adrian140180 5th Gear January 11, 2019 Share January 11, 2019 Seems like one of the greens went to the motor show!! That is the only place it belongs. ↡ Advertisement Link to post Share on other sites More sharing options...
Daniu82 Supercharged January 11, 2019 Share January 11, 2019 And the showroom. That is the only place it belongs. Link to post Share on other sites More sharing options...
walkofwinners 4th Gear January 11, 2019 Share January 11, 2019 Curious why no one interested in the space back? Price is reasonable As compared to other cars too Link to post Share on other sites More sharing options...
adrian140180 5th Gear January 11, 2019 Share January 11, 2019 Curious why no one interested in the space back? Price is reasonable As compared to other cars too 1) Because everyone waiting on the scala. 2) Not heavily marketed unlike the rest of the models. 3) The 1.4 tsi engine in used is the old one, been in use like since 2009. Pretty much all the single charged golfs, jettas, and FL scirocco is using this. 4) Looks funny. Link to post Share on other sites More sharing options...
walkofwinners 4th Gear January 11, 2019 Share January 11, 2019 1) Because everyone waiting on the scala. 2) Not heavily marketed unlike the rest of the models. 3) The 1.4 tsi engine in used is the old one, been in use like since 2009. Pretty much all the single charged golfs, jettas, and FL scirocco is using this. 4) Looks funny. I think engine should be OK, main worry is the gearbox. For a moment, thought its the same 1.4 on Octavia but detuned Link to post Share on other sites More sharing options...
adrian140180 5th Gear January 11, 2019 Share January 11, 2019 I think engine should be OK, main worry is the gearbox. For a moment, thought its the same 1.4 on Octavia but detuned Engine is fine, spare parts easy to find, won't blow your piston seals with the amount of compression on this one. DQ200 gearbox is fine also lah, everyone heard all the horror stories about it, and it will keep going round and round. Truth is, it is an ok gearbox. Take it from me, ex jetta single charge owner, same engine, and gearbox, mod here mod there, drive like monster. DQ200 only tell me it is going to die please change it out at the 160K mark. 2 Link to post Share on other sites More sharing options...
badlammy 6th Gear January 11, 2019 Share January 11, 2019 Engine is fine, spare parts easy to find, won't blow your piston seals with the amount of compression on this one. DQ200 gearbox is fine also lah, everyone heard all the horror stories about it, and it will keep going round and round. Truth is, it is an ok gearbox. Take it from me, ex jetta single charge owner, same engine, and gearbox, mod here mod there, drive like monster. DQ200 only tell me it is going to die please change it out at the 160K mark. Link to post Share on other sites More sharing options...
walkofwinners 4th Gear January 11, 2019 Share January 11, 2019 Engine is fine, spare parts easy to find, won't blow your piston seals with the amount of compression on this one. DQ200 gearbox is fine also lah, everyone heard all the horror stories about it, and it will keep going round and round. Truth is, it is an ok gearbox. Take it from me, ex jetta single charge owner, same engine, and gearbox, mod here mod there, drive like monster. DQ200 only tell me it is going to die please change it out at the 160K mark. So usually engine is fine as long as gearbox dont uplorry else easily 5k down the longkang Link to post Share on other sites More sharing options...
FastRM 2nd Gear January 11, 2019 Share January 11, 2019 Don't so morbid la, green is indeed an exotic color for most of us.Under the hood everything else still remains the same. Link to post Share on other sites More sharing options...
adrian140180 5th Gear January 11, 2019 Share January 11, 2019 So usually engine is fine as long as gearbox dont uplorry else easily 5k down the longkang My engine was fine, except for: 1) Crankcase gasket leak 2) turbocharger manifold wastegate flap actuator jammed, twice (replaced twice with scrap unit) Link to post Share on other sites More sharing options...
walkofwinners 4th Gear January 11, 2019 Share January 11, 2019 My engine was fine, except for: 1) Crankcase gasket leak 2) turbocharger manifold wastegate flap actuator jammed, twice (replaced twice with scrap unit) How much was the damage to fix? Link to post Share on other sites More sharing options...
Pinkpan 1st Gear January 11, 2019 Share January 11, 2019 Wah.. green is too much for me too.. prefer steel grey type-low profile.. Lol Link to post Share on other sites More sharing options...
adrian140180 5th Gear January 11, 2019 Share January 11, 2019 How much was the damage to fix?Few hundreds for the gasket replacement. Over a thousand each time the turbo kaput. Link to post Share on other sites More sharing options...
Contrarian 2nd Gear January 11, 2019 Share January 11, 2019 Engine is fine, spare parts easy to find, won't blow your piston seals with the amount of compression on this one. DQ200 gearbox is fine also lah, everyone heard all the horror stories about it, and it will keep going round and round. Truth is, it is an ok gearbox. Take it from me, ex jetta single charge owner, same engine, and gearbox, mod here mod there, drive like monster. DQ200 only tell me it is going to die please change it out at the 160K mark. To overhaul a gearbox once in a 10-year life cycle is with the normal range and acceptable. 1 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged January 11, 2019 Share January 11, 2019 Thank, points taken Heard some say don’t go over 110 and don’t rev to 3k rpm n above 1st timer as a car owner May I know which brand engline oil n oil filter? Is it done at outside workshop? All the oil filters and oil for first 3 service is free at 15 30 and 45 K. Conti cars and to a lesser extent, Some of the very keen drivers has sent the oil analysis to check if the car has any issue at 10,000 found that the oil still has plenty of life. So, the 1000 km oil change is really quite unnecessary unless you driving another make of cars. For that, its anyone guess. Link to post Share on other sites More sharing options...
Sdf4786k Twincharged January 11, 2019 Share January 11, 2019 (edited) To overhaul a gearbox once in a 10-year life cycle is with the normal range and acceptable. I was one of the lucky few on a GTi with usual 60,000 km DSg oil change and drove it till 360,000km or there about without a single over haul or parts replacement. I was so impressed that I bought another one once I scrap it. It has its usual problem I would imagine, but I am now on my 3rd Golf and pretty much can confirm its still relatively fun to own. Only issue with the Mk 7 EA888.3 is not the engine perse but the Water pump and coolant tank at 10,000 km for BOTH MK7 unit. Claim under warranty I would imagine the VRS to be the same bang for the buck experience. Edited January 11, 2019 by Sdf4786k Link to post Share on other sites More sharing options...
Golf7roy 4th Gear January 11, 2019 Share January 11, 2019 https://www.sgcarmart.com/news/writeup.php?AID=390&FBSKIPPTO=1&fbclid=IwAR3ltAE1Lq0F17_UmXp3QH6r7z9hl7ErGkawpifHMdOwOxF9efH1rXckrHQ car mods that makes the car worst Link to post Share on other sites More sharing options...
Theoldjaffa Hypersonic January 11, 2019 Share January 11, 2019 I was one of the lucky few on a GTi with usual 60,000 km DSg oil change and drove it till 360,000km or there about without a single over haul or parts replacement. I was so impressed that I bought another one once I scrap it. It has its usual problem I would imagine, but I am now on my 3rd Golf and pretty much can confirm its still relatively fun to own. Only issue with the Mk 7 EA888.3 is not the engine perse but the Water pump and coolant tank at 10,000 km for BOTH MK7 unit. Claim under warranty I would imagine the VRS to be the same bang for the buck experience. 360k without clutch change? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Crazy weather in Singapore ?
Marathons in Singapore
National Service in Singapore
