Kangadrool Supersonic December 26, 2016 Share December 26, 2016 Squeaky sound for the first few wipes is normal. It will usually go away when you spray water out from the wiper water tank. Even pure water in wiper tank will do the trick as water will become slimy after some time in storage. If it's constantly juddering, then it's another issue. ↡ Advertisement Link to post Share on other sites More sharing options...
inlinesix Hypersonic December 26, 2016 Share December 26, 2016 On 12/26/2016 at 12:06 AM, Extremme said: Been reading thru some threads. Later i am going to try newspaper with polyglaze hope it works.Don't waste time. Make sure ur wiper water got wiper fluid. If not, go PML buy 1 bottle. My Mini is using BMW wiper fluid. No juddering. BMW wiper fluid has lubrication function. Link to post Share on other sites More sharing options...
Blueray Hypersonic December 26, 2016 Share December 26, 2016 lubrication function ... hmmm ... Link to post Share on other sites More sharing options...
RadX Moderator December 26, 2016 Share December 26, 2016 On 12/26/2016 at 9:23 AM, Blueray said: lubrication function ... hmmm ... U dirty bugga Link to post Share on other sites More sharing options...
Blueray Hypersonic December 26, 2016 Share December 26, 2016 On 12/26/2016 at 10:08 AM, RadX said: U dirty bugga You got me wrong. Maybe I should propose to Bosch wiper blades with lubricating strips, like Gillette razor blades. 2 Link to post Share on other sites More sharing options...
7hm Turbocharged December 26, 2016 Share December 26, 2016 On 12/26/2016 at 10:25 AM, Blueray said: You got me wrong. Maybe I should propose to Bosch wiper blades with lubricating strips, like Gillette razor blades. The Best a Car Can Get!™ Link to post Share on other sites More sharing options...
Jonpaul0104 2nd Gear December 27, 2016 Share December 27, 2016 On 12/25/2016 at 5:24 AM, Extremme said: Hi, is there a way to prevent the annoying windscreen wiper squeaking sound? My wiper is brand new and stock but whenever I turned on the wiper while raining, it will have the squeaking sound usually what i do is to use 3M sand glass sponge to clay it first then use the Comma glass scrub to clean and wash off.... always solve the squeaking issue Link to post Share on other sites More sharing options...
Daniu82 Supercharged December 27, 2016 Share December 27, 2016 On 12/27/2016 at 1:53 AM, Jonpaul0104 said: usually what i do is to use 3M sand glass sponge to clay it first then use the Comma glass scrub to clean and wash off.... always solve the squeaking issue Where can I get these 2 items? I have the same issue with TS after sending my car for PPS, they applied Aquapel on the glass, I think most likely this is causing the problem. Can help? Link to post Share on other sites More sharing options...
Jonpaul0104 2nd Gear December 27, 2016 Share December 27, 2016 On 12/27/2016 at 3:25 AM, Daniu82 said: Where can I get these 2 items? I have the same issue with TS after sending my car for PPS, they applied Aquapel on the glass, I think most likely this is causing the problem. Can help? if u want, u can drop by my place in Punggol....i can try help u to do FOC..... 1 Link to post Share on other sites More sharing options...
Daniu82 Supercharged December 27, 2016 Share December 27, 2016 On 12/27/2016 at 4:20 AM, Jonpaul0104 said: if u want, u can drop by my place in Punggol....i can try help u to do FOC..... Hey, thanks for the offer but I am quite busy recently as I am moving house, after that need to unpack... Link to post Share on other sites More sharing options...
Jonpaul0104 2nd Gear December 27, 2016 Share December 27, 2016 On 12/27/2016 at 4:28 AM, Daniu82 said: Hey, thanks for the offer but I am quite busy recently as I am moving house, after that need to unpack... oic...3M glass sponge can get from Autobacs....but dun know if they still carry the Comma glass scrub..... got it direct from distributor previously.....not sure if still selling Link to post Share on other sites More sharing options...
flashbang Turbocharged December 27, 2016 Share December 27, 2016 I bought the Glaco Glass Compound and did it over the long weekend. Followed by reapplying rain repellent on my windscreen. Now waiting for the next rainstorm to test it out. Link to post Share on other sites More sharing options...
Vyeron 4th Gear December 27, 2016 Share December 27, 2016 Changed to PIAA silicon wiper, smooth... Got it from Autobac Link to post Share on other sites More sharing options...
Daniu82 Supercharged December 27, 2016 Share December 27, 2016 Thanks, I go there and see if they are selling when I am free. On 12/27/2016 at 6:39 AM, Jonpaul0104 said: oic...3M glass sponge can get from Autobacs....but dun know if they still carry the Comma glass scrub..... got it direct from distributor previously.....not sure if still selling Link to post Share on other sites More sharing options...
inlinesix Hypersonic December 28, 2016 Share December 28, 2016 BMW wiper fluid Link to post Share on other sites More sharing options...
jasperng85 Neutral Newbie January 20, 2017 Share January 20, 2017 Bro, you can try using Bullsone Metal Hybrid Wipers, installed it on my C250 Coupe, used to have wiper juddering even with a brand new borsh wiper. Now no more wiper juddering. If I'm not wrong, Bullsone is a korean brand. Quite affordable as well. Got it at some workshop around Serangoon North. Link to post Share on other sites More sharing options...
Extremme 4th Gear January 20, 2017 Author Share January 20, 2017 I always thought stock wiper is the best :P Link to post Share on other sites More sharing options...
Sunny Hypersonic January 20, 2017 Share January 20, 2017 Stamford tyre Lok Yang has 20% off all wipers...other accessories up to 70% Seems their biz quite bad. ↡ Advertisement 4 Link to post Share on other sites More sharing options...
Wiper Blade Refills
Wiper Blade Refills
how to remove micro/fine scratches on windscreen
Wipers for S60
Wipers for S60
How to remove stubborn stain on windscreen?
NWB wiper
NWB wiper
