Hamburger Hypersonic May 11, 2020 Share May 11, 2020 Its the tyre. Try placing the back to the front and see how it feels. ↡ Advertisement Link to post Share on other sites More sharing options...
Toeknee_33 Turbocharged May 12, 2020 Share May 12, 2020 9 hours ago, gamer2030 said: Hi anybody notice a slight pull towards the left when cruising at higher speeds on highways? Had some mechanics have a look, have balanced wheels, rotated etc but its still there. Brought car in for wheel alignment and there is really nothing wrong. It really very minor, but i notice it on long cruises. Just wanted to see if others have encountered something similar. If it is really very minor, and only noticeable over a large distance, then it is not the car but the road. Most of our roads are cambered to the left to cater for water drainage, and its natural for a car to drift to the left. 3 Link to post Share on other sites More sharing options...
STiYaKuzA 3rd Gear May 13, 2020 Share May 13, 2020 On 5/11/2020 at 11:55 PM, Hamburger said: Its the tyre. Try placing the back to the front and see how it feels. If 3.3 version its running staggered setup, can't rotate back to front. Not too sure about 2l though Link to post Share on other sites More sharing options...
Volvobrick Supersonic May 13, 2020 Share May 13, 2020 On 5/11/2020 at 11:39 PM, gamer2030 said: Hi anybody notice a slight pull towards the left when cruising at higher speeds on highways? Had some mechanics have a look, have balanced wheels, rotated etc but its still there. Brought car in for wheel alignment and there is really nothing wrong. It really very minor, but i notice it on long cruises. Just wanted to see if others have encountered something similar. Should not pull left or right. After CB, leave your car with MCFers. They will be happy to test for you! Meanwhile can try swapping the front wheels left to right to eliminate possibility of tire/wheel problem. 😁 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic May 13, 2020 Share May 13, 2020 (edited) You guys do know that roads are built with a slight gradient to drain off rain water? If your car is pulling towards the longkang. It's fine. Blame it on the electric power steering that modern cars have. It gets even lighter when you are on the expressway. Edited May 13, 2020 by Watwheels Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic May 13, 2020 Share May 13, 2020 22 minutes ago, Watwheels said: You guys do know that roads are built with a slight gradient to drain off rain water? If your car is pulling towards the longkang. It's fine. Blame it on the electric power steering that modern cars have. It gets even lighter when you are on the expressway. Hold steering wheel straight then if car straight its ok if let go steering wheel to test sure will pull to the left Link to post Share on other sites More sharing options...
Firehorse 1st Gear May 13, 2020 Share May 13, 2020 Take a different car, drive the same road....see got pull at the same place and same direction. 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic May 13, 2020 Share May 13, 2020 Trust me guys, been there done that. When the car pulls, it's not the gradient of road that caused it, although it is one of the attributes to a lesser extend. Mine pulled. A Pirelli P7. Did 4 wheels alignment, side slip, changed lower arms and control arms that were little worn. Nothing works. Finally decided the most expensive fix, 4 new tyres. Works like a charm. 3 Link to post Share on other sites More sharing options...
gamer2030 Clutched May 14, 2020 Share May 14, 2020 Thanks guys. Yea its really vey minor and car travels straight with the steering wheel straight. There is a preference for it to tilt towards the left which, as you guys mentioned, may be due to the left camber of the highways and roads. Anyone have recommendation of any sites with truly flat roads around SG? Like a huge empty carpark or very very flat straight road of maybe 1-2 kms? C&C said they can test for me but I don't want to trouble people if this is a common thing everyone experiences. Btw I have rotated the tyres front to back and left to right (2 L stinger so non-staggered set-up). Still there. Link to post Share on other sites More sharing options...
Mkl22 Supersonic May 14, 2020 Share May 14, 2020 4 minutes ago, gamer2030 said: Thanks guys. Yea its really vey minor and car travels straight with the steering wheel straight. There is a preference for it to tilt towards the left which, as you guys mentioned, may be due to the left camber of the highways and roads. Anyone have recommendation of any sites with truly flat roads around SG? Like a huge empty carpark or very very flat straight road of maybe 1-2 kms? C&C said they can test for me but I don't want to trouble people if this is a common thing everyone experiences. Btw I have rotated the tyres front to back and left to right (2 L stinger so non-staggered set-up). Still there. ECP 2 Link to post Share on other sites More sharing options...
Volvobrick Supersonic May 14, 2020 Share May 14, 2020 16 minutes ago, Mkl22 said: ECP LCK runway. 1 Link to post Share on other sites More sharing options...
Toeknee_33 Turbocharged May 14, 2020 Share May 14, 2020 (edited) 8 hours ago, gamer2030 said: Thanks guys. Yea its really vey minor and car travels straight with the steering wheel straight. There is a preference for it to tilt towards the left which, as you guys mentioned, may be due to the left camber of the highways and roads. Anyone have recommendation of any sites with truly flat roads around SG? Like a huge empty carpark or very very flat straight road of maybe 1-2 kms? C&C said they can test for me but I don't want to trouble people if this is a common thing everyone experiences. Btw I have rotated the tyres front to back and left to right (2 L stinger so non-staggered set-up). Still there. If you need 1-2 km of road to detect it, or if you need to look out for it, you really really don't have a pulling problem lah. It's like a dripping water tap. Once it gets into your head you can't stop thinking about it, and it gets worse and worse. If you are truly disturbed by it, you can get the car alignment set up to pull slightly to the right. But it's not something I would do. Edited May 14, 2020 by Toeknee_33 1 Link to post Share on other sites More sharing options...
Fuse01 1st Gear July 9, 2020 Share July 9, 2020 car ownership from maintenance point of view korean will be cheaper then a conti. most conti each service can be 500 and above while the korean can be half of it. Link to post Share on other sites More sharing options...
inlinesix Hypersonic July 9, 2020 Share July 9, 2020 38 minutes ago, Fuse01 said: car ownership from maintenance point of view korean will be cheaper then a conti. most conti each service can be 500 and above while the korean can be half of it. Why Korean car service cost can be half of Conti? Link to post Share on other sites More sharing options...
theory_87 3rd Gear July 9, 2020 Share July 9, 2020 2 hours ago, Fuse01 said: car ownership from maintenance point of view korean will be cheaper then a conti. most conti each service can be 500 and above while the korean can be half of it. That is if you just go to the workshop empty handed. If you know where to source for parts online, conti servicing can be very cheap as well. Link to post Share on other sites More sharing options...
Hamburger Hypersonic July 9, 2020 Share July 9, 2020 Another tiagong aka hearsay theory with nothing to back up. Yawn.... 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic July 9, 2020 Share July 9, 2020 (edited) 26 minutes ago, Hamburger said: Another tiagong aka hearsay theory with nothing to back up. Yawn.... Actually, it is quite true. That's because Conti must use exotic engine oil. Otherwise, it will kaboom. On the other hand, Korean can use $20 engine oil. 😂 Edited July 9, 2020 by inlinesix 1 Link to post Share on other sites More sharing options...
SZ_ford 5th Gear July 9, 2020 Share July 9, 2020 2 hours ago, Fuse01 said: car ownership from maintenance point of view korean will be cheaper then a conti. most conti each service can be 500 and above while the korean can be half of it. u mean normal oil change? i paid 160 for it. unless you mean some parts to change ↡ Advertisement Link to post Share on other sites More sharing options...
2025 Kia EV3
2025 Kia EV3
KIA FY24 Carnival - Hybrid
Haiz...another suicide?
2022 Kia EV6
2022 Kia EV6
McLaren entry level sports car, 570S and its related series
