cheap. Pay abit more they can configure the AP for you. Ask for Engenius AP. 5 Link to post Share on other sites More sharing options...
zipping Supersonic December 21, 2017 Share December 21, 2017 (edited) I wana check if electrician is able to relocate my router. Currently, the router and fibre point is located next to the door inside the utility cabinet. The master bedroom not able to get WiFi signal. So using a Wi-Fi extender in master bedroom but signal strength is a bit weak. Need to relocate my router to the middle of the flat so whole flat got strong Wi-Fi signal. Refer to drawing. Red dot is current location and blue dot is disired location. HDB 5 room floor plan.jpg since homeplug or repeater/extender router at e blue spot not an option...... can try tis... Mesh wi-fi router ... get e 3 pcs de....1 at red and blue point ea...and 1 in e master bdrm u can either buy it outright or rent it fr ur fiber provider Edited December 21, 2017 by zipping 3 Link to post Share on other sites More sharing options...
AndrewLee72 6th Gear December 22, 2017 Share December 22, 2017 Challenget got sell mesh. Not cheap. AP still the best and gives faster n consistant wifi speed n coverage. Can set guest network oso Link to post Share on other sites More sharing options...
dcb Turbocharged December 22, 2017 Author Share December 22, 2017 I am looking for home plug also. Its just one piece connect to power socket and lan cabled to the router then the other piece just plug into a wall socket in my MBR thats all? Easy peasy? Hi Adrianli - Homeplug disrupt neighbour signal? hahahaha - first time i hear such bull crap - I got 3 home plugs in my house - all swee swee. If you already home network points in your rooms, just buy Access Points put in yr room will do. Must configure though. Make sure room lan points all go back to your existing fibre router. If not enough ports buy a 8 port Gigabyte switch will do. Try SLS - 5th floor - Mediapro shop. Very pro in AP. Price oso cheap. Pay abit more they can configure the AP for you. Ask for Engenius AP. Link to post Share on other sites More sharing options...
AndrewLee72 6th Gear December 22, 2017 Share December 22, 2017 Yes home plus work in pairs. But note : its for HDB / Condo - single floor. If landed house - of 2nd floor or to 3rd floor - it may not work - depending on 230v ac what type of phase... Link to post Share on other sites More sharing options...
Mustank Hypersonic December 22, 2017 Share December 22, 2017 (edited) Anyone can share the estimated cost of providing and installing a 2 gang outdoor waterproof socket? IP66 classed. Fellow is quoting me 130 bucks which I don't feel is reasonable. There's no additional transport cost involved because this is an optional quote on top of some of the more firm jobs I am giving him at the same time. Quote for those other jobs appear reasonable. Ip66 2 gang cased got different brand one Hager very expensive like $55-$60 Cheaper one I found got about $30 I am looking for home plug also. Its just one piece connect to power socket and lan cabled to the router then the other piece just plug into a wall socket in my MBR thats all? Easy peasy?Yes Edited December 22, 2017 by Mustank 3 Link to post Share on other sites More sharing options...
Kklee 6th Gear December 22, 2017 Share December 22, 2017 (edited) I am looking for home plug also. Its just one piece connect to power socket and lan cabled to the router then the other piece just plug into a wall socket in my MBR thats all? Easy peasy? There are many variations. I would suggest getting Homeplug AV2 standard of at least AV1200 with powerline pass-thru. IMHO, the powerline pass-thru (3-pin socket) is an important featutre as it has noise filtering (TPLink). You should use this socket to power all your devices. As there is only 1 socket, you may want to use a power extension bar. I am running 6x TPLink AV1200 with powerline pass-thru. For setup, you can pair them side by side and test before relocating to the intended location. Edited December 22, 2017 by Kklee 3 Link to post Share on other sites More sharing options...
Kusje Supersonic December 22, 2017 Share December 22, 2017 Ip66 2 gang cased got different brand one Hager very expensive like $55-$60 Cheaper one I found got about $30 Yes I'm being quoted for MK brand. Actually, these kind of plugs won't spoil easily also... I don't really care what they use. 1 Link to post Share on other sites More sharing options...
dcb Turbocharged December 22, 2017 Author Share December 22, 2017 So you re recommending the below mentioned make and model ah? I am running 6x TPLink AV1200 with powerline pass-thru. For setup, you can pair them side by side and test before relocating to the intended location. Link to post Share on other sites More sharing options...
Kklee 6th Gear December 22, 2017 Share December 22, 2017 So you re recommending the below mentioned make and model ah? No leh. The are at least 6 variants of AV1200. The ones I used are Model - TL-PA8010P Kit Model - TL-PA8030P Kit Link to post Share on other sites More sharing options...
Othello Supersonic December 22, 2017 Share December 22, 2017 Ip66 2 gang cased got different brand one Hager very expensive like $55-$60 Cheaper one I found got about $30 Yes bro, can share which brand ? Thanks. Link to post Share on other sites More sharing options...
Mustank Hypersonic December 23, 2017 Share December 23, 2017 bro, can share which brand ? Thanks.No brand oneI found jt in a electrical shop in north star Ang Mo Kio first floor I don’t know the shop name They are bigger than a beighbourhood hardware shop and sells more specialized electrical stuff which cannot find in neighborhood hardware shop one 2 Link to post Share on other sites More sharing options...
dcb Turbocharged December 23, 2017 Author Share December 23, 2017 My colleague tell me home plugs is useless as he tried before. However he recommends changing to an Asus router for better wifi coverage. ↡ Advertisement Link to post Share on other sites More sharing options...
Simple home DIY repairs
Shopee Singapore
Shopee Singapore
Home Aircon
Home Aircon
Christmas lightup 2022!
