Peck Neutral Newbie September 19, 2006 Share September 19, 2006 Anyone tried this brand called "Thermal Guard" (thermalguard.com.sg) before? I bought my mazda and my agent gave me a voucher for it. It entitled me to the moonlight series, but i topped up $350 for the platinium one. On the second day after installation, i noticed some dirt and tiny air bubbles trapped in the front windscreen. And my right rear window has a little bit that is not sticking to my window. I'm planning to go back to the store and get these 2 pieces reinstalled. But I can only go down this weekend... meanwhile, I can only live with it... ↡ Advertisement Link to post Share on other sites More sharing options...
Hungryforcar 1st Gear September 19, 2006 Author Share September 19, 2006 Call first, maybe they need to book a timeslot for your car. The best time to install is the first car in the morning. Link to post Share on other sites More sharing options...
Danielswift Neutral Newbie September 27, 2006 Share September 27, 2006 Hi Hungry, please cool down. I experienced the same situation like you before. Me using window film for 10 over years. Been to a few places too, talk to the installers and understand that normal films always easiler to install. Well,the important thing is How that particular Film company Rectified. As an consumer basically you just want ppl to do a perfect job. And also the technology of the film is also important cause what i understand is that HO ceramic films are thicker than many others. Anyway hows the perfomance of the film you install? Any feedbacks? Cheers. Link to post Share on other sites More sharing options...
Xabby Neutral Newbie October 8, 2006 Share October 8, 2006 Hey topcat, so did u get the films replaced? I have similar problems too, hopefully it would go away after much baking (just 5 days so far) for me. Link to post Share on other sites More sharing options...
Topcat Neutral Newbie October 12, 2006 Share October 12, 2006 Hi Xabby, Sorry to hear about the trouble... I went down to the installer and explained to him the problems. He had a look and did say that on certain cars where the rear window has a steeper angle, this problem has a tendency to crop up due to the air gaps between the film and demister wires. Anyway, he tried to 'rub rub' the rear window film to squeeze out the air pockets. Spent quite some time doing it. That night, was out driving and noticed that the problem is still there, although less noticeable... Next time will try to get them to re-install the film. If it doesn't work again, I might visit other solar film installers and see if they can guarantee that won't have this problem...then just change the rear window Hope you will find a better solution! Link to post Share on other sites More sharing options...
Simlimking Neutral Newbie August 18, 2007 Share August 18, 2007 hi all did with Llumar serangoon my honda civic fd after replacing the front wind screen solar tint, there is still wavy lines he said it was the glue or is it the angle of the honda civic wind screen that gives dis type /////// of distortion any civic brothers, need advice king Link to post Share on other sites More sharing options...
Apollo 1st Gear August 18, 2007 Share August 18, 2007 quite common for solar film to behave this way. they r afterall woven glassfibres plus spluttering of chemicals over it. difficult to control spluttering process. from certain angle, the film will b thicker hence can see the wavy Link to post Share on other sites More sharing options...
Char 5th Gear June 26, 2016 Share June 26, 2016 Is it normal to have some little small bubbles on newly installed solar flim as my installer said it will go away after awhile ? 1 Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic June 26, 2016 Share June 26, 2016 Small bubble i dunno but if theres some smog its normal Link to post Share on other sites More sharing options...
D3badge 6th Gear June 26, 2016 Share June 26, 2016 Very very small like few mm in diameter is normal and yes it will go away, but bigger than 5mm might not Link to post Share on other sites More sharing options...
Char 5th Gear June 26, 2016 Share June 26, 2016 Quite many like 10+ in one window all small 1mm is it normal ? Link to post Share on other sites More sharing options...
Ivan_06 5th Gear June 26, 2016 Share June 26, 2016 Is it normal to have some little small bubbles on newly installed solar flim as my installer said it will go away after awhile ?Lousy workmanship.. Mine has no bubbles since the first day.. 1 Link to post Share on other sites More sharing options...
Char 5th Gear June 26, 2016 Share June 26, 2016 Lousy workmanship.. Mine has no bubbles since the first day..Not even small bubbles like 1-2mm ? Link to post Share on other sites More sharing options...
youpapalite 3rd Gear June 26, 2016 Share June 26, 2016 After a while then monitor if still at there lo. They already tell u after a while. U want them replace also need give them benefit of doubt. Normally 3-5 days clear already. IMO is normal. Mine was gone within 3 days. If after a while still there then ask them replace. But check how long is their a while. Link to post Share on other sites More sharing options...
Nzy Twincharged June 26, 2016 Share June 26, 2016 Usually around 3-5 days will be gone. Also will say cannot wind down windows for 3 days. By then, all the bubbles should be gone or else can go back to them again. Link to post Share on other sites More sharing options...
Ivan_06 5th Gear June 26, 2016 Share June 26, 2016 Not even small bubbles like 1-2mm ?Nope. None at all. From the minute they were done in my presence Link to post Share on other sites More sharing options...
Char 5th Gear June 26, 2016 Share June 26, 2016 Mine already 3 weeks ... Link to post Share on other sites More sharing options...
sake Twincharged June 26, 2016 Share June 26, 2016 Mine already 3 weeks ... 3 weeks will not go away anymore. go back and show them. ↡ Advertisement Link to post Share on other sites More sharing options...
China startup makes large, flexible solar panels in industry first
Rare Annular Solar Eclipse on 26 Dec 11.30 am to 3.30 pm
Solar film JB
Solar film JB
Solar panels on HDB roof.
Sun cable. Solar energy from australia
NASA's Voyager 1 is sending mysterious data from beyond our solar system. Scientists are unsure what it means.
Microsoft to buy solar power in Singapore
v-kool solar film
v-kool solar film
