Splashee 1st Gear April 19, 2017 Share April 19, 2017 Hi all, recently just got my ride so still getting used to it, one question first, does it have a car alarm that i can use to locate my car if i forget where i park it in a large carpark ? Previous ride jus needs me to press the lock button to get some sound sensing but it kinda does not work with Vezel it does have alarm but does not work like your aftermarket alarm whereby you can locate your ride by the sounds. You ned to install 3rd party alarm to have that functions. ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Tilt Neutral Newbie April 20, 2017 Share April 20, 2017 Hi all, my agent quoted me $1100 with 10% ncd from AXA, is that price reasonable? 1 Link to post Share on other sites More sharing options...
Bieffe 2nd Gear April 20, 2017 Share April 20, 2017 Hi all, my agent quoted me $1100 with 10% ncd from AXA, is that price reasonable?I think is totally not. Pls check with others. Direct Asia and Aviva sure cheaper but claim wise I not so sure. Link to post Share on other sites More sharing options...
Kopites Supersonic April 20, 2017 Share April 20, 2017 I think is totally not. Pls check with others. Direct Asia and Aviva sure cheaper but claim wise I not so sure.Mine 600 plus with aunty Lucy. 55% ncb. Link to post Share on other sites More sharing options...
Ian1 2nd Gear April 21, 2017 Share April 21, 2017 Mine 600 plus with aunty Lucy. 55% ncb.For Vezel, $490 with 50% NCD and 5% Offence Free Discount. Driver's age 40-60yr old. Indoor occupation. Link to post Share on other sites More sharing options...
LPPL 6th Gear April 21, 2017 Share April 21, 2017 Hi all, my agent quoted me $1100 with 10% ncd from AXA, is that price reasonable?You tried India, Sompo, Liberty and Tokio Marine? Link to post Share on other sites More sharing options...
rtkh8888 Neutral Newbie April 22, 2017 Share April 22, 2017 Hi all, Recently my vezel encounter this problem. After start engine, abs light is on. Also got orange color "A" symbol. Skid and CTBA light also on. The handbrake "P!" symbol also on. Not sure what is wrong. Anyone encounter this before or know how to solve? Thanks! 1 Link to post Share on other sites More sharing options...
Gsport 1st Gear April 23, 2017 Share April 23, 2017 For Vezel, $490 with 50% NCD and 5% Offence Free Discount. Driver's age 40-60yr old. Indoor occupation. Which insurance company ? That's a good deal you got. I am paying $800 (after 50% NCD) for my mum for ntuc as her age is 75 and nobody else will insure except ntuc. 1 Link to post Share on other sites More sharing options...
Ngloong Neutral Newbie April 23, 2017 Share April 23, 2017 Hi all, Recently my vezel encounter this problem. After start engine, abs light is on. Also got orange color "A" symbol. Skid and CTBA light also on. The handbrake "P!" symbol also on. Not sure what is wrong. Anyone encounter this before or know how to solve? Thanks! What issues did you face before these symbols showed up ? For my case was battery flat, jump start once and then changed of battery solved the issue. 1 Link to post Share on other sites More sharing options...
Jackwolf 1st Gear April 23, 2017 Share April 23, 2017 ya i just read in another thread that TEK doesn't encourage cam o running while parking as it might affects the car battery and the ismart function. if it is so, then the solution is very limited other than installing an additional battery to support the cam running 24hr. 1 Link to post Share on other sites More sharing options...
rtkh8888 Neutral Newbie April 23, 2017 Share April 23, 2017 @ngloong Din't face any issue before this. Only start engine without pressing brake. After that off and on engine again then all these symbols pop up Link to post Share on other sites More sharing options...
w7_lee 4th Gear April 23, 2017 Share April 23, 2017 (edited) Hi all, my agent quoted me $1100 with 10% ncd from AXA, is that price reasonable? I'm paying $655 (@ 50% + 5%). Did check in Direct & Aviva but both not able to be lower than $655. So I think your quote is not too bad since you only have 10% NCD. Edited April 23, 2017 by w7_lee 1 Link to post Share on other sites More sharing options...
Ozkaki 2nd Gear April 23, 2017 Share April 23, 2017 is there a blind spot monitoring and rear clearance monitoring option for Vezel? 1 Link to post Share on other sites More sharing options...
Aukang 6th Gear April 23, 2017 Share April 23, 2017 is there a blind spot monitoring and rear clearance monitoring option for Vezel? Aren't these available on the FL versions since mid last year? 1 Link to post Share on other sites More sharing options...
Tilt Neutral Newbie April 23, 2017 Share April 23, 2017 I'm paying $655 (@ 50% + 5%). Did check in Direct & Aviva but both not able to be lower than $655. So I think your quote is not too bad since you only have 10% NCD. alright thanks, my first ride so i will slowly earn my ncd :) 2 Link to post Share on other sites More sharing options...
LPPL 6th Gear April 23, 2017 Share April 23, 2017 I'm paying $655 (@ 50% + 5%). Did check in Direct & Aviva but both not able to be lower than $655. So I think your quote is not too bad since you only have 10% NCD. Can get cheaper than that for 50% NCD comprehensive 2 Link to post Share on other sites More sharing options...
Andre1288 1st Gear April 24, 2017 Share April 24, 2017 is there any difference between the 2015 vezel hybrid and 2016 vezel hybrid?? The only thing i can notice was the fog lights are different. 2 Link to post Share on other sites More sharing options...
Splashee 1st Gear April 24, 2017 Share April 24, 2017 is there any difference between the 2015 vezel hybrid and 2016 vezel hybrid?? The only thing i can notice was the fog lights are different. before Feb 2016 is Pre FL, after Feb 2016 is FL... difference quite a bit...FL models has more factory fitted equipments as compared to pre FL. Wiser to get 2016 unless its a 2nd hand vezel hybrid ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Takata airbag recall
