andrewyewkc 5th Gear May 22, 2018 Share May 22, 2018 (edited) Any bros had to change their batteries within the first two years? Just checking if anyone has had to face dead cars or are there clear symptoms that the battery is going to fail? My battery (on W211) lasted me more than 4 years. I wanted to change it at 2 years but my workshop told me no need. AA did a check on my battery at about 3.5 years and it was still in very good condition. AA has a device that can measure the remaining life of your battery. I needed AA because my battery had gone flat after my wife sat in the car listening to music with the fan running for more than an hour without the alternator charging. I will normally measure the voltage of the battery to see if it is ok with my ZUS device. Edited May 22, 2018 by andrewyewkc ↡ Advertisement Link to post Share on other sites More sharing options...
Heman75 Supercharged May 22, 2018 Share May 22, 2018 Batteries are not covered in warranty. It is general tear and wear item lol in CnC batteries are warranty for 2yrs. Link to post Share on other sites More sharing options...
Gnahp Turbocharged May 22, 2018 Share May 22, 2018 When I look at the undercarriage of the W211, I can two solid steel members running through the entire length of the car. They are not designed to crumple or buckle. Below is the undercarriage of the W204 and you can see the steel members. the front subframe doesn't run through the entire length of the car it ends near to the firewall 3 Link to post Share on other sites More sharing options...
andrewyewkc 5th Gear May 23, 2018 Share May 23, 2018 the front subframe doesn't run through the entire length of the car it ends near to the firewall Thanks for showing the picture. The subframe would be connected to other structural elements running through the entire length of the car. Important thing is that the entire vehicle is structurally robust and will not easily crumple in a collision. Link to post Share on other sites More sharing options...
Vratenza Supersonic May 23, 2018 Share May 23, 2018 Don't think conti chassis frame design is very much different from other makers. Just a matter of choice of material and where they reinforce important structural points. this is the 2015 C-Class chasis: 1 Link to post Share on other sites More sharing options...
Admiralty 4th Gear May 23, 2018 Share May 23, 2018 Any bros had to change their batteries within the first two years? Just checking if anyone has had to face dead cars or are there clear symptoms that the battery is going to fail? Bro, I changed mine at 14months under warranty. On board display shows "Active Brake Assist Functions Limited". P/S : Replace some parts on left wheel also due to noise at turn, FOC also. 1 Link to post Share on other sites More sharing options...
Voodooman Supersonic May 23, 2018 Share May 23, 2018 Any bros had to change their batteries within the first two years? Just checking if anyone has had to face dead cars or are there clear symptoms that the battery is going to fail? I changed the main battery at 2.5 years. The start stop battery, if you have one, can just leave it to die then change as start stop will be disabled when this battery is impaired, I was told. So I will change when this function stops working. It is still working at Year 3. Link to post Share on other sites More sharing options...
vincentnghangchuan 1st Gear May 25, 2018 Share May 25, 2018 Just to check if my car's start stop function is not working for days, does it mean the battery is dead? 1 Link to post Share on other sites More sharing options...
Vratenza Supersonic May 25, 2018 Share May 25, 2018 no irritating error code reminder when that happens? I changed the main battery at 2.5 years. The start stop battery, if you have one, can just leave it to die then change as start stop will be disabled when this battery is impaired, I was told.So I will change when this function stops working. It is still working at Year 3. Link to post Share on other sites More sharing options...
vincentnghangchuan 1st Gear May 25, 2018 Share May 25, 2018 no irritating error code reminder when that happens? no indication on screen, the green start stop icon just doesnt appear Link to post Share on other sites More sharing options...
Vratenza Supersonic May 25, 2018 Share May 25, 2018 Oh..thanks! I doubt I will notice it since I turn it off every single trip. Second nature now. no indication on screen, the green start stop icon just doesnt appear I did a quick search... seem like there should be a warning: no indication on screen, the green start stop icon just doesnt appear Link to post Share on other sites More sharing options...
Sdf4786k Twincharged May 25, 2018 Share May 25, 2018 Any bros had to change their batteries within the first two years? Just checking if anyone has had to face dead cars or are there clear symptoms that the battery is going to fail? Me. Symtom is the remote even when you change the remote batt , the alarm can trigger off. Other thing is the car cam also does go a little wonky And the most obvious is the Wiper and headligts when you turn them on during rain , the instrument lights dim a little. Link to post Share on other sites More sharing options...
Voodooman Supersonic May 25, 2018 Share May 25, 2018 no irritating error code reminder when that happens?Haven't seen it but i don't use it much in my first 2 years of ownership. Now I have gotten used to it. Link to post Share on other sites More sharing options...
kingfisher07 1st Gear May 25, 2018 Share May 25, 2018 (edited) Just to check if my car's start stop function is not working for days, does it mean the battery is dead?Yes it is definitely an early warning that battery is going to die soon in few months time when that happens. Happened to my first two batteries. To play safe, pls send car to workshop or CnC to check. Edited May 25, 2018 by kingfisher07 3 Link to post Share on other sites More sharing options...
Voodooman Supersonic May 25, 2018 Share May 25, 2018 (edited) Yes it is definitely an early warning that battery is going to die soon in few months time when that happens. Happened to my first two batteries. To play safe, pls send car to workshop or CnC to check. Main battery or start stop battery? Edited May 25, 2018 by Voodooman Link to post Share on other sites More sharing options...
kingfisher07 1st Gear May 25, 2018 Share May 25, 2018 Main battery or start stop battery?Main battery 1 Link to post Share on other sites More sharing options...
Wheelslover 2nd Gear May 25, 2018 Share May 25, 2018 Yes it is definitely an early warning that battery is going to die soon in few months time when that happens. Happened to my first two batteries. To play safe, pls send car to workshop or CnC to check. Yes, is warning sign indeed. Happen to me too,But when I sent in to cnc, they said it due to battery life span, but still within their healthy range, so cannot replace battery. So I LL 2 Link to post Share on other sites More sharing options...
vincentnghangchuan 1st Gear May 25, 2018 Share May 25, 2018 Yes, is warning sign indeed. Happen to me too,But when I sent in to cnc, they said it due to battery life span, but still within their healthy range, so cannot replace battery. So I LL ok thks to all bros for your reply...will call Cnc for a check ↡ Advertisement 1 Link to post Share on other sites More sharing options...
All things W124 :-)
All things W124 :-)
New Mercedes GLB
New Mercedes GLB
