Atrecord Supersonic August 31, 2020 Share August 31, 2020 31 minutes ago, inlinesix said: All this information is available from Cellink app. I got this battery after my previous battery died (4+ years usage) and review from @Adrianli The battery is connect to ciggy charger. Whenever the car is powered up, it will be charged. oh, ok, so i'm learning from the sifu here... had previously thought of getting the batt, but later feared it won't work in my case, cos of my travel/usage pattern... let's see if this will change... ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Adrianli Hypersonic August 31, 2020 Share August 31, 2020 (edited) 8 minutes ago, Atrecord said: Yup, i don't use an external batt, and just leave the cam to shut down when batt falls below the set voltage. Understand the two independent items. But if the batt is fully charge, and it states that useable time can be, let's say, 30 hr... Then this 30 hr is based on what assumption? If i park in a MSCP top level where there's very little human/vehicular traffic, so the motion detector will hardly be triggered to record in parking mode (this is called standby mode, right?), does it mean this can last for 30 hr, before the batt is flat too? Then if parked at let's say an open-air carpark near MRT/market, where every min also got people/car moving in front/behind, then it will trigger the parking mode recording almost continuously, then likely it will mean the batt will likely be used up faster, right? I mean, if my car pumped full tank, if i one pax drive on highway, likely can go 700 km. But if carries full 5 pax, and travel uban roads, then i'll be glad if i can stretch to 500 km. The battery usage indicator is an estimate of the camera battery consumption in the amount of amps drawn from the battery by the camera. Let's say the camera will draw 1 amp from the battery in parking mode. The battery capacity is 1,000mah. Therefore the usage time is 1hr. 1 amp = 1,000 milli-amp. "mah" = milli-amp-hour. So the calculation is based on the manufacturer's estimate of amp drawn from the battery. If you connect 6 or 7 cameras to the battery, definitely the amp drawn will be more thus the usuage time will be decreased and different from the manufacturer's indicated time. The amount of amp drawn by the camera in parking mode should be somewhat constant (negligible difference) as it is constantly recording regardless of any motion or impact. Only when motion and impact then write into the memory card. Edited August 31, 2020 by Adrianli 2 Link to post Share on other sites More sharing options...
Atrecord Supersonic August 31, 2020 Share August 31, 2020 32 minutes ago, Adrianli said: Charging time is indicated in the photo too. Just that the photo posted, the power to the battery is cut, thus showing 00:00. If it is powered, it will show the number of mins to full charge. It can be either hard wired to fuse box for faster charging or thru cig plug for slower charging. Step more oil also no use as there is the fuse, thickness of the wire gauge and ability of the charger to accept more amps. Same for your HP chargers. You connect to 220V for the charger. If you connect to 440V (aka step oil more), what will happen, you will know right? Kaboom. See magic smoke from genie. ha ha ha... ok ok. I layman, only know last time drive old car, or rather young time saw my father drive old car, early morning crank engine like won't start, then once started, will step oil a bit... then last time when batt flat, my mechanic came to jump start liao, also asked me to let batt charge with engine running for 30 min... also got stepped oil a bit now and then. I have been tempted to try using the macbook usb-C charger to charge handphone, but never dared to try... guess i made the right choice, right? 😆 Link to post Share on other sites More sharing options...
iamahbee 5th Gear August 31, 2020 Share August 31, 2020 14 minutes ago, Atrecord said: Yup, i don't use an external batt, and just leave the cam to shut down when batt falls below the set voltage. Understand the two independent items. But if the batt is fully charge, and it states that useable time can be, let's say, 30 hr... Then this 30 hr is based on what assumption? If i park in a MSCP top level where there's very little human/vehicular traffic, so the motion detector will hardly be triggered to record in parking mode (this is called standby mode, right?), does it mean this can last for 30 hr, before the batt is flat too? Then if parked at let's say an open-air carpark near MRT/market, where every min also got people/car moving in front/behind, then it will trigger the parking mode recording almost continuously, then likely it will mean the batt will likely be used up faster, right? I mean, if my car pumped full tank, if i one pax drive on highway, likely can go 700 km. But if carries full 5 pax, and travel uban roads, then i'll be glad if i can stretch to 500 km. Yes, I believe power consumption in parking mode is dependent on your camera and its settings for event logs, on top of the resolution settings, night mode, etc. For most cameras, you can set the sensitivity of motion detection and for some, even the area of detection. 1 Link to post Share on other sites More sharing options...
Adrianli Hypersonic August 31, 2020 Share August 31, 2020 12 minutes ago, Atrecord said: ha ha ha... ok ok. I layman, only know last time drive old car, or rather young time saw my father drive old car, early morning crank engine like won't start, then once started, will step oil a bit... then last time when batt flat, my mechanic came to jump start liao, also asked me to let batt charge with engine running for 30 min... also got stepped oil a bit now and then. I have been tempted to try using the macbook usb-C charger to charge handphone, but never dared to try... guess i made the right choice, right? 😆 That is mechanical motion (engine) to electrical energy (alternator). Here we are talking about electrical energy (fuse box) to electrical energy (battery). As long as voltage and amp draw is same, can use. 1 Link to post Share on other sites More sharing options...
Adrianli Hypersonic August 31, 2020 Share August 31, 2020 9 minutes ago, iamahbee said: Yes, I believe power consumption in parking mode is dependent on your camera and its settings for event logs, on top of the resolution settings, night mode, etc. For most cameras, you can set the sensitivity of motion detection and for some, even the area of detection. Let me use an analogy of using your hp to watch a show. How much power is consumed when : 1) Watching a movie streaming 2) Playback a downloaded movie The power consumption difference between the two activities are really negligible. You will not feel the difference on the amount of power consumed. The battery usage will be almost similar. 2 Link to post Share on other sites More sharing options...
Lotr 6th Gear August 31, 2020 Share August 31, 2020 My car cam is installed a few years ago draws power directly from battery so it is always on. The cam has low voltage cutoff and so far my battery is ok, though I change battery every 12-18 months Dunno why nowadays the cam's is only on when engine is running and need to get battery pack if we want parking mode. Is it because of different batteries used for engines with auto start-stop function? Link to post Share on other sites More sharing options...
Adrianli Hypersonic August 31, 2020 Share August 31, 2020 2 minutes ago, Lotr said: My car cam is installed a few years ago draws power directly from battery so it is always on. The cam has low voltage cutoff and so far my battery is ok, though I change battery every 12-18 months Dunno why nowadays the cam's is only on when engine is running and need to get battery pack if we want parking mode. Is it because of different batteries used for engines with auto start-stop function? In modern cars, more of Conti cars, the ECU will sense the drop in battery voltage and will cut all unnecessary power. Thus battery pack is a go around solution. As the car gets smarter, you need new ways to go around it. More electronics = more headaches. Unless car manufacturer willing to produce bare bones cars now. Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic September 24, 2020 Share September 24, 2020 Talking about hit and run into a new level 9 Link to post Share on other sites More sharing options...
Hamburger Hypersonic December 13, 2020 Share December 13, 2020 The car in the attached pix hit my rear bumper in a open air car park. Came down and gave me his hp number and verbalised that he will settle it amicably. Its also a PHV registered car. Texted him yesterday and no response till date. Just my luck to meet this kind of person with little or no integrity. Guys, you been warned of such audi. 1 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic December 13, 2020 Share December 13, 2020 Wolero is PHV hired car I think. Maybe not own car, bo chap.... 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic December 13, 2020 Share December 13, 2020 15 minutes ago, Hamburger said: The car in the attached pix hit my rear bumper in a open air car park. Came down and gave me his hp number and verbalised that he will settle it amicably. Its also a PHV registered car. Texted him yesterday and no response till date. Just my luck to meet this kind of person with little or no integrity. Guys, you been warned of such audi. https://www.wolero.com/ Make 3rd party claim lor. If the insurer rejects, complain to MAS. https://www.sgdi.gov.sg/ministries/pmo/statutory-boards/mas/departments/mdo 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic December 13, 2020 Share December 13, 2020 1 hour ago, inlinesix said: https://www.wolero.com/ Make 3rd party claim lor. If the insurer rejects, complain to MAS. https://www.sgdi.gov.sg/ministries/pmo/statutory-boards/mas/departments/mdo It's a blemish on the bumper that cost no more than 200. I rather suck it up than to go through the hustle. Next time I see any phv driver, it's cash on the spot. 1 Link to post Share on other sites More sharing options...
Comage 5th Gear December 13, 2020 Share December 13, 2020 3 hours ago, Hamburger said: It's a blemish on the bumper that cost no more than 200. I rather suck it up than to go through the hustle. Next time I see any phv driver, it's cash on the spot. Cash on the spot and they will claim "aiyar Boss, I no have enough money right now! You see my wallet!" And if they have more than $200 - they'll just cook up some sob story that they need the money to pay hospital bill to bring the old mother home. You can't restrain them, and you can't call police unless someone's injured. Just take picture of their NRIC and phone number - and CALL the phone number on the spot to make sure it's a valid phone number. If the guy has multiple phones in their car, make sure to get every single number and call up your phone to get the number - they could have used a pre-paid number and dumped that number to you. Otherwise, if want to hit them where it hurts - just file the claim and you will see them kneeling down begging not for you to burn their NCD premiums... 2 Link to post Share on other sites More sharing options...
shrjun 5th Gear December 13, 2020 Share December 13, 2020 5 hours ago, inlinesix said: https://www.wolero.com/ 5 hours ago, Hamburger said: The car in the attached pix hit my rear bumper in a open air car park. Came down and gave me his hp number and verbalised that he will settle it amicably. Its also a PHV registered car. Texted him yesterday and no response till date. Just my luck to meet this kind of person with little or no integrity. Guys, you been warned of such audi. Report to insurer stat. 1 Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear December 13, 2020 Share December 13, 2020 1 hour ago, Comage said: Cash on the spot and they will claim "aiyar Boss, I no have enough money right now! You see my wallet!" And if they have more than $200 - they'll just cook up some sob story that they need the money to pay hospital bill to bring the old mother home. You can't restrain them, and you can't call police unless someone's injured. Just take picture of their NRIC and phone number - and CALL the phone number on the spot to make sure it's a valid phone number. If the guy has multiple phones in their car, make sure to get every single number and call up your phone to get the number - they could have used a pre-paid number and dumped that number to you. Otherwise, if want to hit them where it hurts - just file the claim and you will see them kneeling down begging not for you to burn their NCD premiums... Taxi drivers the worst kind Link to post Share on other sites More sharing options...
Happylife88 Clutched April 19, 2021 Share April 19, 2021 Need some advices, as my car ganna hit n run yesterday evening when I was at the petrol kiosk in woodlands. Went in to pay for the pump when a Honda trying to squeeze in between my car n other car to get behind to pump. His side mirror scratches side of my car n created a dent too. The culprit actually came out of his car n take a look... I hv in car cam video capturing his car plate n saw that there is a jerk to his car when the scratches n dent happened. He then parked his car n Went to his side mirror to check n then drove off. Reported to police for hit n run n to my insurer too. Understood from my insurer that his insurer is income May I know what is the chances of claiming against him...very sian. Link to post Share on other sites More sharing options...
Soundphile 2nd Gear April 19, 2021 Share April 19, 2021 46 minutes ago, Happylife88 said: Need some advices, as my car ganna hit n run yesterday evening when I was at the petrol kiosk in woodlands. Went in to pay for the pump when a Honda trying to squeeze in between my car n other car to get behind to pump. His side mirror scratches side of my car n created a dent too. The culprit actually came out of his car n take a look... I hv in car cam video capturing his car plate n saw that there is a jerk to his car when the scratches n dent happened. He then parked his car n Went to his side mirror to check n then drove off. Reported to police for hit n run n to my insurer too. Understood from my insurer that his insurer is income May I know what is the chances of claiming against him...very sian. 100% win for your case. investigation may take a while (IO need to get your dashcam video and even the petrol kiosk video if necessary). Let insurance company handle your repair, don't accept to pay out of your pocket first. ↡ Advertisement Link to post Share on other sites More sharing options...
Teens in pmd checking for cashcard in the iu bikes or any vehicles with unlock doors
Why run on four limbs when you can run faster with two legs?
Car Owners Who Chope (Hog) HDB Car Park Lots
Using hose in mscp
Using hose in mscp
Slowly slowly reverse your car hor lol
Coin operated water dispenser @ MSCP washing bay
New Self Help Car Care at MSCP
