2017 Hyundai i30
Thecarboy302
This is the general consensus.
1. Avoid creeping as much as possible, especially not on a slope. DO NOT DRIVE it like a conventional auto with a torque converter. With a conventional auto,u can even hold the car on a slope by lightly tapping the accelerator pedal without using yr foot brakes. Never ever do that with a DCT. Use the electric parking brake or turn on the auto brake hold feature. U can have the parking brake engaged with the transmission in D. Dont have to switch between N and D.
2. On a slope or in a jam, let the car in front move further away and u can accelerate normally without creeping. Of course, it isnt very practical if u are in a causeway jam.
3. At MSCP slopes, using the manual function helps. If u notice carefully, on VW's 7 speed DCT, 1st gear is seldom selected even when moving slowly on the slope... to prevent this jerkiness i believe. Perhaps u can use the manual function and use second gear.
and use engine oil with low volatility (NOACK).
Yes. Good efficiency but
Is so difficult to maintain the dry DCT with so many don't list... especially I am frequent travel to malaysia via the causeway jam.
Clutch plate replacement will be needed based on my usage if i keep the car till end of coe..
Thats why I avoiding DCT even it give better performance and response.
If the Tuscon 1.6T come with normal trans or wet DCT or CVT i will go for it already.
Unfortunately Hyundai choose dry DCT because they have spend so much on developing it for hybrid use as well.
Sigh...
U'll still need a oil catch can as the BOV has nothing to do with the crankcase ventilation system. Blow bys is still routed by the system back into the intake.
If i add a blow off valve that recirculates to the atmosphere, i wont need an oil catch can anymore right?
Just got my ride today. The turbo lag when going up mscp is really quite obvious, like a sudden surge at the end of the ramp when the car is almost level. May be quite dangerous if there's another car coming down from the adjacent ramp.
Congratulation on the new ride. Dont worry to much. You will used to it soon. Did you try to manual shift to gear 2 or 1.
Thanks bro. Have not tried engaging the gears manually yet, hopefully it helps. However if the surge is coming from the turbo lag, not sure if manually setting the gears can reduce the effect..
I also read from somewhere else need to warm up a bit for this turbo units before get power in order.
Every morning we normally going down ramp from mscp, so I guess no issue.
And please drive gentle when cold start, and also almost reach car park. Need to take note for general turbo car.
pennzoil FTW.
But as intake valve carbon, need oil catch can to solve it,
Cannot get cheaply from amazon Liao. Unless shell helix ultra is the same formulation? Edited by Mkl22
Have not seen one on the road yet. Hopefully someone will write honest review after two tanks. Can it really do the hybrid-level of 18km/l?
18 a bit unrealistic. Might be achievable but u doing that purposely. 14 I think possible for day to day
Sigh...
Eh... How do we know if our I30 is dry or wet dct.. This doesn't state in the specification leh
will hyundai's dry clutch DCT suffer from similar issues as VW's dry clutch dsg?
Ya man. I am also very concern. I check with my SE.. he says veloster is using the same technology.. So far haven't hear any issue.
If look purely the possible wear n tear on clutch plates, all dry clutch DCT share the same faith.
Just like manual gb in old days where we are changing the clutch plate as well (but cost cheap compare to DCT)
Other defects on operating issue will be case by case per each individual brands.
Just like early when Hyundai started dry DCT also reported many issue at oversea market (before it was launch here in sg).
