boonhat_91 6th Gear July 23, 2020 Share July 23, 2020 1 hour ago, Stratovarius said: The wires are concealed, but likely to come from the ceiling. Since you are moving up the switch, you might have enough wire. An estimation I usually use is if you are shifting the switch say, 3inches to the right, you need to move the also move the switch at least 3 inches up to use the length of same wire. Just curious how you going to run the wires within the wall? You can use a terminal block to extend the wire easily if you can cut a groove in the wall. Actually I would rather not cut the wall if I can don't do so. So I will run the wires on the outside, something like what bro t0y0ta described. ↡ Advertisement Link to post Share on other sites More sharing options...
boonhat_91 6th Gear July 23, 2020 Share July 23, 2020 2 minutes ago, Dafansu said: usually need to extend the wiring. likely u need to install box version as can't drill a hole in the wall. Thanks for the pic! Hope you didn't specially pluck out your switch just to take a pic 😅 Is that an example of the box version? Link to post Share on other sites More sharing options...
Dafansu Turbocharged July 23, 2020 Share July 23, 2020 35 minutes ago, boonhat_91 said: Thanks for the pic! Hope you didn't specially pluck out your switch just to take a pic 😅 Is that an example of the box version? this is found online, it's wall version, box means will pop out, if not how u going to put on the flat wall Link to post Share on other sites More sharing options...
inlinesix Hypersonic July 23, 2020 Share July 23, 2020 My shoe cabinet position overlap with light switch. The switch is moved to the side of the cabinet. The wiring runs from inside the cabinet. 1 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic July 23, 2020 Share July 23, 2020 (edited) 1 hour ago, boonhat_91 said: Just to clarify, my wardrobe in question is those standalone ikea type, not carpentry built-in one. So mounting the switch on the cupboard is not my top choice, though I have considered as well. Then the simplest option is to pull the wire out (extend if needed) and run a surface trunking to the new switch location. Cover the old hole with this: Drill a hole on the cover and pull the wires through before running them in the surface trunking. You don't want to have exposed wires dangling. Again the shop will be very sian to sell you 10 cm of trunking! Ps. Use small concrete nails to secure the bottom half of the trunking. Edited July 23, 2020 by Volvobrick 1 Link to post Share on other sites More sharing options...
Othello Supersonic July 23, 2020 Share July 23, 2020 (edited) 2 hours ago, boonhat_91 said: Just to clarify, my wardrobe in question is those standalone ikea type, not carpentry built-in one. So mounting the switch on the cupboard is not my top choice, though I have considered as well. ahhhhhh .... anyway, I thought of something. The architrave switch you want only comes in 1 Gang, but your current one is 2 gang. so maybe you have no choice but to mount in on the wardrobe ..... unless one switch is unused currently Edited July 23, 2020 by Othello 2 Link to post Share on other sites More sharing options...
boonhat_91 6th Gear July 23, 2020 Share July 23, 2020 49 minutes ago, Othello said: ahhhhhh .... anyway, I thought of something. The architrave switch you want only comes in 1 Gang, but your current one is 2 gang. so maybe you have no choice but to mount in on the wardrobe ..... unless one switch is unused currently I think architrave switch got 2 gang 3 gang version also have, but anyway I live in this house 20+ years still have not figured out what the present 2nd switch is for 😂 1 Link to post Share on other sites More sharing options...
Othello Supersonic July 23, 2020 Share July 23, 2020 30 minutes ago, boonhat_91 said: I think architrave switch got 2 gang 3 gang version also have, but anyway I live in this house 20+ years still have not figured out what the present 2nd switch is for 😂 Bro, Have you seen how it looks like? 🤣 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic July 23, 2020 Share July 23, 2020 39 minutes ago, boonhat_91 said: I think architrave switch got 2 gang 3 gang version also have, but anyway I live in this house 20+ years still have not figured out what the present 2nd switch is for 😂 Don't doubt the expert. 😄 1 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic July 23, 2020 Share July 23, 2020 12 minutes ago, Othello said: Bro, Have you seen how it looks like? 🤣 Got 2 gang lah! 2 Link to post Share on other sites More sharing options...
Othello Supersonic July 23, 2020 Share July 23, 2020 20 minutes ago, Volvobrick said: Got 2 gang lah! Wah seh....... I first time see. Hopefully can find in SG. 1 1 Link to post Share on other sites More sharing options...
boonhat_91 6th Gear July 29, 2020 Share July 29, 2020 My box switch looks like this.. If the red circle is to screw in the front plate, and the green circle is to screw the box into the wall, does that mean I have to cut/drill extra hole on the box to run my wires through? Link to post Share on other sites More sharing options...
Volvobrick Hypersonic July 29, 2020 Share July 29, 2020 26 minutes ago, boonhat_91 said: My box switch looks like this.. If the red circle is to screw in the front plate, and the green circle is to screw the box into the wall, does that mean I have to cut/drill extra hole on the box to run my wires through? Yes. Just start with the smallest hole at the base (close to wall surface). Enlarge slightly only if too small. 1 Link to post Share on other sites More sharing options...
boonhat_91 6th Gear August 6, 2020 Share August 6, 2020 Done, with much help from dear old dad. Hope my strawberry self can be more handy. Before: After: 3 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic August 6, 2020 Share August 6, 2020 Wires should not be exposed. It's potential hazard. And fails building code. Link to post Share on other sites More sharing options...
Hamburger Hypersonic August 6, 2020 Share August 6, 2020 Ugly sia and dangerous Link to post Share on other sites More sharing options...
Othello Supersonic August 6, 2020 Share August 6, 2020 haha, ok lah, at home no one see. Lighting cable, protected by the MCB bah (most likely 6A rated). Just buy some electrical tape and wrap ard lor ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Car repair and maintenance
Simple home DIY repairs
Home Aircon
Home Aircon
Catalyst converter issue
Advice on exhaust.
Advice on exhaust.
